XREAS shocks rusting badly
T.Rock
Banned
I'm the original owner of a 2004 Sport Edition with only 61,000 miles on it. It has been virtually trouble-free for the 10 years that I've owned it, other than dealing with frozen pistons in the front calipers (yes, I know that's a common issue). Anyway, I've noticed that the rear XREAS shocks are starting to rust badly on both sides. I think it may be time to replace them.
Here's the question: My 4Runner is basically stock. I do have a small 1" leveling lift up front. I want to replace my XREAS shocks with something that will give me comparable ride quality to the stock set-up. I'm not really interested in swapping coils (no Moog or FJ coils for me). I just want to find a replacement shock that will give me similar ride quality to the XREAS system.
Anyone have advice?
When my XREAS failed on my 03 Limited (due to corrosion of the lines between the shocks and a loss of fluid), I considered two options.
First option was to replace the XREAS - this option was very costly and I decided against it. Being a closed system makes it very challenging to repair/replace the original suspension.
Second option was to remove XREAS and replace with the basic SR5 suspension. Much more cost effective. This was the option I chose.
I did not want to lift, install aftermarket coils and what not. Just wanted it pretty much stock.
While the XREAS is a great suspension system in principle, when it fails it affects all four corners. The SR5 suspension has worked out just fine for me.
So you went to the Toyota dealer and purchased OEM shocks for the SR5? That might be a good option, but did the dealer gouge you on the shocks?
Also, how much different did the vehicle ride and handle? Did you notice a lot more body lean while corning or turning?
Yes, I did go through my local Toyota dealership at the time, and my mechanic recommended the SR5 suspension. I trust my mechanic (who has since opened up his own shop with a much cheaper labour rate).
I likely did pay a little more at the dealership for OEM parts, rather than sourcing some aftermarket parts. If I had to do it again, I might have gone aftermarket just to save some cash. You pay a lot for the Toyota name on parts. Quality parts are certainly available from other sources.
Ride quality is good (I also have the rear air suspension) on the SR5 suspension. I can't say that I really noticed that much difference from the XREAS.
I do like to push the edge when cornering, and the standard suspension handles just fine in my opinion. It is a big vehicle and does not hug the road like a sports car in the corners (or highway on/off ramps). But body lean seems manageable with sensible driving on the standard suspension.
My first own 2003 sport. 2wd V8 was hit hard the sides and back end. The sport had XREAS syspension. We it was totaled its engine now lives in #2 an SR5 w/o XReas. There is no better system for ride and comfort.
