here she was from the snow today...
-Will Model: 03 T4R l V8 l SR5 l PreRUNNER l |
Registered users don't see this ad. Register today! |
How much did this set up cost you? The coilovers? Also did you put the BL on by yourself, if not how much did it cost to get put on and does the frame hang out of the bottom a lot? (PICS please) How much did the roof rack cost you and who made it? What exactly do aftermarket bump stops do for you? Who makes those and how much? I am thinking about a body lift, I think I could stuff 35's underneath mine at that point, wishful thinking maybe. How much did the roof rack decrease your mileage? I am already at 13.5 on the highway on a good day, without the shrockworks bumper so probably a little less in a few weeks.
2006 4Runner Sport V8 4WD Magnaflow exhaust, K&N drop in filter; 3/2 Cornfed Lift 33 inch Nitto Mud Grapplers wrapped around 20 inch black Rockstars. Tinted tail lights, LED license plate lights, LED running lights and turnsignals. De-badged all around. 5% tint on front windows and 5% over stock tint on rear windows with 30% all the way down windshield. Kenwood Double Din 7 inch headunit, integrated Ipod controls. 2 Alpine Type R 12" subs with 2 Alpine 500 watt Mono Amps and a 6 farad capacitor. All interior lights swapped for LED's. Shrockworks steel bumper replacement on its way!! Car Domain page: http://www.cardomain.com/ride/3124002/2 |
Snow in AL
We ended up getting about 3-4 inches, which is a big deal for Alabama. These pics are outside by friend's house after it had sat all day outside.
Bumpstops make the impact when you bottom out less harsh and more controlled, it is only noticeable if you wheel your truck hard, at speed, and fully compress your suspension. They are made by Timbren and about $200 for the fronts. 35's require a lot more modifications. See toyota120.com for more info 35s on a 4Runner - Toyota 120 Platforms Forum The rack is made by Baja Rack. It is about $525 for the rack and about $200 for the light cage. It will hurt your mileage quite a bit on the highway, also creates a lot of wind noise.
Build Thread 2008 Sport Edition 4WD V6- Shadow Mica Fox 2.5 Extended Travel Resi Coilovers|Camburg UCA's|Fox 2.0 Piggybacks|Icon Coils|Timbren Bump Stops|TC Diff Drop|RB 1.5" BL|Gusseted Frame|Spidertrax|SW Sliders|Black FJ Wheels|6000k HID's|(4)KC Slimlites|Bajarack with Lightcage|255/80/17 BFG MT KM2's|TRD Exhaust|Factory Nav|Garmin eTrex|Cobra 75|Wilson 5000 Last edited by BlairB; 02-13-2010 at 04:45 AM. |
I only have bumpstops in the front, not the rear. Usually the thud you hear in the rear end is your suspension full expanding. With a Cornfed 3/2 your springs are typically trying to overextend your shocks farther then they are designed to extend, so that may be causing it. Typically you have to be doing fast and pretty big obstacles to make your suspension stuff fully. I highly recommend the full suspension I have if you wheel hard, and for long periods of time. Remote reservoirs like I have are useful on extended runs where you begin to overheat standard shocks. I have beat on these at 70+ across the desert for almost an hour straight before without any issues of fading. I would say that for about 95% of off roading, Resi's are not needed, esp if you do not do FAST runs. Also, these are very pricey and will run you about $3k+ for a similar setup, so many looks elsewhere. I would look into the Rad Flo suspension, sold by Overland Warehouse if you do not need Resi's (which most do not, I think I only know about 5 other guys running resi's on 4Runners). The Rad Flos were valved and designed specifically for 4th gen 4Runners are work GREAT with guys with bumpers and extra weight, like you will soon have. And I am 22.
Build Thread 2008 Sport Edition 4WD V6- Shadow Mica Fox 2.5 Extended Travel Resi Coilovers|Camburg UCA's|Fox 2.0 Piggybacks|Icon Coils|Timbren Bump Stops|TC Diff Drop|RB 1.5" BL|Gusseted Frame|Spidertrax|SW Sliders|Black FJ Wheels|6000k HID's|(4)KC Slimlites|Bajarack with Lightcage|255/80/17 BFG MT KM2's|TRD Exhaust|Factory Nav|Garmin eTrex|Cobra 75|Wilson 5000 |
Thanks guys. Those wheels were an awesome upgrade. I actually posted a WTB for some FJ wheels on the FJ forum and some guy said I could come have his for free, but they had some bad rock rash from wheeling. Since I was planning on painting them that was fine by me. Just took an afternoon of sanding and spraypaint and I had the final product. Only cost me about $30-40 to get 5 black FJ wheels, pretty good deal
Lubbock did get snow last week but nothing that stuck. On the whole, Lubbock has seen more winter precipitation this year than I can recall for nearly the last decade.
2007 SR5 4WD V8 |
Cornfed 3/2 and Timbren a good solution?
Hi All,
First time poster needing some help. I have a 2008 4Runner limited w/ XREAS. I carry a motorcycle on a hitch carrier that causes some sagging in the rear and extends out far enough that it sometime will drag the ground over dips. After reading several posts I think that maybe the Cornfed 3/2 is a good choice and maybe the Timbren system stops too. Any thoughts or recommendations? Thanks! John |
are you ever going to get a baja prerunner bumper???
MATT-X,
No need to dream...you can make it happen!! I wheeled w/ Todd (crazydubman) a few times...he's a great guy. Message him...he'll teach you what he did w/ his 4Runner.
. -Kenny- . • 2007 Toyota 4Runner V6 SR5 4WD - Titanium Metallic Daystar Spacer Lift 2.5/1.5 (Preload/Topout)|P265/70R17 Bridgestone Dueler A/T Revos|XenonDepot H11 4300k Xtreme HID Kit|Weathertech Floor & Cargo Liners|Rear Axle Diff Breather Extension|Color Matching Grill|Debadged Emblems|FatCat6|Soon/Wishlist|CB Radio|BL 1"|Demello Bolt On Sliders|Icons or Radflo|BajaRack or Rola Rack |
| Thread Tools | |
| Display Modes | Rate This Thread |
