Originally Posted by AuSeeker
I have one other question to final get the TPMS to display, did you use the 2007 module or the original 2005 module?
I used the 2007 module. I didn't take it out since it would have been a hassle to take it out, go to Discount Tire and have the tech reprogram the tires(although he did it for free when I changed out the TPMS module).
When I talked to Maestro tech support about the issue. They told me it was the tech that was sending the message to the Maestro unit. From my original post, you can see that the tires have a green square but no number. The maestro tech told me that back in the early days of TPMS, the unit would only send a single of 'green=good' red= bad"or...under the 28 or 29psi threshold.
I also talked to
gshadow325
who has more knowledge about these units than me, and he also stated something of not having enough CAN bus thingamajigger.
You can try and get an update Maestro RR and see if gives you the psi/temp on your unit before you go buy a later model TPMS ECU module.
