Aiming Headlights on 4th Gen 4runner
Kip Dynamite
Is it possible to aim/adj. the headlights left or right???
I found the up and down adjusment, but did not see anything else. Thanks.
Yes. There are 2 bolts for adjusting -- the lower bolt (A) is the vertical adjustment, the upper bolt (B) is the horizontal adjustment. See this diagram:
In case you need it, here are the procedures from the repair manual:
1. HEADLIGHT AIM ONLY
HINT:
 For adjustment of headlight aiming, perform with Low
beam.
 The Low
HRunner said:
Hi John, any pictures from the repair manual?
It's not easy to understand... (sorry I am not professional)
For step 1b:
Sorry I think I am too dump~
How big is the paper do I need? And should I prepare the paper and draw the lines before I aligned the car with the paper?
If so, how to determine the H line? It's kinda confuse.
Please help... thanks~
Based on the first diagram from step 1c, I'd presume at least the width of the truck and at least the height of the headlights.
Can anyone post a picture of your beam pattern on the wall? I am a bit confuse and not sure of mine, because I had the JDM headlight....
Thanks.
If you find a flat level parking lot with a wall, you can use chalk to draw lines on the wall. I set mine up by parking 25 feet squared from the wall; draw a horizontal line the same height as the center of the headlight to the ground. Draw vertical lines centered from the distance between the centers of the two headlights. I adjust the lights until the beam
Koz said:
If you find a flat level parking lot with a wall, you can use caulk to draw lines on the wall. I set mine up by parking 25 feet squared from the wall; draw a horizontal line the same height as the center of the headlight to the ground. Draw vertical lines centered from the distance between the centers of the two headlights. I adjust the lights until the beam
