Spc cam bolts?
I wanted to know if these are any good before I spend the money on oem?
Mine work just fine, but just had them for a short time. I asked guys at ToyTech and they like theirs.
I do have two flattened Cam Tabs now. Now that's another thing on the list to do.
SPC is a pretty reputable aftermarket brand in general. I've used them for all of my past vehicles without a problem.
No direct experience with the T4R tho. Wife saying no to (visible) mods this time around.
Just put them on my third gen and they work as they should. [MENTION=59048]S p a r k y[/MENTION] and i just had to deal with bent camber tabs so i also installed Total Chaos Camber tab kit. Pain in the @$$ if you ask me but its all done and aligned fine.
Do you really need the tab kit?
I bought a set of the SPC cam bolts because a friend of mine had to cut his factory hardware off when he did his lower control arms, so I had a set just in case at the ready when I did mine. Once I saw what they were compared to OEM, and saw that my OEM's were good to go; I stuck with the factory stuff. That same friend, ended up going back to OEM hardware. He was getting a clunking off road and no matter how much we tightened them down, they would work their way loose.
I had some SPC UCA's and didn't have a lot of the BJ or breaking arm or bushing ring issues that some have experienced, but I did have issues with the nuts backing out on the long pin. But I'd run the arms again I suppose. I liked the adjustability and OEM style BJ. I wouldn't recommend the cam bolts though. Compared to the Toyota stuff, they're just really chintzy IMO. My 2 cents FWIW. YMMV.
I am starting to notice some new clunking noise myself. I do have 2 bent cam tabs or "crash tabs" as well. So it could be either one, dangit!
I have knee surgery tomorrow, so guess I will be dealing with the noise for a bit instead of fixing.
