Toyota 4Runner Forum
Register *new* Garage Photo Albums FAQ Members List Social Groups Calendar Mark Forums Read Sponsors
Go Back   Toyota 4Runner Forum > Toyota 4Runner Forum > 4th Gen T4Rs
LinkBack Thread Tools Rate Thread Display Modes
Old 03-06-2008, 04:41 PM
  #1 (permalink)
Registered User
boarder is an unknown quantity at this point
hitch center bracket question
I have an 07 V6 that came without a hitch. I want to install an aftermarket weight distributing hitch (similiar to the V8 model).
Do I need to have an OEM center bracket even if I use an aftermarket hitch (such as Hidden hitch etc) ?
My 4runner has no hitch or bracket (no cutout either). I can't tell from the online hitch manuals if they attach just to the frame rails, or to both the rails and the bumper center bracket.
boarder is offline
Old 03-06-2008, 10:18 PM
  #2 (permalink)
Super Moderator
Uneek's Avatar
Uneek is on a distinguished road
HiddenHitch model# 70411 has an attachment point in center on the rear most cross member. The 70411 has been discontinued, you might still be able to find it. It's rated for 7000lbs.
Model# 70779 attaches to the frame rails. There isn't any attachment points in the center. It's rated for 5000lbs. No cutting is required, but you will have to remove two support brackets that bumper tabs attach to on the rear most cross member. The brackets are about a third of the way in from the sides.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
Uneek is offline
Old 03-07-2008, 08:41 AM
  #3 (permalink)
Super Moderator
CJ3Flyr's Avatar
CJ3Flyr is on a distinguished road
The label on my 70779 says 600/6000lbs(dead weight) and 730/7300lbs with weight distributing hitch. On my 4Runner I am limited by the V6 4wd to lower values; 500/5000lbs and 62 or 6300lbs (I forget what the manual says) w/ weight distributing hitch.
My 70779 looks good and light plug bracket is in a very functional, safe and cosmetically acceptable position. Some 4Runner hitches have the hitch plug so far under you may need and extension to reach the trailers' plug or I've seen them so that the plug is the lowest part creating an angle-of-departure issue. Good Luck
CJ3Flyr is offline
Old 03-07-2008, 10:48 PM
  #4 (permalink)
Super Moderator
Uneek's Avatar
CJ3Flyr,
Does your hitch look like this?
Label
Relocated hitch wiring plug
'06 Limited V6
Uneek is offline
Old 03-08-2008, 04:05 PM
  #5 (permalink)
Super Moderator
CJ3Flyr's Avatar
My hitch is as follows:
Upon further review the hardcore off-roader may not like my hitch. The light plug does hang down some, not as bad as others I've seen though
Check this on towing limits for the V6... LV4R's reply sums it up. It's about the 12th one down. V6 towing with 70779
Hope this helps
EDIT Here's another hitch option with the same hitch rating:Hitch Installed!
PS- My hitch was purchased Oct '07, shortly after I got the T4R.
CJ3Flyr is offline
Old 03-10-2008, 11:59 PM
  #6 (permalink)
Super Moderator
Uneek's Avatar
CJ3Flyr,
HiddenHitch must've made some changes/upgrades to it. I would think they did since they discontinued the 70411 and there would be no reason for a V6 owner to upgrade to their 70779 if the capacity is the same as stock. Mine doesn't relocate the hitch harness either. The bolt and plate is all they provided to mount the hitch, thus I no longer have the tie down in the rear.
My bar code label like yours says 17/02/06, but the tag with capacities show 02/20/06. I got the hitch in May '06 a couple months after getting the 4Runner.
Yours appear to be the same shape/style as mine, even to how it pushes the bumper up slightly too. At least no cutting is required.
'06 Limited V6
Uneek is offline
Old 03-11-2008, 09:29 AM
  #7 (permalink)
Super Moderator
CJ3Flyr's Avatar
I'm very satified with mine.
I towed a poorly balanced 4300-4500lb the other day with zero issues. It was poorly balanced in the sense I was light on the tounge, light enough that I could lift it. I'm guessing a squeak over 200lbs. The 4Runner was stable and smooth to spite a pretty stiff breeze.
CJ3Flyr is offline
Old 03-12-2008, 02:52 PM
  #8 (permalink)
Registered User
thanks for the info guys.
I did a little digging of my own, and it seems Hidden Hitch along with many of the other hitch companies are all owned by Cequent Towing Group. And so, the 70779 series has different models or "revisions" now. Depending on which revision you get it could be listed at 5000/6000 or 7000 lbs for WD.
Now I have to decide if I should get Toyotas V8 hitch (and bracket) or just get one of the 70779 models.
boarder is offline
Old 03-12-2008, 03:05 PM
  #9 (permalink)
Super Moderator
CJ3Flyr's Avatar
If you're curious mine (with the high rating) has 4 bolts on each side for a total of 8.
CJ3Flyr is offline
Old 03-12-2008, 09:08 PM
  #10 (permalink)
Super Moderator
Uneek's Avatar
I found that out too when I was looking at different hitches. I don't remember exactly, but Valley and Reese might be under Cequent. I believe my HiddenHitch was dropped shipped, and the box it came in said Cequent all over it.
'06 Limited V6
Uneek is offline
Trackbacks are On
Pingbacks are On
Refbacks are On
Trailer hitch question Eastcoaster 4th Gen T4Rs 6 02-19-2010 10:18 AM
hitch FoozGrind 4th Gen T4Rs 0 05-14-2009 09:11 PM
Can my 4Runner tow this thing? juneau92 4th Gen T4Rs 30 07-05-2007 01:50 PM
Stupid question - all new runners have a locking center diff, right? spud72 4th Gen T4Rs 12 03-06-2007 03:36 PM
Question about center console. darktiger Audio & Electronics 2 01-19-2004 01:26 PM
» Current Poll
Who should win T4ROTM May 2012
93Toy - 29.55%
13 Votes
SV_Dude - 22.73%
10 Votes
Slacker - 34.09%
15 Votes
Drz400smoto - 13.64%
6 Votes
Total Votes: 44
You may not vote on this poll.
» Facebook Page
» Log in
User Name:
Password:
Not a member yet?
Register Now!
» T4R Sponsors
T4R Gauge Swaps Key Insurance
Metal Tech 4x4
4xInnovations
Toyota TRD Parts
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Optimization by vBSEO 3.6.0
