Bad cv joint or front differential?
rex66m
Hello all. New to the forum - just bought an 06 4x4 v6...love it (takes me back to my fj80 days). Seems to have a loose front drivers side axle (specifically where it enters the differential). Had it in for an oil change and they seemed to think I need a new front differential (yikes) as opposed to an cv shaft. It also seems to grind a bit when turning hard left. Any thoughts and comments are appreciated, Thanks
- rex in bham
There is a needle bearing that rides directly on the CV shaft. If the shaft is worn, replace it. If the bearing is trashed, get it out and put a new bearing in. I have a hard time believing that a bushing would be better than a bearing, especially since the shaft turns constantly. I wouldn't do it. Getting the shaft out of the diff is easy (remove lower ball joint bolts, stabilizer bar, pry out shaft) the bearing can be accessed once the shaft is out.
Some play seems to be common. The shaft could be worn. The only way to tell whats wrong is to pull the axle.
The bushing i referd to is made out of the same material as a crank bearing or rod bearing. So if its good enough for that why wouldnt it be good enough for the axle?
