Old 08-28-2012, 03:53 PM #1
dannyg dannyg is offline
dannyg is on a distinguished road
110,000 service with timing belt cost?
I have been putting off my timing belt for over a year so I finally went to the dealer to get a quote. I am at 110,500 miles so I figured I would take care of a couple other things besides the belt.
Heres the list of things that will be done and the prices
timing belt $379
w. pump $299
rear diff $60
front diff $60
spark plugs $159
transfer case $60
lube propeller shaft free
which comes out to $1155 OTD
I asked for a better price and he said he would do $925 OTD
Should i jump on this deal or shop around some more?
and also, is there anything else i should be getting done that is not listed?
2003 Limited 4x4 v8
dannyg is offline   Reply With QuoteReply With Quote
Old 08-28-2012, 03:59 PM #2
2TreeManor 2TreeManor is offline
2TreeManor is on a distinguished road
You can and should do the spark plugs yourself.
2008 SR5 2wd.
2TreeManor is offline   Reply With QuoteReply With Quote
Old 08-28-2012, 04:05 PM #3
ASUMTNEER ASUMTNEER is offline
ASUMTNEER will become famous soon enough
Def do the plugs yourself. Very quick and easy.
ASUMTNEER is offline   Reply With QuoteReply With Quote
Old 08-28-2012, 04:15 PM #4
talonjade's Avatar
talonjade talonjade is offline
talonjade is on a distinguished road
talonjade's Avatar
I agree, if you are able to hold a wrench then save the $100 labor and do the plugs yourself.
2003 Sport Edition 4.7L V8 4WD, weather tech, carbon Filter delete, POR-15, Deeza Heavy Duty End-links, Prothane Bushings, AMSoil tranny, AMSoil diffs, Mobile 1 Synthetic, stay tuned more to come!
talonjade is offline   Reply With QuoteReply With Quote
Old 08-28-2012, 04:21 PM #5
boondoggle's Avatar
boondoggle boondoggle is offline
boondoggle is on a distinguished road
boondoggle's Avatar
Not a bad price BUT you could save good chunk by doing the diffs, transfer case and plugs yourself. They require pretty basic hand tools and you could get it all done by lunch even if taking your time.
Nothing wrong with taking it in to get done if you aren't confident though.
Oh, and when you get the TB/Water Pump done, make sure they go ahead and replace the idler pulley(s)/tensioner while he's in there.
There'a local independent shops here in Denver do a Timing Belt/Water Pump kit for under $500. Not sure what the dealer charges.
2004 Sport Edition V8 in "rare" Titanium Metallic
~165k miles, 2nd owner since 99k miles.
boondoggle is offline   Reply With QuoteReply With Quote
Old 08-28-2012, 04:32 PM #6
aha2988's Avatar
aha2988 aha2988 is offline
Real Name: Austin
aha2988 will become famous soon enough
aha2988's Avatar
Real Name: Austin
you can get all the parts for a t-belt kit on amazon for under 400 bucks comes with new water pump, wp seal, crank seal, cam shaft seal, new thermostat, new t-belt, new auto tensioner, new idler pulleys, and a new drive accessory belt.
you dont have to worry about the crank shaft seal or the cam shaft seals I haven't seen or heard of one leaking yet
-Austin
A-Ha's Build
aha2988 is offline   Reply With QuoteReply With Quote
Old 08-28-2012, 09:20 PM #7
ridefast's Avatar
ridefast ridefast is offline
Real Name: Jesse
ridefast is on a distinguished road
ridefast's Avatar
Real Name: Jesse
All the fluids and spark plugs are diy! Use a torque wrench
_____________________________________________
2016 Trail-P Dobinsons 302/325 DK Chromoly, 285 kO2, C4, RCI, BD Squad Sport, XD Phillips HID's, Tint, Husky liners, Crestone Rack
2020 Gx460
2000 Limited 4X4 - OME 881/890- B&M 70264
Overland Bound #10926
ridefast is offline   Reply With QuoteReply With Quote
Old 08-28-2012, 11:35 PM #8
Ok thanks for the replies everyone.
