Thread Tools Rating: Thread Rating: 5 votes, 3.80 average. Display Modes
Old 05-07-2014, 09:53 PM #1
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
Arrow *** V6 Head Gasket Action Request ***
I know this has been discussed a lot and I really don't want to start a thread about anything other than a simple survey of those that have had to have their head gasket replaced. If you are looking for info do a search and there is plenty of threads. I am just curious if there is any similarities and would like to put the information together once enough is complied.
Thanks!
Please post info as follows:
Year
Production Date
4x4 or 4x2
Mileage of failure
Cylinder # that leaked
*** FYI UPDATE ***
Thanks to momo.75 this thread has been combined with NuclearN8's. Great links and info can be found on pg. 5 POST #61.
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
Old 05-09-2014, 01:26 AM #2
jake87toy jake87toy is offline
jake87toy is on a distinguished road
2004
06/04
4x4
120k
2004 Limited V6 4x4 - FJ / Bilstein 5100 - 265/65r17 Grabber at2 - Eagle Alloy 050 series ***Future plans: Gibson cat back - Tint - Projector retrofit - Satoshi??
jake87toy is offline   Reply With QuoteReply With Quote
Old 05-09-2014, 08:07 AM #3
MikeInNH MikeInNH is offline
MikeInNH is on a distinguished road
I've never had the problem. 05 V6 with over 260k miles.
The BIGGEST problem with Aluminum engines is not letting it overheat. That is by far the biggest cause of head gasket failures. Probably 99% of all head gasket failures on Aluminum engines is due to engine over heating. Over heat just ONCE and you could have a head gasket failure.
Besides the life time Tranny fluid...I'm NOT a big fan of leaving coolant in the radiator for 4 years. I change mine out every other year. It's very very very cheap insurance of having a head gasket failure.
MikeInNH is offline   Reply With QuoteReply With Quote
Old 05-09-2014, 09:29 AM #4
Runner27's Avatar
Runner27 Runner27 is offline
Runner27 is on a distinguished road
Runner27's Avatar
Do you get your coolant from the toyota dealer or just use a general coolant from auto shop? I realize that there's a difference in color (orange vs. pink) but not sure if that really matter.
2006 SR5 4WD: Icon stage 1; Baja Designs Lapaz; 265/65/17 BFG Rugged terrain; 2x 18w LED; Scion FRS display radio.
Runner27 is offline   Reply With QuoteReply With Quote
Old 05-09-2014, 12:43 PM #5
I buy Zerex Asian formula. It's designed for Toyota engines (and several Asian engines).
I NEVER buy something like that from the dealer. The coolant from Toyota is made for them by one of the 3-4 coolant manufacturers. Probably Zerex.
Old 05-09-2014, 02:41 PM #6
Sungod Sungod is offline
Sungod is on a distinguished road
My neighbor just traded in his 2004 2wd Limited with low compression on #6. He had 180K.
Sungod is offline   Reply With QuoteReply With Quote
Old 05-16-2014, 10:36 PM #7
morphious's Avatar
Real Name: John
morphious's Avatar
Real Name: John
With about 280 views and 1 member and a members neighbor that is a possible, not seeming like an epidemic at this point.
Old 05-21-2014, 12:36 PM #8
Mine is in the shop currently getting both head gaskets replaced. I wouldn't call it an epidemic either by any means, but I also would not ignore the fact that it is happening to people. Google search "P0306 Toyota 4.0" and read through a few. If are researching prior to a purchase, I would advise making sure you start the vehicle from a cold start in the morning and confirm that it runs smooth immediately. Toyota quotes this job at $2500-3200 and that is a very heavy expense for some.
Old 05-23-2014, 12:23 AM #9
Calimander Calimander is offline
Calimander is on a distinguished road
I agree with Jake, this is an issue that should be taken into consideration to anyone considering buying a used 4Th gen 4runner. Make sure you're not buying someone else's problem. 05 V6--Head gasket went at 93k--never overheated ----Cylinder #6
Calimander is offline   Reply With QuoteReply With Quote
Old 05-23-2014, 11:16 AM #10
j-dub j-dub is offline
j-dub is on a distinguished road
2006 v6 2wd
152k
no head gasket issues
j-dub is offline   Reply With QuoteReply With Quote
Old 05-23-2014, 01:23 PM #11
birdmann birdmann is offline
birdmann is on a distinguished road
2007 4wd 105,000 no issues. Never been overheated.
'07 sr5 4x4 4.0
birdmann is offline   Reply With QuoteReply With Quote
Old 05-23-2014, 07:57 PM #12
wnelax04sr5's Avatar
wnelax04sr5 wnelax04sr5 is offline
Real Name: Ethan
wnelax04sr5 is on a distinguished road
Real Name: Ethan
2004
4x4
121xxx
I've never overheated it, owned it since 94k, no issues
A lot of stuff I didn't need...
My Build
Originally Posted by kfitz77555 View Post
oh my god the erection I have from this thread is unreal.
wnelax04sr5 is offline   Reply With QuoteReply With Quote
Old 05-24-2014, 03:34 AM #13
kao kao is offline
kao is on a distinguished road
kao kao is offline
2004
05/04
4x4
120k
Changed coolant at 100k as vendor recommends.
Radiator leaking preceded headgasket problem. But never overheating it.
Changed radiator in January and headgaskets in March)))
And i am not alone in my city.
Also there are many similiar problem with 1gr on tlc prado 2004
4runner 2004 Sport Edition
FJC spring/KYB
kao is offline   Reply With QuoteReply With Quote
Old 05-28-2014, 09:48 PM #14
SharonKR SharonKR is offline
SharonKR is on a distinguished road
2004
4x2
137thousand miles
SharonKR is offline   Reply With QuoteReply With Quote
Old 05-29-2014, 01:17 AM #15
JEL's Avatar
JEL JEL is offline
JEL is on a distinguished road
JEL JEL is offline
JEL's Avatar
Looks like a lot of problems occur on pre-06. Was there an update/redesign for the facelifts? I realize it could be down to age and mileage. but there have to be plenty of 06+ with just as many miles as earlier rigs by now...
5th gen inbound
JEL is offline   Reply With QuoteReply With Quote
***Cracked Dashboard Action Request*** momo.75 4th Gen T4Rs 1582 08-10-2023 09:37 AM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
4th Gen HEAD GASKET (ACTION REQUEST!) Kshino 4th Gen T4Rs 2 09-12-2018 11:36 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
