Billynath1988
Billynath1988's 2005 SE V8 Build Thread
Thought it was time to start the build thread. Not only to share my truck and the experiences I have with everyone here but to keep a record of all the mods and repairs I've done over time.
Updated (September 19th 2025)@ 171,750 miles
Routine Maintenance
Oil changed November 7th, 2024@ 170,400k
Greased driveline with Redline CV2 November 15th 2023 @ 167,800
Full frame Fluid Film treatment December 15th 2024 @ 168,800
Rotated Tires April 24th 2023 @ 166,500
Rear Diff Fluid Changed April 8, 2021, @161,500
Transfer case fluid changed August 2020 @158,600
Front Diff Fluid change August 2021 @162,000
Changed Cabin Filter September 10th, 2021 @162,350
Alignment - (March 21 2020 157k)
Transmission Drain and fill 12qts Toyota WS fluid ( March 2020 157k)
Driver side CV Reboot 2nd time with SDHQ (Oct '18 144,950k)
Passenger side CV Reboot 2nd time SDHQ (June '19 149,200k)
New Everstart MAXX Battery - ( January '22 164,400k))
Other Maintenance/ Repairs
New OEM starter 11/7/24 170k
New CV axles & Seals 11/7/24 - 170k
Add Grease zerks to UCA bushings April 2023 166500k
New OEM PCV valve (September 2021)
Replaced Rear diff Breather - (Sept 2021)
Disabled rear defroster at the rear window - (Sept 2021)
Replaced Upper Control arm Bushings with JBA HD- (Aug 2021 162k)
Replaced Upper Ball joints with JBA HD - (Aug 2021 162k)
Replace Serp Belt - (August 2021 162k)
Replaced Rear Brakes with Powerstop Rotors Pads (8/2/2020)
Replaced DS rear caliper with advanced lifetime warranty 8/2/2020
Replaced Inner and Outer Tie rods with Sankei 555 (March 2020 157k)
Replaced transfer case output seal (March 2020 157k)
Replace Pass Rear Caliper (January 12th, 2020 156k)
Replaced Airbag Clockspring (Sept 8th, 2019 151k)
Front diff and Fill drain plug changed to Lexus Part (August 2021 162k)
Passenger side Diff Seal changed (June 2019 149k)
New DS hub assembly (Nov 18' 145K)
New OEM Drivers side ABS sensor and Sensor Harness (Oct 2018)
New Exhaust spring joint bolt kit (Sept 2018)
New Driver's seat Bottom Foam OEM ( August 2018)
Brake Fluid flush (July 2018 142k)
New OEM thermostat (May 2018)
A coolant flush and replace with OEM Toyota coolant (May 2018)
Bosch ICON wipers (December 2017)
New OEM genuine Toyota LCA's and cam bolts (July 2017)
Front Diff DS axle seal changed (May 2017)
Fuel pressure pulse regulator (April 2017)
New tires installed @ (162,100 August 2021 163k)
New Dashboard from Toyota (April 2016)
Tires & Wheels
New- 255/85/17 Mickey Thompson Baja Boss AT
2021 Genuine TRD SEMA edition Gloss gunmetal wheels (Aug 2021 162k)
4 -1.25" Spider Trax wheel spacers (Sept 2017)
Brakes
5th Gen Stoptech severe-duty front calipers, Rotors pads- Aug 2018 142k
4th gen PowerStop rear Rotors and pads - Aug 2020 158k
Braided stainless brake lines upfront
Extended Braided stainless lines Upper rear Metal tech - Aug 2018
Suspension & Steering
JBA High Caster Ball Joint Upper control arms painted silver
Radflo 2.5 ext travel Coilover with remote Resi's and 700# springs (overland warehouse valving)
Radflo 2.5 ext travel rear shock - New upper bushings 5/28/18
Metaltech HD Long travel Rear springs
*FJ Rear sway bar- * Skyjacker Extended rear sway bar links -New rear sway bar end link bushings 5/28/18
Front sway bar delete*
Sankei 555 Inner and outer tie rods
Energy suspension Poly rear sway bar bushings
(replaced lower Coil-over spacer bushings April 2017)
New OEM Genuine Toyota LCA's and cam bolts (July 2017)
