Tie rod end torque spec
00328
I am in the final stages of completeing an OME install on the front end. I'm trying to button things up before I start on the rear and for the life of me I can't find what to torque the tie rod ends at.
Anyone know?
I searched and found all the other specs, but not tie rod ends
this thread helped me
Thanks for posting that link to the service manual.
Just to save whoever references this thread after me. The castle nut is torqued to 66 ft lbs, as per the link provided.
that link provides all torque specs for the front end components so might be good to save if you're doing other stuff :)
Cheers
Both my front wheels are super loose and I need to do my tie rod ends I got the inners but I don't have the tool to do it but I'm afraid to drive right now and here it is Christmas Eve. I'm stuck at my friend's house in the keys 100 miles from home. If I do the tie rod ends on reading two different Torx for the nut on top. One thing I read in one video said 36 lb for the night on top of the tie rod end then on here I see people saying 66 lb that's a huge difference. Which one is the proper torque for the nut on the tie rod end. Thanks for your help Merry Christmas.
I should probably do my inner is also I just don't have the tool to take it off and i just saw some manual talking about not messing up the gears on the driver side and all kinds of crap. Should I be concerned with this ? and how do you properly torque that. None of the videos I watched discuss the torque for the inner tie rod
