Switching from 03 to 06 headlights and had a question about the wiring
momo.75
Registered User
I have looked for a while but can't find the answer i was looking for. I am switching to the 06 headlights and was curious what you guys have done about wiring the turn signals in the headlights to the the turn signals in the bumper. I know i would need to get a plug and bulb for the turn signal in the lights and then tie them into the turn signals in the bumper but can't find a part number for that plug. Anybody have any info or input on this? Thanks in advance.
Morris
I think the part number for the harness needed is 81125-35440 from toyota.
Morris
I know that [MENTION=44862]macoyle[/MENTION] did the switch on his '04 so maybe he might offer some insight.
sorry I dont remember what the part numbers were, they are on the site here somewhere though if you search around. Im sorry I couldn't be more helpful-
Yep, just finished up with the painting a little while ago. I will clear and polish the filler pieces tomorrow. It is really easy and if you take your time to do it right they will turn out fine. I did the same thing with my door handles and trim pieces. Here is a thread on those.
http://www.toyota-4runner.org/4th-gen-t4rs/111684-changing-trim-colors-my-03-a.html
I see, I just ordered mine from Toyota and they are already painted white. Came out to be like $75 shipped to me for both
I was able to find plugs at my local pepboys to hold the turn signal bulb that fit right into the 4runner lights, then just spliced the wires together from the factory turn signal wiring. I believe it was made for a 2006 F150 or something. Lost the box though, so not 100% sure. I think I paid about $6 each, and they were out with the rest of the turn signal bulbs.
1156 for bulb socket and single filament bulb.(signal only, or wire it up as drl only.)
1157 for bulb socket and dual filament bulb.(drl and signal)
i wish they had my color still for 06+ would make life a lot easier.
Sam, you might want to try Touch Up Paint and Accessories | AutomotiveTouchup or Automotive Touch Up Paint from PaintScratch - Order Pro Grade Paint. I have never used them but heard some people have had good luck with them
Thanks guys!
I've been researching this swap and pretty much any of the stores that sell OEM will give you the parts numbers and diagrams needed to get everything right the first time. When its all said and done its just pricey as a mofo as in the $500-$600 range. This makes me rethink it and just go with a DOT/SAE approved pair of bumper lights by either Rigid or PIAA.
im going to buy a can or two for the filler plates and see how well they match. May end up shooting the fenders too just to get them somewhat matching.
I saw a Cherokee today that had some aftermarket fender flares on it. They were matte black and they didn't look bad next to the gold paint. you could PD the new fenders black or gray to tone them down until you get them painted.
INTERESTED!......THIS SHOULD BE EASIER ON THE WALLET than a retrofit. [MENTION=56924]mom[/MENTION]o pls give us total cost for this
