Thread Tools Rating: Thread Rating: 5 votes, 3.80 average. Display Modes
Old 02-10-2015, 09:38 AM #61
NuclearN8's Avatar
NuclearN8 NuclearN8 is offline
NuclearN8 is on a distinguished road
NuclearN8's Avatar
*** V6 Head Gasket Information Thread ***
I created this thread to keep track of all V6 head gasket failure (and related) discussion threads on this forum (and others) to allow people to draw their own conclusions on the topic.
So here's what I've collected....
General 1GR-FE info
Head gasket failures are reported across multiple forums for the 1GR-FE V6 engine (4Runners, Tacomas and FJ Cruisers all use this engine)
This Forum (several DIY HG replacement threads toward the bottom which are great):
Head Gasket -Survey- Specifically V6
1GRE- FE head gasket was redesigned when?
2004 Limited Edition 4Runner 4X4 - Head Gasket
Preventing Blown Head Gaskets on v6?
New member - need help!!!! - p304 misfire
Head gasket issue for 2004 4runner V6 (a thousand time)?
P0306 Misfire Rough Idle
T120:
Head Gasket Blown - 2004 V6 - Toyota 120 Platforms
Forum
TW:
1GR-FE Head Gasket Failing - Options - Tacoma World Forums
TN:
Head gasket question - Toyota Nation Forum : Toyota Car and Truck Forums
'05 4.0 Liter Head Gasket Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Expedition Portal:
Repair advice? Blown head gasket on 4th Gen 4Runner? - Expedition Portal
Pirate 4x4:
Blew a head gasket on my 4.0 (long rant) - Pirate4x4.Com : 4x4 and Off-Road Forum
Toyota VIN decoding
Total 4Runner Sales Info:
Toyota 4Runner Sales Figures - GOOD CAR BAD CAR
Toyota 4Runner - Wikipedia, the free encyclopedia
Head Gasket production information from this site: 2005 Toyota 4Runner 11-04 Cylinder Head Parts
(It appears the phase in of the new head gaskets for production purposes started in August 2005 and ended in November 2005, anything after November 2005 seems to be assured of having the new head gasket installed at the factory)
V6 exploded View link from same site:
ILLUST NO. 1 OF 2 ----- (0211- )1GRFE
If you've experienced a failed head gasket, please reply with your
Model year
Mileage at failure
Cylinder,
Production Date (on driver door jamb sticker),
11th digit of VIN (This denotes the plant of manufacture from link above) (0=Tahara, 8 or 9 = Hino or K = Japan)
EIN (Engine Identification Number) Is found on rear passenger side stamped into engine (next to VIN plate on engine).
I will update the attached file periodically as members share the above information concerning their head gasket failure. Hopefully, we can then use this information to see if there are any correlations between EIN serial number and/or vehicle production facility with the reported failures.
Also attached is a troubleshooting and diagnosis procedure I found that may be useful for cylinder misfire codes on the 1GR-FE engine.
NuclearN8 is offline   Reply With QuoteReply With Quote
Old 02-10-2015, 11:58 AM #62
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
Sounds good, my most up to date tracker is attached.
*** V6 Head Gasket Action Request ***-screenshot_1-png
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
Old 02-11-2015, 05:04 PM #63
NuclearN8's Avatar
NuclearN8's Avatar
@ecally @Greydog @boostaddict89 @mtn_rooster @PNWSportEd @thebitz1 @Calimander @KMG1981 @ChalkOutline @thefatcat @bobdod04 @lifesaver71 @run4estrunner @bme75 @Mark3850 @BIGA1969 @anthonyhkim @Jerrydog @WillRunner05 @jake87toy @kao @SharonKR @BToyota @VACJ7 @nysimonsez @Jeff S. @Cornelius @vinnie febs @thatguy1988 @thewizard @nossliw @Wishbone @TracyScram @smcdowell @cah283 @i65south @savants @scottb @BenSD
If you still own the 4Runner and you're willing to share, please reply with the missing data about your head gasket failure
Model year
Mileage at failure
Cylinder,
11th digit of VIN (This denotes the plant of manufacture from link above) (0=Tahara, 8 or 9 = Hino)
Old 02-13-2015, 05:15 PM #64
nossliw nossliw is offline
nossliw is on a distinguished road
What is the end game here? And are you requesting replies by PM or so the general public can see it all. Just was wondering.
nossliw is offline   Reply With QuoteReply With Quote
Old 02-13-2015, 09:20 PM #65
NuclearN8's Avatar
NuclearN8's Avatar
My end game is to collect the data, enough at least to analyze it in an objective manner and present it here in a consolidated manner. (since no such thread exists yet that I have found on any forum)
A simple reply in the thread works for me... the data will be in the attached pdf file in the first post anyway... but if you feel more comfortable with a PM, works too.
