5th Gen Calipers
Update:
Right rear aft parking brake shoe retaining pin was somehow bent. This allowed the shoe to not be retracted far enough (even with the adjuster at full contraction).
So I'll order that up. In the mean time I've removed the majority of the components in there and zip tied them secure and I'll be without a parking brake until I get the parts.
Then torquing the last bolt on the last wheel. . . broke the stud. So add that to the list of fun things I get to do this week.
What a nightmare this has been.
BUT! The braking is improved! I need to bleed the fronts again as the pedal is still somewhat soft in the first 1-2" of travel.
Hand check each lug nuts mine was out of pitch and causing each one to snap. Either that or.replace.all youe wheel studs. Exactly happened to me . on mobile report back tomorrow with more comments
Anybody else's centric non-painted calipers starting to rust? I put them on in late August and they're rusting already. I really don't feel like pulling them off just to paint but I also don't want them turning rusty either.
Bleh. Buying painted calipers next time.
Yep, did mine in September and they are covered in a nice coat of orange surface rust now. I wish I would have painted them before the install but oh well. I'll paint them one day but it's pretty far down my "need to do"list at this point. I'll take the performance of the rusty calipers over the old 4th gen calipers any day.
16 in wheels: what options for caliper upgrades
I was all excited to do the 5th gen caliper upgrade. I now see that it does not work on my sr5 with 16 in wheels? What are other options,if any?
Thanks for the help
17" wheels are your only option other than going with the same 4th gen calipers again. 5th gen calipers won't clear the wheel or will be dangerously close to it.
Take a look through the classifieds or Craigslist. I see people upgrading their wheels all the time. I've seen stock 17" toyota 4th gen wheels with decent half used tires for as low as $200 for a set of 4.
Good timing if you are planning on getting new tires anytime soon, just upgrade the rims. Don't forget the spare.
I just started noticing a burning smell after driving my 05 SR5; it's a distinctive smell - almost like a metal or electrical burn. Turns out my front calipers are starting to seize or already seizing.
I plan on replacing my brake set up with the following:
Calipers: OEM 5th gen for all 4 corners
Rotors: 5th gen centric rotors for all 4 corners?
Pads: OEM pads
Lines: stainless steel - need ideas
I have an 05 SR5, with the standard rims (265/65r17) - will I have any clearance issues w/ the 5th gen rotors and the oem rims?
I am either thinking of the following for rotors:
http://www.amazon.com/dp/B004HEICVO...TF8&colid=38J5HV5R32OSP&coliid=I3HAAECXAEJWH4
or
http://www.amazon.com/dp/B005FL6M6A...TF8&colid=38J5HV5R32OSP&coliid=I2MHDQ15CWD4YA
So I guess what I am trying to ask is will this set up work for my T4R?
I've read some credible reports that claim that slotted and drilled rotors don't improve brake performance. The assertions that I read stated that the slots and drilling were to allow gases to escape from the pads as they heated up.
However, modern high performance pads (such as akebono ceramic brake pads) have newer technologies that don't give off much gas. Thus, heat dissipation becomes a major concern in brake performance, and more rotor surface area in contact with the pads and more mass of the rotor allows for better, faster heat transfer, and improved cooling.
Slotted rotors can have some advantages, but they are not major and they tend to wear brake pads faster.
See this thread for some opinions on the subject...
The logic makes sense to me.
Just an FYI.
-Phil
Well this is finally done! Couple words of wisdom:
I went with the G4 Caliper Paint system to try and apply some rust deterrence before install. Easy system and there's a LOT more paint there. I got 3 light coats on all 4 of the new calipers and there was several ounces of product remaining.
Make damn damn damn sure the parking brakes are FULLY released before attempting to remove the rear rotors. My right rear was not and I bent the shoe retaining spring pin (picture below) and make for one hell of a troubleshooting episode.
My old rotors popped off with ease but I was prepared with several different devices to get them off. Surprised with how easy they came off.
I went with the Centric products already listed in this thread. 5th Gen Calipers and Rotors all the way around. Found a deal on Hawk LTS pads on Amazon and pulled the trigger.
The braking action is superior. Now. . if that's because of the bigger calipers/rotors or aftermarket pads? Who knows. But I am confident I will enjoy stopping my 6500lb boat much more than previous years.
Should have been an easy 4 hour job. Turned into a few days with that damn parking brake. What a retarded design. I nearly just removed the whole thing. Finally got it working with the new hardware.
Well the clicking returned from the rears. . but only in reverse. I am taking it in to my local shop tomorrow to help diagnose. I STILL think it's coming from the parking brake assembly. . . but sure hope there isn't something wrong with the hub flange.
when the weather gets warmer here I think Ill do proper video on how to do it.
it took me 3-4 weekends to figure it out. I left my car on jacks for 4 weekends. when i finally got it right. where it held, on both sides, I was putting back together and my lug nut snaped for the 2nd time. I wanted smash the brakes to pieces. I had to engage the parking brake when at 5mph a few times. It clicked and everything snapped into place and no more touching noise. (I assumed it seated itself correctly)
Once I got it right it, it held in drive reverse on flat surface, and in nutrual on a steep incline.