I do have access to basically any tool i need and am decently handy my self, soooo I am considering doing the spark plugs and fluids, but i've never changed spark plugs or any fluids before... I cannot find a tutorial or how to on here, just a lot of tips...Are there any on here/ where do I find this?
I have seen the how-to for the timing belt and it doesn't look like something I would want to do personally, so i will be leaving that up to the dealer.
But if i can save a couple hundred $$ doing these fluids and plugs i'm down. Any advice? recommendations?
2003 Limited 4x4 v8
Old 08-29-2012, 12:06 AM #9
4runnerfevr's Avatar
4runnerfevr 4runnerfevr is offline
4runnerfevr is on a distinguished road
my friend is a mechanics and he charge me $600.00. Got new belts and water pump. You should find aa friend to help you out. You can stand there and watch or help
4runnerfevr is offline   Reply With QuoteReply With Quote
Old 08-29-2012, 06:59 AM #10
ridefast's Avatar
Real Name: Jesse
ridefast's Avatar
Real Name: Jesse
How To: Spark Plug Change (1 GR-FE) - Tacoma World Forums
Front Diff and Transfer Case Oil Change Howto - Tacoma World Forums
Sorry to post from tw but I know that site pretty well and where to find DIY! I just sold my taco ( 3 carseats dont fit) so I guess I'll be learning the ins and outs of t4r site.
2020 Gx460
Old 08-29-2012, 12:58 PM #11
eli_lilly eli_lilly is offline
eli_lilly is on a distinguished road
I can tell you that in South Florida, I will be shelling out about $400 more than that and only getting about half of what is on your list done. I got quotes from 3 dealers and they were all the highest of what I've ever seen mentioned on this forum.
-E
eli_lilly is offline   Reply With QuoteReply With Quote
Old 08-29-2012, 01:06 PM #12
Hey thanks for those, i have the v8 but im sure this combined with all the other advice from the threads on this forum will make that easy enough to do myself.
And then I found http://www.toyota-4runner.org/mainte...-included.html for the fluids so I guess i am good to go do this my self now...
2003 Limited 4x4 v8
Old 08-29-2012, 01:40 PM #13
MikeInNH MikeInNH is offline
MikeInNH is on a distinguished road
While sparkplugs are pretty easy...for a first timer it might be worth it for a friend to show you. Get a spark-plug socket that has the rubber insert.
MikeInNH is offline   Reply With QuoteReply With Quote
Old 08-29-2012, 01:48 PM #14
boondoggle's Avatar
boondoggle's Avatar
And a torque wrench.
I've got the 'click stop' kind and the 'beam or gauge' kind. For your first time doing spark plugs I actually recommend the cheaper 'beam/gauge' kind. Less chance of over torqueing and/or stripping the spark plug hole.
Take it easy. Slow and steady wins the race.
Old 08-29-2012, 02:17 PM #15
NJshadow93's Avatar
NJshadow93 NJshadow93 is offline
NJshadow93 is on a distinguished road
NJshadow93's Avatar
I was just quoted $975 for timing belt, water pump, tensioner, and pulleys from a local shop. How does that sound? I was thinking of asking the dealer to match that price just because I would rather have them do it.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
NJshadow93 is offline   Reply With QuoteReply With Quote
Approximate cost to replace timing belt and water pump osiris3mc 3rd gen T4Rs 47 09-30-2018 01:15 AM
PLEASE help! Timing belt cost, advice Buddy2012 4th Gen T4Rs 21 03-27-2012 08:33 AM
Timing belt service cost SolRayz 4th Gen T4Rs 4 01-19-2011 01:05 AM
CPO Warranty and timing belt cost at 90k miles? RHINO-99 Maintenance/Detailing 0 01-29-2009 11:19 PM
Cost of a Timing Belt T4RBoarder 3rd gen T4Rs 8 11-14-2007 05:59 PM
