Install Shrockworks Slider by Yourself
jdkilroy
As there are a few folks expecting sliders soon, I thought this might be helpful:
Tools:
scissors jack, floor jack, large C clamp, a maul, some short pieces of wood (2 x 6, 4 x 6, a piece of soft wood like a shingle), 12mm, 14mm, 15mm box or ratchet wrenches (sockets will do you no good on this job except for the 12mm for which a long extension will make life better)
Removed the OEM running boards and after greasing the bolts, put them back in the holes they came from to reduce corrosion.
Cardboard on the floor, positioned the scissors jack at the balance point of the slider with a piece of 2x6 on it. Placed the slider on the scissors jack and got it positioned fore and aft so it lined up where it needed to be. The front edge of the back bracket needs to land just behind the weld on the frame rail.
Start jacking the slider into place with your jack. Helps to whack the underside of the slider brackets as you go along with one of your heavier pieces of wood to encourage it to travel up the frame rail. Watch the back bracket to be sure that it is far enough back to clear the piece of chassis that the bracket is notched out for.
DRIVER"S SIDE:
The bolt for the back bracket has to pass from outer to inner and access to the inside is severely limited due to the gas tank sitting right there next to the frame. I ended up using a thin stick with some really sticky stuff on the end to hold and place the washer, the lock washer and finally the nut onto the end of that bolt. That one took a while and was cause for more than a few exclamations.
The inside of middle bracket passes behind two brake lines that are attached to the inside of the frame. You don't need to detach them but you need to ID them and make a mark on the outside of the frame so you know you are not running into them as you jack the slider into place.
The bolt needed to be bent to get over the weld on top of the frame and then back into the hole on the other side. I just laid it on the edge of a 2 x 6 with the threads resting on the piece of soft wood and hit it in the middle with a 3# maul until I achieved a precision radius.
The front bracket on driver's side required removal of the heat shield over the exhaust pipe (12mm nuts x 3; here's where that long extension comes in handy). Now you have to deal with the gas lines that are right in the way of passing that bolt which has to pass from inside to outside. You will need to gently urge the tubing downward in order to get the bolt into the inside bracket hole. Replace heat shield and head on over to the passenger side.
PASSENGER SIDE:
The same process gets the sllder up onto the frame and again.
I started by positioning the back bracket as in the picture above and securing it with a bolt. The muffler shield needed to be bent temporarily to give better access. Bolt passes outside to inside.
The middle bracket was the easiest of all six. Bolt passes outside to inside.
The front bracket bolt passes inside to outside and again, the bolt required bending so that it could "find" the hole on in the outer bracket.
Both the front brackets required the use of a large clamp to bring the two ears of the bracket together enough so I could get a washer and lock washer on before the nut.
Nothing too severe and again, I'm writing specifically for the 2008 V8; other models may well have other obstacles to overcome. But you can do it alone pretty easily with only a few tools. No question; having two would be handy.
NOTE!
On my sliders there were 3/6 brackets that were too high and rubbed the body of the car. Make sure there is space or you will get an annoying THUD when you go over bumps.
I had to grind some corners down. You will be able to tell as you are jacking it into place.
*off topic question* How did you color match your grille? BTW, love the new lift and sliders!
Thanks Deeds; originally planned to paint chrome grill but a few of the bolts sheared off during removal so I bit the bullet and bought a new one from Toyota Parts Zone. This time I used all stainless Nylock nuts to attach. (my wife thought I had lost my mind when she discovered me cutting out the guts of the brand new grille!)
I'm gonna bump this to share my experience with SW bolt ons in hope sthat it helps someone else.
photobucket isn't working right now, but ill try and post some pics later.
So the passenger slider went on OK, but here are the issues with the front brackets. It seems like the bracket winds up going like | frame / so the bolt goes up and nto the body and is very hard to align. Th problem is aligning the bracket by standing on it like the directions say, or, I used a brake pad spreader and some spacers, when that wasnt working well i used one of those clamp/spreader guys and spread the bracket. Again, problem is the bolt hits the body and is hard to align. FInal solution was to jack up the front leg of the slider from all the way under the corner that was furthest inward. This gave me enough room to get the nut threaded and compress the bracket. Then I get a 12. ratchet wrench stuck in there (i'm a dumbass) between the body and the bracket and on the stud of the bolt.
SO now, what I have to do is go back and take that bolt out, pray the bracket doesn't shift, and add the washers on the end because the study is contacting the body and wont tighten down any more. and I want a lock washer on there for piece of mind. I'm also getting some slight vibrations at lower speeds post install, I think that front bolt really needs to be tightened down.
The gas tank bolt is literally impossible. The only was I was able to do it way by sticking the bolt head through and the nut on the back by the tank. There was no way to get the bolt behind the gas tank and slip it in.
Also, the fuel and brake lines are a huge pain. I broke a bunch of clips to get them out of the way. Also, the XREAS lines are clipped in literally all of the exact spots where the slider brackets go, so I had to break those with a pry bar to get the slider behind.
Overall, the mounting style is very difficult to work with, but I feel as though it is definitely strong. The welds on these were perfect and they seem to be well constructed. I wish that I had gotten them powdercoated and painted over the PC. There was some oil on them that was a real PITA to remove, the instructions say to use acetone and even then it was difficult and Im sure i missed a few spots. Doesnt really matter since I need to repaint them anyway since the movement from installation ripped off a ton of paint. Anyway, I hope that helps someone else.
That is part if the reason I opted for a weld on slider. The potential for interference with my RCI skid plates combined with the little brackets led me to weld on style. Unfortunately I had to pay a welder for attachment.
I wanted them to be removable/wanted to DIY. In retrospect I should have done that.
