Not-So-Krazy Build Thread! (Picture Heavy!!)
Stealth LED Bar Installed
So here it is. Took me a few hours cause I was messing around with some stuff, but here is the stealthed LED Bar on my 4th gen.
As I said in my previous post, I went with the brackets from [MENTION=93512]MojaveMadMan[/MENTION] and a 32" OPT7 bar + wiring harness.
As for the install, it was relatively easy. The brackets are very very solid and I am extremely happy with them. I will admit, it does take some shimmy-ing though. I had to push the brackets out with a bit of force in order to get the light bar to go in. But in the end it was a very snug fit and that actually gives me more piece of mind. I don't want this thing bouncing around a ton. The brackets were relatively easy to install and I tightened them down as hard as I could when everything was installed. Going to check them and the light bar for the next few days of driving to double check and make sure everything is fine and still snug. The bar sits essentially right on the inside of the bumper, and it feels solid as all hell when everything is nicely torqued down. Very happy with light output, even behind the lower valence.
As for the light bar, it came with the right bolts, but they were just a hair too long, so the bar had too much play. Easy for adjusting, bad for driving. So I went to the hardware store and got a washer and a lock washer for both sides to fill the space and hopefully keep the bar in place. Ended up working perfectly in terms of positioning and tightening. Again, going to keep an eye on it and check it over the next few days of driving.
In case anyone is curious, the OPT7 wiring harness is very well done. The switch provided is pretty shitty, but I had my one ConturaV switch I was going to use anyway. The harness is solid, well wrapped, and comes with plenty of length (and by plenty I mean way to much lol). My only gripe was that the wires for the + and - were a bit too short and the ring terminal things were wayyyyyy to big. Ended up cutting them off, extending the wiring, and putting my own smaller terminals on.
Overall I am very pleased with everything and I am looking forward to some inclement weather! For now, enjoy some of the pictures from the install! And if you have any questions, please, ask away! :)
After the install, unlit.
Light bar on.
The wiring was kind of confusing, so if anyone needs a reference pic, here is one. Maybe I'm just dumb. :brick:
Bit of a side shot of the bar lit. (Headlights are also on)
Front shot with all of the lights on.
Low beams.
Lows + Highs.
Lows + Highs + Bar.
Hope you all enjoyed! :bounce:
Simple question
I have a really simple question that really doesn't warrant its own thread, so I figured I'd post here and hope someone sees it.
I am going to install my CB soon, and I did a test fit last night of the firestik and comet RS mount. I want to put it on my trunk hatch, right by the driver side tail light. I did the test fit, but didn't full tighten down the RS720. When I closed it, it seemed to put a bit of pressure on the tail light, to the point that I feel like one wrong close and it'll crack the tail light housing. Should I simply put it higher up above the tail light? Or is the pressure a non issue? Thanks for any help!
Rausch Creek 10/24 Pt1
Went to Rausch for the day for my first true off roading experience! All I can say is wow, am I impressed with the 4Runner. Way more capable than I had imagined, and I never felt out of control. Ran the entire day in 4Hi with the Center Diff Locked. Only dropped in to 4Lo to pull a jeep out :dance:
All in all, I cannot wait to go back. Didn't realize there were a ton of forum members there too. Ended up wheeling with my cousin (who has the Grand Cherokee) and another forum member with a beastly 3rd gen. I didn't get his name to tag him, so if anyone recognizes this 3rd gen, then please tag him!
Also had the GoPro on the car and got some fun footage, so hopefully that will turn in to a nice video later this week. :D
And here are some pics!
Rausch Creek 10/24 Pt2
And here are some more pics!
Can't wait to go back!
More Pics from Rausch!
Here are some more pictures from Rausch! The couple that wheeled with us took these photos. I haven't been able to find them in the third gen section, but I know they are on here. If anybody recognizes that 3rd gen, mind tagging them or PMing me? Thanks!
Even MORE Pics from Rausch!
As you can probably tell, I can't get enough of this place. And I'm freaking obsessed with some of these photos. Maybe off-road/4x4 photography is my calling lol. :bounce:
Jeep Recovery Unit :D
Nothing major as of now. Working on sort of refining what I currently have. I need to find a place to route my CB cable connection, and where to put the microphone hanger. If anyone has some suggestions, please let me know!
I do have some upcoming plans that I am extremely excited about. I am looking to put in an ARB Dual Compressor in my engine bay with room for a 1Gal tank in the future. Leroy (aka Bandiworld) and I have been talking and he makes engine bay mounts for FJs and 5th gens. Talked to him and he said he would hook me up with a custom 4th gen V8 mount. Super stoked!
Beyond that, my next plans are probably a set of sliders (cause I basically broke my running boards) and maybe a roof rack. That Gobi groupbuy is really really tempting, but man is that a lot of money :cry: I am looking for bolt on sliders with a top tred plate. I have looked all over the place and I am currently in the process of doing more research, but does anyone have any brands that I should definitely put at the top of my list or definitely avoid? Thanks!
In other news, gained a solid 10HP today...
Compressor Mount
Compressor mount from Bandiworld is here! Won't be able to test fit for a few weeks, but that will just give me time to get the ARB Twin compressor ordered and ready to go :D
What color trails did you do at Rauch Creek? Im In baltimore so thats the closest place to legaly gonaround here. Gonna try it this spring. Nice build btw. Looks great
Did a bit more work on the car today. Completed the 03->06 Headlight swap with relative ease. I haven't seen any fantastic literature/guides on how to do this for a newbie, so I think I am going to make a (hopefully) idiot proof guide on how to do it. But for now, here is a nice comparison of the old and the new.
Also installed two new switches. They are pretty awesome and simple to wire/install. Had to sand down the inside of the switch hole a bit, but nothing too extreme.
Also, not pictured, I put my factory skids back on. I put some red rustoleum on them and they look great. Only issue was that two of the bolts snapper when I initially took them off, and we tried to extra them. No dice. Ended up just drilling a new hole in the skid with some beefier bolts and put them through two holes already in the frame. Works, but not ideal.
I'm loving these lights! Where did you get the fixtures from?
I honestly don't really know. We were just blasting around all over the place and I wasn't leading. But I honestly had a blast and didn't have any trouble on any of the trails we went on, and some were sketchy lol.
Hit me up some time and maybe we can get a group from Bmore to head up to Rausch for a day or two!
You mean the headlight assemblies themselves? Originally I got the TYC replacements from RockAuto, but both of them had defects and I returned them for a refund. Said screw it and decided to go with OEM fixtures from Camelbak Toyota. Perfect fit, no problems so far, and although I had to spend more, it was well worth it.
Pulled the lighted running boards off today. Really easy and I am liking how it simply makes it look higher off the ground. Definitely digging it. In the meantime, still working on figuring out the compressor mounting and now I am trying to come up with some courtesy lights to replace the ones from the running boards.
Before:
After:
What offset for the rims did you go with? Any rubbing at all with that tire setup? Looks amazing btw!
They were 0 offset. I got a bit of rubbing in the fender liner up front, but that was really easy to fix and took me about 5 minutes. Same goes for trimming the mud flaps. Really simple to do.
Very nice, I planned on this same lift but have been torn between 255 75 17s and 275 70 17.
After trimming, do you have any more rubbing issues? If so what does it rub on? Are you happy w this size tire?
Nope. No more rubbing after the initial trimming. Everything was perfect after that. I am in love with this tire size. I think they should come factory like this. It is a slightly taller, slightly wider tire and I think it gives it just a bit more lift/clearance while also giving it a more aggressive stance. All in all, I love it.
Awesome, thanks for the reply. Looks great!
