07-06-2018, 05:34 PM
#16
If you are looking for a quiet exhaust, the Gibson is NOT it.
(I have a Gibson exhaust)
Back in the day, I was not impressed with the Bosal welds.
Walker/Magnaflo is my go to for OEM quality.
If you are able to see/touch the actual exhaust parts before purchase, I would consider doing that.
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
07-10-2018, 10:41 AM
#17
Thanks for all the responses. I'd love to be able to find a used factory exhaust and priced out a new one at the local dealer and it was just shy of $800. Again, not looking to get cheapest fix either but really best value.
2004 Galactic Grey 4runner - Sport Edition 4x4 -265/70/17 Nitto Terra Grapplers-35% Front Window Tint-Hella Optilux XY Yellow Fogs-Sylvania Silverstars (Lows)-TRD Skidplate-Weathertech Ventvisors (In Groove)-K&N Cold Air Intake-LED Mod Interior & Exterior
1986 Matte Black 4runner - DLX 4x4 22RE Manual -4” Trailmaster Lift w/ Bilstien Shocks, Bushwacker Fenders, RoundEye Headlights, KTT Top, Tuffy Lockbox CD player, Moonroof, Front BrushBar w/ custom skidplate, Smitty Built Rear Bumper, Marine Speakers in Rear,Tankota Quick Release Hinges
07-10-2018, 11:08 AM
#18
Real Name: Joey
Real Name: Joey
Cali legal?
Does anyone know if there is any exhaust that is CARB legal?
07-11-2018, 11:08 AM
#19
Will a 4th Gen V8 exhaust fit a 4th gen V6 as far as a replacement? Found one local that is being parted out.
Also will a 5th generation 4runner exhaust work on a 4th gen? I found a local used one.
07-16-2018, 11:13 AM
#20
Bueller? Anyone? Thanks in advance.
07-16-2018, 01:32 PM
#21
Mine gave out in the same spot. I got a walker cat back system for Rock auto. Good quality and cheap.
07-16-2018, 03:02 PM
#22
My OEM exhaust only lasted 8 years before rusting out. Installed a magnaflow for about 6 months but it sounded awful. I then went with Bosal and it's lasted 18 months and is about to fall off. Also there's something loose inside the muffler that rattles really loud at high revs, so I won't be buying their stuff again.
Currently have a gibson system in the garage waiting patiently for some free time to install. If it sounds like crap too, then I'm going back to oem.
07-16-2018, 03:35 PM
#23
Bueller.....,
I don't recall what engine you have (V6 or V8) that has the bad exhaust?
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
07-17-2018, 05:48 AM
#24
depending on the year. you will need to extend the front of the pipe.
when i did the dual borla, it came from a 05 v8, i drive a 07 v6.
front of pipe had to be extended about 4 inches i think.
my muffler guy already knew that he had to modify it a little. but since he was so cool, he didnt even charge me at all.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
07-17-2018, 07:24 AM
#25
Exhaust Recommendations
BBK Performance adjustable muffler. You can attenuate the volume of your exhaust to your liking.
I went to a local muffler shop and asked one of the old heads if I wanted the exhaust a bit louder, but not magnaflow 40 series loud, if that was possible. He first said I should get a 50 series. After hearing my truck, he said the 50 series may even be a touch quieter than what I have now.
I’m currently running with the muffler dialed out to it’s ‘loudest’ setting and I have DT headers as well. Very happy with the results. Not loud and boomer ever and when you get on it you can hear intake & exhaust noises.
I have a v8 btw
https://youtu.be/LoMDnEplC90
https://youtu.be/IrmfAYP3JwY
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
07-17-2018, 10:23 AM
#26
Registered User
Registered User
I agree. OEM is the way to go. I have the 2005 model V6, I am still using the original exhaust parts. at some point those rusted parts will finally fail on me and once it does, i'll replace it all with OEM since I plan on using it for a long time.
Originally Posted by wc11
The galvanized OEM version lasted 14 years.
You want to keep it and give to your daughter in 6 years = OEM.
Cheap out now and there won't be anything to give her.
07-29-2018, 04:36 PM
#27
Ok so my tailpipe broke off of my exhaust today as well. I'm looking into options and i came across this video (linked below).. The muffler was replaced with the resonator which i've never seen done before, Anyone more experiences with exhaust systems have input on this i'd appreciate it. Pros/cons?
https://www.youtube.com/watch?v=P-9knLhYA30
