Issues with rim rubbing on brake caliper.
kjonus
Hey guys wondering if anyone else had the issue that I was faced with today. I bought a set of 17 inch '17 Tacoma rims off of a guy to use a summers for my '07 Sport but the the brake caliper is just rubbing the inside of the front rims only. The caliper on the rear are single piston and have lots of room, while the fronts are double pistons and bigger overall. I didn't notice this until I pulled out of the garage and scored the rim all around. Thoughts? I'm thinking I could file the high spot on the caliper as there's lots of meat there but what kind of clearance should the minimum be between the calipers and rims.
The Toacoma rims have a step up as can be seen in the pictures where the OEM 4Runner rims don't have this step up which is the difference from rim to rim.
Hey guys wondering if anyone else had the issue that I was faced with today. I bought a set of '17 Tacoma rims off of a guy to use a summers for my '07 Sport but the the brake caliper is rubbing the inside of the front rims only. The caliper on the rear are single piston and have lots of room, while the fronts are double pistons and bigger overall. I didn't notice this until I pulled out of the garage and scored the rim all around. Thoughts? I'm thinking I could file the high spot on the caliper as there's lots of meat there but what kind of clearance should the minimum be between the calipers and rims.
U could run a small spacer up front.
Sent from my SM-G930V using Tapatalk
You think that the rim is tapered? Cause it's rubbing on the outside of the caliper not the front of the caliper. I'll measure it tomorrow and report back.
Man I could swear I’ve seen 4th gens with these wheels before.
Do you have any pics from the side with those rims mounted? Looking to replace my stock rims.
They look pretty sharp, but I put my winters back on until I figured out what I'm going to do....I'll get you a pic when I have them on again.
Are you the original owner of your 4Runner?
My educated guess would be that at some point someone replaced either the driver or passenger side caliper/rotor with a different size.
I would check both calipers to see what is stamped on them (see my suggested threads above).
I run these 17" tacoma wheels. YES, they do RUB the caliper. Do not grind your caliper.
Easy fix is to put wheel spacers on or sell them. The wheel spacers I ran did not engage the stock wheel studs well so I bought longer wheel studs for my hubs front and back.
My notes about the wheel studs:
Longer front wheel studs needed in order to run wheel spacers
2003-2006 matrix or pontiac vibe, 55mm long.
AWD matrix Toyota PN 90942-02078
Dorman 610463 from a 2004 Matrix $1.42 each
$34 shipped (qty 20) from Rockauto or $39 amazon