Metal Tech 3 inch rear Bump stops (April 2018)
DuroBump extended front Bump stops (September 2019)
DesertDoesIt Seat Jackers for front Drivers Seat (August 2021)
DuroBump Extended Rear bump stops ( August 2021)
Drivetrain
NAPA HD axles
Redline CV-2 Grease
Front Diff fluid 75w-90 Redline ShockProof HD - (August 2021 162,000)
Rear diff oil change 75w90 Redline Shockproof HD -(April 8th, 2021 161,500)
Transmission Drain and fill ( March 2020 157k)
Transfer case fluid Mobile 1 synthetic 75w90 DEVLAC (Aug 2020 158,600k)
Rear Diff Breather extension to the gas filler
Fumoto Oil drain Valve with a hose extension
NJN636 front Wheel Hub bearings
Engine/Performance
Stock 4.7L V8 VVT-I
Gibson Catback Stainless Exhaust
Slyfox SAI pump relay fix
AFE Pro Dry S Filter (Sept 2018)
Denso Laser Iridium Spark Plugs
Denso downstream 02 sensors
New PCV valve (September 2021)
Silver Rhino Washer Relocation Kit - (Aug 2021)
Armor
BAMF Rock Sliders Coated with Herculiner Bed Liner
Bud built Skids- Front, Mid, Trans- coated with Herculiner
FJTOYMAN - Lower Rear Shock Skids with bolt protectors
Allpro Offroad - Lower Link Skids
Exterior
Detours of Maine Tire Carrier- April 2022
New Style TRD Pro Grill
06+ Led tail lights
Black bezel Headlight Housings
Auto vent shade Rain guards
Plasti Dip upper & lower grill
Plasti Dip rear bumper plastic trim
TRD rear quarter decal
CBI ditch light brackets
Rola Roof rack- installed for trips
Lighting
Xenon Depot LED PRO 9006 low beams
Rigid D2 Driving Lights
Rigid D2 Yellow light covers
Rigid Dually Spots on CBI ditch light brackets
Rigid Dually Flood in 3d Printed inserts stock location
Sylvania ZXE bulbs hi beams
LED License Plate Bulbs
LED interior bulbs
LED DRL and turn signal
LUYED ultra-bright LED reverse lights
LED Amber marker lights
LED Amber rear blinkers
Electronics
Air onboard zombie LED light switches in factory switch bank
Toyota OEM smokers kit with extra power Port
Dash Cam with Reverse Camera in review mirror monitor
________________________________________________________
How I got involved in a 4Runner:
I sold my 1996 Chevy Impala ss with 101k in August 2012 in as clean as they come condition for 11,000$. I needed something newer and more useful since the impala was my car since I was 19. I spent blood sweat and tears keeping that thing clean-running and looking perfect and now to replace that I needed something to fill the void.
I test drove a handful of cars, trucks, and SUVs in my price range.. under 15000$ and nothing did it for me... I felt like I was holding a pretty high standard for being satisfied driving a vehicle. I wanted something that, holds value, is reliable, and has ample power. Something that gives you more than just the ability to drive around dry highways... which is what I dealt with for 7 years.
I drove a V8 05 4 runner.. and WAS SOLD... I did my research and this is what I ended up with.
August 10th, 2012:
2005 Toyota 4Runner Sport Edition V8 with XREAS, Silver,89k, I am the second owner, Zero Rust anywhere underneath, was garage kept.. dealer-maintained.. came with 1-year free maintenance, New tires, had the windshield replaced.
The minute I got it home 8/10/12:
Offroading: 12/1/18 ( Rausch Creek PA)
As it sits now : Feb/2022
Routine Maintenance
Tires & Wheels
Brakes
Drivetrain
NAPA HD axles
Redline CV-2 Grease
Engine/Performance
Stock 4.7L V8 VVT-I
Armor
Exterior
06+ Led tail lights
Lighting
LED interior bulbs
Electronics
August 10th, 2012:
