direct drop in switches?
I don't KNOW one way or the other but SOUNDS like they fit. The "face surface size" dimension listed matches one of my factory switches: 39mm X 21mm.
If you find they DO fit please post back. It would be a help to those looking to install factory looking switches. I know I paid a considerable bit for several toyota factory switches.
I have the led light bar switch and the reverse light switch and I am very happy. They fit like oem and come with a harness so wiring them up is easy.
So I did end up buying some switches, just got them in and they fit perfectly in the factory slots. Still need to wire them up but here is a pic
May use one for the VSC/TRAC off mod when I get around to it... I didn't see any "LED Light bar" switch as talked about previously.
Found mine on e bay. My truck is in the shop due to a hard hit off road last weekend, hoping to have it back early next week and will take some pics.
my first switch I used for my fog lights was the rocker one from otrattw and I didn't like that it didn't look factory
