Hella Black Magics = Defiant Light Bar + OEM Switch
bavarian323i
Hella Black Magic 1000s + Defiant Light Bar + OEM Switch
Check it out. I installed a Defiant Short tube with Hella Black Magics 1000's. For the switch I used the FJ Auxiliary Light Switch: PT297-35070-AS with Auxiliary Switch Harness: PT297-35070-SH. Very clean and I think it looks great with the black car. I had these Hellas on another car 15 years ago, so it's great to see them dusted off and back in action!
Looks good. Nice and clean.
Do you have the wiring PDF for using that harness and switch that you can email me?
Nice neat job. BTW Hella has been making light fixtures for the aviation industry for years. Good quality manufacturer. FYI should you ever have the type that use the high intensity replaceable bulbs - don't touch the bulb with your fingers. The oil on your skin will get on the bulb and cause premature failure.
Does anyone have a picture of these with the lights on at night? I really like the look but can't decide on these or a cheaper option from Hella
I could take a picture but its really not worth it. They look a very bright white. There is not tint effect because the black is on the inside of the casing and not the lense itself so they look like any normal hella would look on.
