Toyota - 4Runner . org Forum
Go Back   Toyota - 4Runner . org Forum > Toyota 4Runner Forum > 4th Gen T4Rs
LinkBack Thread Tools Rate Thread Display Modes
  #31 (permalink)
Old 02-21-2008, 09:23 AM
LTH LTH is offline
Simple Swap
Originally posted by 00328
Is the HIR bulb just a simple swap with the OEM bulb?
Do the HIR bulbs have a whiter light output than OEM?
The HIR bulbs may have a slightly differently shaped plastic flange than OEM, so a file or Dremel tool may be needed to reshape to fit. Otherwise it's a simple swap.
The HIR bullbs are longer than the OEM, but the primary light source is about half-way along the bulb length, so the focal length of the headlamp assembly remains correct.
I don't care much about white, although I don't like those blue lights very much. The HIRs are very close to the same color temperature as OEM, just 33% more candlepower for the same wattage thanks to the infrared reflective coating.
For details, here's the discussion thread on I8MUD:
http://forum.ih8mud.com/80-series-te...ry-lights.html
LT
1999 T4R LTD
2004 T4R LTD
Black Mountain, NC
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Registered users don't see this ad. Register today!
  #2     Report Post   IP
Old 07-10-2009, 09:59 PM
Sponsor
Edit/Delete MessageReply With QuoteMulti-Quote This Message Quick reply to this message
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
