Wobble on Braking
CXS
I'm thinking tire out of balance. When stopping gradually from 35-45mph I get a significant steering wheel shake. Pressing harder on the brake I don't get any. Stopping at all other speeds is fine. Is this a tire out of balance?
Could be you have brake pad deposits or a warped rotor. My truck had a seized caliper when the dealer got it and they only replaced the caliper, not the rotor or pad. So the rotor is warped from when the caliper WAS seized and I get the same symptoms as you.
I figure I'll deal with it for now and change the rotors when the pads are dead.
An out of balance wheel will shake at all times, not just when braking.
Your problem is brakes related. My money is on warped rotor - wobble when braking slowly but stopping when jamming on brakes is usually a classic warped rotor symptom. Could be siezed caliper also as 4th gens (including mine) are known to have siezed calipers.
Definitely not wheel balancing related.
I thought the same thing. but a rebalance did fix my issue.
I wish I had the same solution as [MENTION=76583]Morphyne[/MENTION] but it looks like a warped rotor. :dammit:
Thanks for the input folks!
I hate the term warped rotor, more likely deposits on the rotor if its the rotor.
However, had the same issue on my MDX. After a bunch of attempts to fix it, turned out to be a tire that was out of round. Got lucky that the new discount tire by my house had a newer style balancer that detected it.
An older discount tire down the road from me attempted to balance it 3 times but never caught that it was out of round.
i'm havin the same issue, probably going to get all the brakes and rotors replaced in the not-so-distant future. what's a good upgrade for 4th gen brakes? i don't need anything like a tundra swap, just something that's a little bit better than OEM.
I've heard that the 5th gen brakes bolt right up and won't seize on ya...there should be a "5th gen brake swap" thread somewhere around here.
I don't see why folks go to the 5th gen brakes myself. I know about the sticking calipers but mine have 211,000 miles on them w/o any issues. I'll stick with the tried & true.
I just put all new brakes and calipers on mine at 137k due to a frozen caliper. I didnt bother with changing to the 5th gen.
I think that SS brake lines are a better upgrade on the 4th gens than switching calipers.
If your rotors still have life left but your getting the wobble, it's likely a sticking caliper. Have you had the brakes apart? Pretty easy to check.
Makes sense, my calipers are the originals at 211k. I can't look at them myself unfortunately since I'm facing back surgery. Hoping to get it in to the shop before going under the knife. :(
Hello all,
I wracking my brain and now your collective brain to solve a mystery front end and steering wheel shake upon braking at all highway speeds. In the last year the following have been replaced on my 195,000 mile 2008 sport edition 4wd 4.7 v8: steering rack, drive axles on front, ball joints, brake discs front and back with new pads, front wheel bearings and brackets, front end bushings, front shocks, tie rods, wheels for new TRD black wheels, tire rebalancing and rotations, and multiple other small parts. All of this work was performed by dealerships and with OEM parts. None of it has changed the wheel shake. I'm considering now replacing the front calipers to see if one of the slave cylinders has been damaged by moisture in the brake fluid.
I'm from a family of mechanics and because they are older and out of the loop on newer cars none of them really know what is happening. I've tapped all of the locals who are still great at the business of suspension and brakes but no one really knows what is happening.
The car doesn't pull left or right all it does is shake but up until 180,000 miles this never happened. I keep up with maintenance and this is very disconcerting. Anybody ever solve this issue definitively and not have it return. I love my truck and have long term plans to keep it up and drive it until it falls out from under me. Help Please!
Hello all,
I had the same issue when I purchased my 4Runner back in November. I had two seized callipers. All four were changed as well as all rotors and pads at the same time. I can’t say for sure it was the callipers causing the shaking, but it was definitely brake related. Considering you’ve done the rotors and pads already, you should definitely have a closer look at your callipers.
