Modded sunglasses holder (roof)
4D7
My Oakley Gascans wouldn't fit in the glasses compartment located by the sunroof switch.. so I decided to make use of the waste of space.
Alas.. a flush mounted Samsung Galaxy S I Home dock.. shaved and modded of course.
I basically pulled out the whole console from the headliner and removed the compartment separately. You'll notice if you open yours that there is a large bump in the center on the inside (for supporting your glasses). This bump actually houses the spring mechanism that allows the release button to return to its latched position when the compartment is closed. I had to completely cut this out as it didn't leave enough space to center the phone where it could be usable. I ended up fashioning my own spring return that took up much less space (sorry no pictures). I also cut the entire front of the compartment off (mostly the two ugly sides) so that I could have a smooth flush surface. I used a flat black foam sheet, cut it to shape, and then made a frame behind it so that it would be solid.
In the end it came out perfectly, looks OEM. There are a lot of steps that I made that I haven't mentioned (running wires etc). If anyone is interested, I'll write up a tutorial.
Oh! and this is my first post :p
I just bought my 2003 SR5 V8 4WD a few days ago :)
Sorry for the quality of the picture, my best camera is my phone.. and well, it was in the dock! Tablet camera fail.. I will try to get better ones soon.
<br></br>
I think that's a great idea! I actually use mine though, for garage door remotes.
Oh and Welcome!
Genius! These are the types of things that have allowed America to flourish. Innovation.
I like that it has the OEM look.
I like it, how does that upper console pull out? Do you just yank on it like most interior body panels?
It has two snaps near the rear that go straight up. Pull downward from the rear along the sides, the front has nothing holding it in besides 3 plastic forks that go inward towards the sunroof. There will be a single harness that the lights and sunroof switch are connected to, so pull it down carefully - the harness is unplugged easily.
Thanks!
very nice. Might just need to mount my portable GPS in there. My sunglasses dont fit either.
You could fit a Garmin Nuvi in there with ease. I went with my smart phone because it has Google Nav. I also ran a USB (to charge) and 3.5mm aux cable to the back of my head unit so I can play all of my music from the 16GB sdcard on the phone :)
It tripled as hands free calling too, mic works really well surprisingly - and the call is played over the stereo.
I was thinking about doing something similar. Even if I can get my sunglasses in there, they get all messed up from fingerprints.
Nice place for a GPS or phone for sure. Good to see it implemented.
Thanks!
I have a high end garmin nav. I dont trust the phone as a nav device in the many areas i go with no cell signal.
