How is everyone's radio reception?
4by4runr
Mine seems pretty crappy and I'm thinking about replacing the hu but I'm not sure if it's the hu or the crapoy antenna
I just replaced my HU and have pretty crappy reception. I did NOT use a Y cable and mini to regular antenna adapter for the second antenna.
I will try this next.
I have much better reception in our Marinette boat (all aluminum hull, decks, and superstructure) with an 18 inch diversity wire antenna behind the lower helm.
Both HU are Kenwood.
I will be investigating better radio reception as well.
I seem to remember reading something along the lines of connecting the power antenna wires, even though we do not have a power antenna, in the thread about new stereos ( can't remember the actual thread name).
I will try to find it soon.
My radio reception is pretty sucky. Lots of static on local stations that come in crisp on every other car I've driven. Since it does have an aftermarket head I'm hoping just a connection issue behind it.
Doing some searching on google and there seems to be some sort of common issue with it.
When replacing your head unit don't forget you have to get power to the factory antenna amplifier.
Mine is pretty good on my 2016, but im close to philly and manhattan ....distance obviously makes a difference.
WC11
Do you happen to know which factory wire that would be?
The "Radio Upgrades" is where I remember reading something about it but that thread is pretty big now.
Thanks in advance.
WC11
Thanks in advance.
It differs on the radios.
In my case, I had the Ltd. JBL Synthesis system and it was the black wire on the harness.
I put a meter on the radio and checked for the switched B+ to confirm.
Then once it was hooked up, all was good.
So I also have the jbl synthesis, however I think the previous owners had xm hooked up, I'm wondering now if they maybe used the antenna amp as their power source.
XM runs off it's own antenna independent of the other.
Connect a switched 12 volt to the black wire.
I have the JBL and get great reception, my apartment has a underground parking garage and I can listen to quite a few stations on the radio with a little bit of static on the first level where I park. My previous car was straight static.
My stock sr5 hu had better signal with almost to none static my pioneer raido has horrible signal. I even connect both antenna to the radio using the adaptor like someone mention on here and it had no fix.
I upgraded my HU to a Pioneer and used it with only one antenna plugged in for a couple of weeks. The signal strength was not great and I experienced some loss of signal in lower lying areas. I couldn't pick up any AM stations at all.
I bought the two into one adapter and tore everything apart and installed it. The signal strength improved only a little bit and still don't have really any AM station coverage. The HD channels come in pretty clear most of the time but when the signal is weak, it bounces to analog sound and won't display the artist and song info, album art, etc.
My HU is a Pioneer AVH-X3800BHS.
Interesting as I'm looking at the pioneer Avh-x2800bs, ... This isn't looking good.
Interesting as I'm looking at the pioneer Abu-x2800bs, ... This isn't looking good.
Someone mentioned hitting the antenna amplifier with switched power, but I have no clue where it's at in the vehicle.
TBH, I would probably not get another Pioneer HU, if you are using the app function for Waze, you can't listen to the radio anyway, everything has to come through the USB connection or bluetooth. Pretty frustrating to find that out...after you've bought and installed it all. If you don't need local radio it's a non issue.
my reception was great until i changed head units from stock to a kenwood single din. stations that were crystal clear don't even break through the static. been that way for a few years now
Pretty much describes my pioneer unit except the adapter bringing the two antennas together made mine worse.
Sad. I had seen someone else echo those issues as well.
