10-30-2006, 10:54 PM
Front Turn signal lights keep burning out
Hello,
I keep having my front turn signal/daytime running lights burn out. I just had both replaced and they have both failed again (one a few weeks ago, and another today).
It's been going on for a couple of months. I noticed the problem after I had an alpine radio installed and then removed. Do you think that had something to do with it?
Anyone got any advice? All the other lights work fine.
10-31-2006, 09:55 AM
Did you have them replaced by the dealer? If so bring it back, there may more of an issue than the bulbs. You said you had the stereo installed, then removed? So its not in the truck right now? I cant see why a stereo would effect your turn signals, but I guess it depends on who did the install for you.
Mike
04 Sport Edition V8 4x4, Natural White, 22% Tint, XM Myfi Install, Bridgestone Dueler Revo's (11/20/06 @ 31314 mi), Homelink Mod (12/26/06) Royal Purple Gear Lube - front and rear and transfer case (12/17/08 @56,600)
10-31-2006, 01:21 PM
I seem to recall that Toyota sells different bulbs for trucks that have the DRL option. I'm in a bit of a hurry, but I think I remember reading about that in one of the DRL threads... Maybe someone sold you the wrong bulbs?
05 V8 Sport 4WD - Icons, ARB bull bar, Borla exhaust - SOLD
95 FZJ-80 - ARB, Ironman lift, triple locked, - SOLD
09 GX470 - trying to resist the urge to mod.
10-31-2006, 07:54 PM
Yup, the trucks that had DRLs installed from the factory run a different bulb. If you had swapped out the non DRL relay for a DRL relay, the bulb was specifically designed for the extra output. I've been running with the added DRL relay and so far the bulbs have held up but the life has yet to be seen for me.
10-31-2006, 09:44 PM
So you had ur DRL installed? I had my installed after I got the car. If anyone remembers the picture i posted, but does the "DRL" logo next to the "Koito" logo on the lens of the lights mean DRL ready or something?
2014 Lexus LX570- Nebula Gray Mica-Charcoal Interior
2013 Lexus LS460 F-Sport-Matador Red
2007 Lexus GX470-Blizzard Pearl-Ivory Interior-Nav/RSES/ML
2003 Lexus GX470-Sand Dollar Pearl-Charcoal Interior
2001 Lexus RX300 Silversport Edition-Millenium Silver-Black Leather Interior
10-31-2006, 10:20 PM
My truck didn't have DRL from the factory. All I did was swap the NON-DRL relay for the DRL Relay and everything still worked. The only problem is that my truck doesn't have the bulbs/plug that was designed for the DRL equipped vehicles. The regular bulb still works, but wasn't designed for the lights to stay on all the time so the bulb may go out faster.
10-31-2006, 10:26 PM
Well, hope they won't. The 4R might even beat my GX. Both of my DRL bulbs on my GX have burned out! But only once per side. :gaptooth:
10-31-2006, 11:20 PM
Does anyone know the type of daytime running light that toyota puts in the 4runner?
The dealership offered to replace them but it was 15 dollars a bulb, so I just rolled my eyes and said no thanks.
I'm thinking maybe get it off of ebay or an auto store.
11-01-2006, 01:24 AM
I too am wondering. I did the DRL relay swap to enable DRL and the old stock bulbs just burnt out. However, I replaced it with the same bulb, but this means it will burn out faster than the DRL "ready" bulbs. Could someone please post a part no for this bulb?
Thanks
02-05-2008, 01:19 PM
Sorry for bringing up a old post.
I too did the DRL mod and wanted to use the dual filament bulbs so it will last longer. However, the DRL bulbs will NOT fit the current socket because it was meant for the non-drl bulb turn signals.
However, looking at the service manual, if we were to switch the bulb socket for the DRL one, will it work? Does the DRL one have an additional wire or something special that toyota used different sockets?
Look at the picture below:
Replace #3, Socket, Bulb
w/o DRL TO THE w/DRL socket? then we can use the regular DRL dual filament bulbs.....
Any ideas??
02-05-2008, 01:32 PM
Use a LED replacement bulb!
Koz
02-05-2008, 01:34 PM
Koz
Thanks man,
However, I looked at the superbrightleds.com website and they said since the LEDs use a lower amount of power, it might make the blinks flash faster. (as if the bulb were burned out)
02-05-2008, 02:03 PM
There are two ways to fix the fast blinking. You can measure the resistance (ohms) of the two bulbs (LED/nonLED) and add the difference (approx 2/3 ohms), as a resistor. Add it in series on the positive line in. You could also fix it the easy way by adding a solid state flasher relay.
http://www.narva.com.au/Switches_20.html
Koz
12-20-2009, 12:02 AM
READ THIS::
I replaced my front drivers side blinker/turn signal/parking bulb twice and both times it burned out within a day.
Thanks to some advice from andrewajc I think the problem has been corrected.
Turns out the bulb was not pushed all the way into the socket. It clicked once and then I had to push REALLY hard with both hands to get the bulb seated all the way in the socket to get a second click. hopefully this helps some people like me who just aren't pushing the bulb all the way in which results in the bulb burning out quickly/shorting.
2005 4Runner Limited V8 4X2
Stratosphere Mica Blue/Gray Leather
Borla Performance Exhaust, JBL Synthesis 6 CD Chgr & 10 Spkrs, Aerodynamic Spoiler, Sunroof, Sunroof Wind Deflector, Bug Deflector, All Weather Mats, Heated Seats, ToyoGuard, and Tinted Windows.
02-01-2010, 11:46 AM
Thanks baronvdb (and andrewajc)!
This was exactly the problem I had. The new bulb worked for a couple of days and then was out again. Luckily, mine had not shorted or anything. The contacts must have just worked loose. With the second click, it's been working fine!
(This is with the DRL option, btw.)
