SPC UCA Greasable Ball Joints
CXS
I have the greaseable ball joints on the SPC UCA's I have installed. I assume that's the same joint as the one you show. I have about 7000 miles (mostly highway, some offroad) on them. I grease them when I do an oil change. So far everything is good, but it's obviously still early.
Thanks [MENTION=134884]RonJR[/MENTION], early reports are better than none. My current set have a bit of play as do the LBJ and I'm trying to decide the best approach in fixing before Spring. Those combined with the need for new front calipers, rotors & pads will set me up for snother 200k I hope.
10k or so on mine. Feel good, same as my non greasable. The non grease were starting to show wear, so went greasable.
I have some sitting in the garage but I'm waiting until I install the bumper/winch combo and swap out the 600 lb springs for some 700 lb springs. I have the non-greaseable version now and the right side has developed a little play but they have roughly 60k miles on them.