From the data I've collected to date, I'm not convinced there is an issue at all.... I mean if 03-05 are allegedly the trouble years for the 1GR-FE in 4Runners,how come no 2003's have been reported as failed? It seems awfully weird, right?... The HG changes doesn't mean anything in my eyes... logistic supply chains and suppliers change all the time, it's just part of doing business in large scale and quantities.
I believe the 1GR-FE is a very reliable engine based on the numbers... I'm not sure how to draw any other conclusion based on the total sales numbers and number of failures reported... I mean .. in 2004, conservatively assuming 1/2 the 4runners sold were V6's this means with the failures reported on this site that's less than .01%, all of which were out of warranty at the time of failure. Even if there are 10 times more that have failed that aren't reported... that's still not .1% of total sales (assuming 50% of sales were V6's, probably more like 60-70%).
My end goal is the follow the numbers, numbers don't lie.
Old 02-16-2015, 05:03 PM #66
morphious's Avatar
Real Name: John
morphious's Avatar
Real Name: John
Combined tracker in alphabetical order update.
*** V6 Head Gasket Action Request ***-screenshot_3-png
Old 02-16-2015, 05:06 PM #67
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
Wow. That list is scary long. I priced a head gasket job on mine today because I have a 2004 and I'm not lucky enough to dodge that bullet for very long. I wanted to plan ahead. I found a trusted independent job to do it for $2300.
I had no idea the list was that long.
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 02-18-2015, 03:47 PM #68
lifesaver71 lifesaver71 is offline
lifesaver71 is on a distinguished road
Add this info
Production date 10/04
Cylinder 6
0-Tahara
Also notice the abundance of 4 and 6 as the problem. Photos posted of others gasket failure and my gasket failure are virtually identical. The gasket fails in the area between the 4 and 6 cylinder.
2005 T4R SR5 4X4 V6 Natural White 230k miles
2008 Scion xB Super White 160k miles
lifesaver71 is offline   Reply With QuoteReply With Quote
Old 02-18-2015, 04:35 PM #69
morphious's Avatar
Real Name: John
morphious's Avatar
Real Name: John
@lifesaver71 you are on the list, is the information I am adding for "0-Tahara"? If so, do you have a current mileage and 2 or 4wd? Thanks.
Old 02-18-2015, 05:48 PM #70
NuclearN8's Avatar
NuclearN8's Avatar
he was just supplying the additional information for his failure I requested... the 0-Tahara was the production plant for his vehicle....
Old 02-20-2015, 10:08 AM #71
thebitz1 thebitz1 is offline
thebitz1 is on a distinguished road
head gasket
2006 Sport 4Runner was a 4WD. Sold
Unsure which cylinder was affected, but both head gaskets were replaced under warranty.
2003 Limited 4WD V6, Black, 41K miles
1999 Limited 4WD V6, Silver, 122K miles - SOLD (tired of the suspension issue)
2006 Sport 4WD V6, Silver - SOLD
thebitz1 is offline   Reply With QuoteReply With Quote
Old 02-20-2015, 10:59 AM #72
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
2003 Limited 2WD
210,000 mi
Cylinder 6
04/2003
Tahara
Don't know EIN
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 02-20-2015, 11:45 AM #73
NuclearN8's Avatar
NuclearN8's Avatar
thanks guys. updated the HGData pdf file in the first post with the info you supplied
Old 02-20-2015, 01:18 PM #74
morphious's Avatar
Real Name: John
morphious's Avatar
Real Name: John
Update.
Old 02-22-2015, 12:59 PM #75
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
Tagging for future reference. Thanks
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
***Cracked Dashboard Action Request*** momo.75 4th Gen T4Rs 1582 08-10-2023 09:37 AM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
4th Gen HEAD GASKET (ACTION REQUEST!) Kshino 4th Gen T4Rs 2 09-12-2018 11:36 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