I gave up on taking the car apart again. I found out it was the lug nut that was causing the stud to brake. anyway, i had mechanic upgrade to 5th gen calipers and redo all the studs. I bought a new parking brake (Cheapo one)
anyway when he did, it does not hold in reverse at all. So i know the trailing shoe is not releasing properly. granted it could crappy rebestos brakes.
in any case in the spring when i go in there and reset the parking brake I think I should do a proper video.
also do yourself a favor and get new hardware kit. the one I got from autozone was good enough for me. You can test it to make sure both sides engage (use it to replace the springs only!, keep the rest of it OE)
I've been buying new calipers, rotors, pads, and ss lines for the past 2 months - I think I am almost done!
I bought the reman centric calipers, new centric rotors, and oem toyota pads - all for the 5th gen.
I've seen a few people talk about hardware kits - what are included in them? My pads only came with the pads and that's it. I still need shims? Anything else?
Also - should I paint the calipers? I bought the g2 caliper kit from amazon to try but these look like they're already painted?
Brakes
Brakes
which centric kit did you buy? 142 series = new pistons and painted loaded with crapy brake pads as well, ignore those.
you should just need the shims with the pads. it comes with new hardware. I'd also get copper anti seize to put anywhere the caliper meets the pads.
The hardest thing about this job is the parking brake. Probably needs adjusting if you haven't touched it in a while. Once you are done it should hold in neutral if you on a steep hill facing both ways. if only holds one way, chances are you need to change out the top 2 springs
Part numbers are here guys
From Rockauto
Calipers:
141.44587
141.44588
141.44287
141.44288
Rear Caliper Brake Flex Hose Stainless Steel Numbers:
950.44507
From All-Pro
Front Caliper Brake Flex Hose Stainless Steel Numbers:
5500FJT-AP-F x 2
Rear Axle Brake Flex Hose Stainless Steel Numbers:
5500FJ-AP x 2
Enjoy!
This may be a dumb question.. But do you need 2 rear caliper brake hoses? Just want to double check. 2 axle hoses?
Brakes
If you didn't get the 142.xxxx calipers (which are prepainted), then you should definitely paint them.
I just finished painting my calipers using the G2 paint system.
I also ordered stainless steel speed bleeders for when i reinstall the brakes.
I tried the regular ones that are made of brass, but i broke them all off... They were hard to screw in, and I couldn't tell when they were seated. I hope the stainless ones perform better. I'll also be very careful not to over tighten them.
Photos of paint job are here. ImageUploadedByTapatalk1456130797.667296.jpgImageUploadedByTapatalk1456130844.702827.jpgImageUploadedByTapatalk1456130900.724325.jpg
Now i have to let em dry and wait for my speed bleeders to arrive.
Here are the speed bleeder part numbers I ordered. I'm getting the stainless steel because i broke off all of the brass ones i had previously ordered.
www.speedbleeder.com
Order Contents. -- these are supposed to fit the 4Runner 4th and 5th gen calipers.
DESCPRICEQTYEXT
Sku: SB1010SS
SB1010-SS Speed Bleederx $15.002= $30.00
Sku: SB7100SS
SB7100-SS Speed Bleederx $152= $30.00
Sku: DUSTCAP
Extra Dust Capx $0.102= $0.20
Subtotal:$60.20
Sales Tax:$0.00
USPS Priority Shipping $9.80
Order Totals:$70.00
More photos of the g2 paint job. In the previous photos, my camera's flash made the color appear lighter than it really is.
ImageUploadedByTapatalk1456131688.159439.jpgImageUploadedByTapatalk1456131711.809645.jpgImageUploadedByTapatalk1456131738.211263.jpg
After i removed all of the calipers from the truck, i spent about 1 hrs disassembling and cleaning them, and about 3 hours painting them. Everything got 2 coats all around on all sides. I had just enough paint left to pit a third coat on just the portions that will be most visible once everything is installed.
It's been time consuming, but the calipers rusted within 6 months or less, and i hated the look, especially because my wheels have large open areas, so the rusty calipers really stood out and were a real eyesore.
View attachment 192653View attachment 192654View attachment 192655
Hey I would not paint the area in which the caliper mounting brackets meet the pad (on the rear calipers). there is only a few mm of room where they are supposed to slide along. if you add too much paint you risk causing them not to release when letting go of the the brakes....
if it went in easy without forcing the pads in there you might be okay. but my 4th gen calipers seized because there were a few mm of rust, preventing the pads from sliding correctly. Other wise nice paint job.
That g2 paint looks good. How was your install? I got mine installed on Saturday and what a *****... about 10 hours later..
My driver rear caused us a lot of issues - rotor wouldn't come off, checked everything on it and it seemed fine, installed new rotor and it wouldn't rotate. Broke the damn shoe to get off rotor, had to buy new shoes, install, found a clicking noise while driving, couldnt figure out what it was, reinstalled old rotor and noise went away. Not sure if new rotor was out of whack or what.
you bent the parking retaining pin. there is a star adjuster you need to dial back to get the rear rotor off. if you don't you will bend the retaining pin and it will start to make that scrapping noise. or you
chances are your shoes are fine, mine were and the local shop was wacking away at it. Just need a new hard ware kit to properly mount them.
Has anybody bought 5th gen calipers through NAPA? If so did they take your 4th gen calipers as core for 5th? I need rears by Tuesday before a 2000 mile drive. They have some in stock for $73.49 each. Also they only have their cheapest rotors in stock for $48.99, anybody have experience with those? Thanks in advance
