NJshadow93's 2006 SR5 Build
Nice build man truck looks sick! I just got my 4runner like a month ago and love it! How far are you from NYC ? I would love to come hit up some trails with you guys.I just need to get my lift and tires on which hopefully be sooner than later!
Thanks! I live around 45 minutes from NYC but going to school about 20 minutes away. You should definitely come out! Actually we might be going within a couple weeks if you're interested. Send me a PM if so!
Nice that's not bad at all, Yeah I'm down! I don't know if I'll be lifted by then but depending on what you guys are doing maybe I could tag along, either I'll hit u up.
Installed my new CB Radio yesterday.
Radio: Uniden Pro520XL
Antenna: 3' Firestik
Hatch Mount: Comet RS720
null_zpsf5d4d5a2.jpg~original
I wired the antenna through the grommet on the top of the hatch, above the headliner, inside the side body panels, down under the side kick plates and under the driver's seat. I used that Liquid Tape stuff to seal the opening in the grommet so no water or dirt gets in.
null_zpsf0c94a39.jpg~original
null_zps8a2bcefb.jpg~original
I hardwired the CB Radio to the 12V outlet in the center consol. I bought a spring for the antenna and a microphone holder at Radioshack. I put a couple strips of electrical tape on the back of the spring to avoid contact with the paint. As of now I just have the antenna wire secured with electrical tape since it's pretty strong. I'll probably look for some clips to stick on and clean the appearance up a bit but as of now this does the job. Onto the rest of the pics:
null_zps8f21a2f7.jpg~original
null_zps04c0cd18.jpg~original
null_zps25443577.jpg~original
null_zps5db47ea6.jpg~original
a>
Hey mike, Did you tape off everything under there that you didn't want to rust over? Or did you just carefully spray? I wanna do this to mine this weekend
If you're referring to the undercarriage, I didn't bother taping anything off or masking. Just sprayed the frame rails, axle, control arms, etc.
Installed a PA speaker to my CB Radio. It's pretty loud, not like a police PA system, but it's loud. I put it in this location because it fit nicely and one bolt coming from the wheel well is enough to keep it securely in place. I may decide to move it if I want more sound output but for now it's sufficient. Played ice cream truck music and other weird noises driving through the streets and got some funny reactions :D :snacker:
photo_zpse15b6814.jpg~original
I also moved my antenna about 6 inches higher on the rear hatch and tuned it. I get great reception now and it's crystal clear.
I tucked the wires for the CB Radio underneath the center console to clean up the appearance.
E201BF6F-4571-44C7-B1F4-C51BB98AE607_zps7sdj2dc2.jpg~original
Also, got half of my order from RCI Metalworks, front engine skid and transmission skid. My transfer case skid should be here next week. I washed them tonight and I'll be painting and installing tomorrow afternoon! Very happy with the quality.
5C73617D-1668-4F8D-8A77-D308FE62D6FB_zps3v4aopga.jpg~original
E82CC764-083B-4D70-A9B8-A43131D3E6AE_zpsi0yohxac.jpg~original
I installed the engine and transmission skid today. I painted the backs of them first, then the other side when it was on the truck already. Very happy with how they came out, now I just can't wait to get my transfer case skid and be done! I had to remove my front diff drop to fit the front skid. On to the pics...
Before painting:
BFE24B4C-2FD8-42E1-970C-DA9FDF85353C_zpszl4mbtrn.jpg~original
74788D18-2717-45EF-8F83-053065C857BF_zpsuohmfpj8.jpg~original
D0A45259-AB71-4777-8F1A-09444E89328B_zpsofgsqksy.jpg~original
After painting matte black (hard to see, but I'll have better pics once the tranfer case skid is on):
9A28D3A3-24A8-462C-8827-9E8E9FF2DC77_zps1i7swkdn.jpg~original
27D63992-02CA-474D-A992-6A32EC88A353_zps3ytdo4yn.jpg.html
890D974D-D88C-4CD9-8D2A-E4574B3EEADB_zpshehun1v5.jpg~original
Installed a rear Daystar 1.5" spacer on the driver side to correct the lean. Seemed to do the job.
DC6AA2E8-5C4D-4BBF-BBB9-D64AD321733E_zpszevezhwc.jpg~original
And a couple shots I took in the snow today.
9911AF72-AA56-4BA8-8B96-F74D7C44163E_zpsl5ypewxp.jpg~original
71796BBB-6549-4997-99CB-D08E8916C4C6_zpscwjctce3.jpg~original
Installed some Skyjacker extended end links, purchased from Summit Racing. They're advertised for the FJ Cruiser but they work just fine on our trucks. Only modification was to slightly drill the hole in the sway bar a little larger, not a big deal. I had to cut the old end links off (would have saved me a lot of time had I decided to do that originally. The passenger side took 20 minutes since I didn't bother trying to remove the sway bar to end link bolt and just broke out the angle grinder. I pretty much followed [MENTION=77955]jdkilroy[/MENTION]'s little write up(Extended Rear Sway Bar End Links installed) , including adding in an extra washer for each, which was a good idea. I didn't bother purchasing grease from Summit Racing, I just used Mobil 1 Synthetic grease for the bushings.
I'm happy with how they look and feel. The ride has definitely improved. I notice bumps are absorbed much better now, and body roll seems to have decreased. I still have to flex it out but so far I'm very impressed. On to the pics:
As I was getting ready to remove the driver side, the UPS truck pulled up and dropped the new ones off. Before assembling the bushings or anything, I took a quick comparison shot.
960C399C-0EAC-4225-B1F5-4F6AF23F1B21_zpswp98bg50.jpg~original
Ready to install
B715C546-7195-46E1-9617-4BD120BF23D9_zpsidq4kjok.jpg~original
Finished product (passenger side)
BF881782-28FC-4F98-A54C-9D1634B7A6A8_zpscdeuhmhr.jpg~original
Did this stuff over a month ago, just been too busy to post this up :D
Cleaned up coax cable for the CB antenna on the rear hatch by using those zip-tie wire hooks.
2488F4E3-9336-497A-AEB8-295E5DF615AD_zpskgraicuq.jpg~original
Also installed some LCA skids from RCI
C534ECD2-E1AE-4DD9-8C1C-922ED61590FC_zpscnjgcurm.jpg~original
