Cabin Air Filter Replacement
dheeter
My cabin air filter needs replacing. Does anyone know a part number and where it is located? Jiffy lube wanted $40 to replace it. Thanks.
buy the Carbon coated air filter from the 2003 Lexus equivalent (the gx I think).
those things rock.
Toyota OEM Cabin Filter (V6 & V8) - 87139-47010-83
charlier180 said:
I replaced mine late at 32,000 miles...it was extremely filthy. I won't bother including pictures, because these Threads completely sum it up.
charlier180 ...has helpful links...thank you for being on top of things!!
You are welcome.
Just so happens that a few years ago I had the same questions about the Cabin Filters.
I went to Home Depot and purchased a 3M filter and made 4 Cabin filters for my 4Runner.
They perform VERY WELL and best of all, cost me about $4 each. :D
those things rock.
What makes them better?
Thanks for all the feedback, I appreciate it.
Super easy and well worth the 15 minutes that it takes. It's also nice to know your not breathing all the stuff that comes out of there....
How often do ppl change these out?? At a certain distance driven or when its summer and everything is filtering through your channels...for instance here we go through lots of smokey days. Fire season kills my allergies. Would it be best to change out often when air conditions are bad "enough"?
I do mine every spring, both vehicles.
I'm a fan of Premier Air Filters. They are known as "simpleairfilters" on ebay, and they are slightly cheaper there.
2003 - 2009 Toyota 4Runner - Carbon Cabin Air Filter
Search for eBay item number 250869527370.
Who knows if the carbon does anything, but they are dense filters that catch a lot of dust. They restrict the max fan speed a bit, but it's worth it for the dust collecting ability. I changed mine after a trip with 100+ miles of dirt roads last year, and there was about a half inch of dirt in it. That would have been a half inch of dirt that made it inside otherwise.
I bought a Toyota filter from the dealer once, and I returned it because I could see straight through. That would be good for catching leaves, bugs, mice, and not much else.
Looks like it's been almost a year, so I should order another one.
I had the 6 month old 4K mile cabin filter replaced by me . reason was I was in a sugar sand area with construction stirring up this fine dust.. then the fires smoke. this is in sw florida.. being from NE had no problems, but day one in this area the filters where thrown out and replaced with carbon cabin air filters by WIX. cost $20 .. well worth it me and wife had no more breathing problems.
on replacing it depends where your at.. up in new england the pollen in my area you have to do this every JUNE.. that is when all that pollen is done. if not then the ac will not work good !!!!
OEM IMO IS crap................
just looking at it its crap ... toyota lets do a better job ...
my GM 2000 truck have far better filter 10 X better..
I bought a reusable one at Walmart, and just open and sqeeze the sides of the dash to see filter location
Sent from my SM-N910V using Tapatalk
[MENTION=85375]Brookey_813[/MENTION] I think it depends on the user and their preferences (and of course conditions encountered). The worse the conditions encountered or more particular the preference, the more frequently it should be changed.
I took the lazy option and just set one of the user definable maintenance reminders for every 10k miles... in ~3yrs of owning this 4Runner, it seems to be a good interval for me and what I put it through.
What's a user definable maintenance reminder, and how do you set it?
Its the "Personal" icons on the Maintenance menu under the INFO menu ... guess I have mine set to 15k, not 10k like I thought :confused:
