bhest's Build Thread
bhest
My 2003 2WD V6 Limited 4Runner
Original Owner
My Mods:
Inside
-Interior LED full light swap
-Kicker 8'' Comp S sub in stock inclosure
-6x9 Pioneer front door speakers
-Plasti Dip interior trim
-Sony MEX‑N5100BT
-Custom iPad Mini Mount
-Metra Amp bypass Harness
-USB Power in center console
Outside
-Daystar spacer lift 2.5 front and 1.5 rear
-LED reverse lights
-LED tag lights
-K and N Air Filter
-Plasti Dip emblems, grill, lower front bumper, and exhaust pipe
-Aux Beam 4'' Led Lights
-CBI Ditch Brackets
Photos of the mods? Would love to see how the interior trim turned out as well as the LED swap.
I will try to get some getter ones tomorrow. I blacked out the center console side panels as well
What LEDs did you use for the reverse lights? Picture of output would be great too!
They aren't the brightest, but look a lot better! I got them cheap at walmart, because I will be soon putting cubes around the hitch area or on my roof rack.
Nice build. I'm excited to see what you do. If you haven't already you should join the ATL 4Runners group a lot of guys from farther away like you. Also If your looking to hit some trails I'm trying to go up to Bell mtn and Charlie's creek this weekend.
Thanks! Ill check and see if I have any thing to do and let you know.
Led lights
Just got the wiring harness today to hook up my Aux beam 4 inch leds and my 32inch led light bar. Pics coming soon!
Led Lights/ USB Power
Here are my Led Light Install Details
Hardware
-32'' Light bar (Cheap Amazon)
-4'' Flood Lights (Auxbeam)
-Kawell 1 Leg Wiring Harness 300W (Amazon)
-Kawell 2 Leg Wiring Harness 180W (Amazon)
-Led Work Lights Switch (eBay)
-Led Light Bar Switch (eBay)
-CBI Ditch Mount Brackets (CBI Offroad)
-Tube Mounting Brackets (Amazon)
Wiring
-The light bar was wired like most on here, to the front drivers side plastic cover and down the windshield molding to the relay in the engine bay. The harness came with a switch that I removed and wired my eBay led light bar switch. I wired both switches so that the leds in the switches only come on when the buttons are pressed, so I wouldn't risk draining my battery or cutting into factory wires. The 4'' Floods were wired normally, but with the led work light switch.
USB Power
-I never use the cigarette lighter in the front, so I used power from it to power the USB charger.
iPad HeadUnit
Today I finished up my iPad Mini mount. I am very pleased with the turnout. I wanted a head unit with music, movies, apps, GPS. I just couldn't spend $400+ on a real headunit.
