#31 (permalink) | |
Registered User
As time pass's the real truth will show up. It might not be a complete failure, but small thing like using more oil have happened to many others who have not heeded over heating items.
| Sponsored Ad | # |
Advertisement
#32 (permalink) | |
Banned
#33 (permalink) |
Registered User
x3
Mods - Any chance we can clean up this thread. I'm looking forward to the write-up from the_josh.
2004 SR5 V8 - Natural White 265/70-17 Nitto Terra Grapplers / Hanna Quality Sliders / Scion Xb Radio w/ XM / SAW Coilovers (F) / OME 895 & N141 (R) / Light Racing UCA / Kurtfab Diff Bracket / Toyota Skid Plate / 06 LED Tails / Hard Wired Nuvi 760 |
#34 (permalink) | ||
Administrator
2001 & 2004 Toyota 4Runner SR5 4X2 Both V6 and both Natural White "Yeah, I like white and I like 4Runners" |
#35 (permalink) |
Registered User
Before the work Started:
![]() removed the drained the radiatior and removed it, along with the fan and fan shroud ![]() ![]() removal of the serpentine belt and start un bolting the starter (not pictured) ![]() unbolting of the power steering pump and just leave it connected
2004 SportEdition V6 Mods: - Radflo Full Suspension - Budbuilt Full Skids + Diff Guard - 4 Lightforce 170's on The 4th gen Bajarack W/ Lightcage - National Luna Dual Battery Setup W/ Blue/Yellow Tops -Blue Seas Fuse Block -Bfg M/T KM2 35x12.50x17 - Kenwood Excelon X993 - Schrockworks Bumper - AFE Stage 2 C/A Intake- Spidertrax wheel spacers - CBI Rear Bumper & Tire Carrier - Viair Onboard A/C+Tank - Rocky Road Super Sliders - Lightorce 240 Blitz-4300k HID's |
#36 (permalink) |
Registered User
unbolting the a/c compressor
![]() next we removed the starter, and unbolted the flywheel from the transmission (it was too hard to get the angle for the camera, i will try to get it when we install the engine) then we unbolted the exhaust manifolds and pulled one out and left one on ![]() the fuel needed for the day ![]() it was a pretty simple process to remove the engine, next we are getting ready to pull it out, we forgot to disconnect the fuel lines just as we were hoisting the engine out!! no damage though
#37 (permalink) |
Registered User
its out!!!
![]() notice the new wheels, only a day old and no chance to enjoy them yet haha, the clearance was low for pulling the engine out so we ended up deflatting the tires for a few extra inches ![]() posin with the 4.0 ![]() almost out, ![]() look at all that space!!! ![]() hangin by a chain...
#38 (permalink) |
Registered User
thought i might relax and enjoy a beer
![]() hoppin out ![]() the new engine to be, freshly stripped ![]() new water pump ![]() the work area... ![]() old engine... ![]() new engine...
#39 (permalink) |
Registered User
dude, no offense, but your buddy is wrong about your engine being unrepairable. i'm nearly 99% sure all you did was blow a headgasket. if both the block and head were warped there would be no possible way the cylinder would be able to build 199psi when you did the compression test. and even still, i would NEVER diagnose a warped head and block without physically taking it out and MEASURING it. its the only surefire way to tell for sure. and when a headgasket is 70 bucks, opposed to a $1500 longblock, i'd always recommend checking the head and block before tossing it out.
03 T4R Limited V8 |
#40 (permalink) | |
Registered User
and also when we pulled the engine there is also external leakage on the left cyclinder head in several places
#41 (permalink) |
Im Opinionated mmK?
This is just awesome!! Keep up with the updates please!
Good luck!
| 2007 V8 SE | 265/70/17 BFG KO's | Complete Alpine + Kenwood Audio System | 20% Front, 5% Rear Tint | M1 All Around | |
#43 (permalink) |
Administrator
Man, great pictures. Just chilling out. Can't wait to see the install. Keep up the good work.
#44 (permalink) | |
Good luck with your project. Bottom line is that when you're done, your 4Runner should be working just fine.
2007 4Runner Sport V6 4x4 Last edited by brucemoose2; 05-28-2009 at 04:20 PM. |
#45 (permalink) | |
Registered User
| Thread Tools | |
| Display Modes | Rate This Thread |
