My "Fun DD" Build Thread
9civichatch3
9civichatch3 "Fun DD" Build Thread
Hello,
I have a '06 Galactic Gray Mica 4Runner SR5. We purchased it in '09 for my wife with 30k. It now has 72k. I recently traded in my Tacoma for her '11 Sequoia so I took the 4Runner (paid off, Tacoma was not). I have always like the 4Runner.
So Far:
-Front: Bilstein 5100 w/ OME 855 Springs
-Rear: Bilstein 5100 w/Toytec Superflex Springs
-Spridertrax 1.25" Spacers All Around
-265/70/17 General Grabber AT2
-K&N Drop-In w/ Charcoal Delete
-Remove/Trim Mudflaps
-Remove Running Boards
-OEM Color Matched Front Grille
-OEM All Season Mats
Feel free to comment. Open to suggestion etc..
The day we got her Sept 2010
Skip 4.5 years. I drive it now. Getting new tires.
Removed running boards and trim/remove mudflaps
My #1 Helper
Bilstein 5100 and OME 10mm spacers have arrived
Most Recent Pic: Nov 2015
So I had the passenger caliper replaced due to leaking last year to 18months ago.
I had new tires installed last week and the front 2 wheels would not move freely. We had to rotate with force for them to move. Wonder if that is a sign of frozen calipers?? Now the rotors are warped due to abnormal high heat.
I have a appt at the Stealership Thursday. Only a few months left on my 5yr/100k warrenty.
Progress:
K&N Drop-In w/ Charcoal Delete - Installed 2010
265/70/17 General Grabber AT2 - Installed 1/09/2015
Remove/Trim Mudflaps - Removed/Trimmed 1/10/2015
Remove Running Boards - Removed 1/10/2015
Bilstein 5100 Fronts @ 2.5" - Installing Today!
OME 10mm Rear Spacers - Installing 1/18/15
I installed the 5100 Fronts tonight. The install went smooth. It took about 2.5hrs total not rushing. Should get to the OME Trim Packers tomorrow. I have only done leaf springs. Need to do watch a video on rear spring removal.
Results:
Both Fronts Before - 18.5" from middle of center cap to fender (+/- 1/8")
Both Fronts After - 21.25" from middle of center cap to fender (+/- 1/8")
Unboxing..
Compressing the spring/Cleaning stuff
All together :whoo:
needed help pressing down the suspension to get the strut back in so I rigged up a knee press. It actually worked great.
Back In
All Done with the Front
There is a severe lack of Double D's in this thread, let alone fun ones; I am angered by this false advertising!
The 4Runner is a mild consolation for my nerd rage, it is prettyful.
Took it to the Dealership and it needs the following:
Warranty
-L/R Front Calipers
-L/R Swaybar Endlinks
-L/R Lower Control Arms (balljoints)
My Pocket
-Pads
-Rotors
liked the way you engineered the board to the lower a-arm! I'll be using that method soon, the last time I adjusted my 5100s it was a pain to get that lower mount in and I think that will do the trick
I heard from the dealership today. The warranty adjuster agreed the following:
Replace front calipers
Replace front swaybar endlinks
Replace front lower control arms
Flush brake fluid
Front end alighnment
Cost:
$100 deductable
$120 resurface rotors (pads look fine)
Very nice, i like that the subtle mods make such an improvement over stock. This is a very capable truck. Now I just have to remove my running boards like you did...
