Originally Posted by Run4nuts
I believe you just cleaned the contacts.... But I'm not 100% on that. I know you finagled with it....
See if the following applies to your issue, copy/pasted from the link I included previously:
I'm suspecting that possibly the main issue here may be the stop lamp switch circuit, but I am not 100% certain at the moment without being able to look at TIS for more information regarding the DTCs as well as testing the vehicle myself. If you can, please try the follow:
1.) IF the lights do go out when you cycle the key, please start the vehicle and do not touch the brake pedal at all.
2.) IF the lights do not turn back on after waiting a few minutes, THEN step on the brake pedal as if you were to shift out of gear.
3.) IF the lights still do not turn on after you depress the brake pedal please drive a short distance (about 5-10ft should be enough).
