Aftermarket Projector Housings for 03-05s
lovemybadkitty
Has anyone tried aftermarket projector housings like the ones I have seen at dashzracing? They have the angel eyes halo rings, blacked out and projectors for both low and high beams. I know they may not be legal but not asking about the legality just the build quality. I have seen them at other sites also. Cost about 200 or so us $.:frog:
Some members have them and like them, others think their crap. It all depends on your definition of quality. Personally I'd buy a pair if they where just projectors w/ halo rings but all those other LEDs make them look a bit cheesy in my opinion. Bottom line, don't expect OEM quality but if you like the look then pick up a pair. Also search around for the best price because these lights are all over ebay and other online stores
EDIT: For example heres a pair (http://www.ebay.ca/itm/2003-2005-TO...ccessories&hash=item1c2d25b64d&vxp=mtr&_uhb=1) for 125 with free shipping.
Keep in mind that the optics of the projector are going to be no where near as good as OEM or aftermarket TRS projector setups. I have a small headlight modification business (Headlight Hookup) and have compared several of these type of chinese lights directly to my projector retrofits. The output is not worth the "upgrade" IMO - your better off getting OEM projector headlights or doing a retrofit on your stockers.
Cheers
Personally, I would take the OEM and modify them. I wanted halos but not the cheesy ebay ones so i just custom did mine.
I left the OEM projector as i felt it was more than adequate with the Morimoto 55w kit from TRS.
Do you have a write up or anything on that mod? Where did you get the parts for the Halo?
I ordered the Halos for around 65$ from TRS and to install them you just go as if you were blacking the crome in the headlight out. But just drill a hole at the bottom of the shroud type thing for the wires and glue it in place and wire them into the parking lights or through a switch. If you need i can make a video and try to explain what i did. Just let me know
I wish I had the time and the talent involved in the do it yourself retro,blackout,halo ring projects. I have watched youtube videos and they have vacuum machines and such and cut this and that off to make fit. Just looking for a easier way then the DIY. You guys with photos, nice job!
Little older thread but for anyone looking contact Rickashay, a few posts above. As far as I'm concerned he's the man for projector retrofits. He did mine and does outstanding work, and can build a CUSTOM set for you.
could you show us pics?...is it pnp?...not everyone has the skills for this project
how much did it set u back?
Has anyone tried ...They have the angel eyes halo rings, blacked out and projectors for both low and high beams...
T4r is not a BMW! Dont put halo's on it. Plain and simple. Buy BMW if you want to put halos on something. Look, I did..:boink:
Right before I M-swapped the interior, suspension and drivetrain.
Do your own, just get a used or broken headlight to practice first, then do it to your own lights. All you need is a dremel and some jbstick to hold the projector in, then nut and bolts and jbweld for permenant install, this will take 2 days for first timers to get an idea on how its done. You can view my own personal retrofit thread and it gives you some idea on what i needed to do on 06-09 halogen projectors.
