#1 (permalink) |
Registered User
TSB: Technical service bulletins 4th gen T4R
This is a great resource thread. I'm going to stick it and lock it. If you would like to add a TSB PM me and I'll do it or unlock it for you. By locking it I'm avoiding this becoming a "discussion thread" and leaving it as an information thread.
Thank-you CBR GUY IA ![]() Chris aka CJ3Flyr I saw a sticky somewhere that had the TSBS, but you had to pay for the whole thing.. Here are all the tsbs and info for the 2003 4.0.. These are the copied/pasted bulletins. These bulletins don't have the pictures with them. It would take thousands of hours to save each picture to my computer, upload the picture then link them in the correct place..Not even consdering the time it would take to figure out where each picture goes. Without the pictures the bulletins and service information is incomplete. The flow charts, most Vin break points, etc are mostly listed in the pictures. Consider this general information. If you want want to view the bulletin in its entirety I would HIGHLY recommened a subscription to ALLDATA. They list all models for the specific year and model build. They also list the OEM service procedure in it's entirety. on top of that it has a very easy interface and even lists how long a job takes. Imagine taking your car to the dealer. They call you and tell you that your fuel injectors need replaced. They want to charge you $1000 labor plus parts. You jump on alldata find out that it only takes 3 hours to do the job. Basically 3 hours repair plus diag and they "claim" $1000 in labor. IT WILL PAY FOR ITSELF in one single service visit. All Technical Service Bulletins Number Date Title SB0301-08 09/19/2008 Engine - Serial Number Locations SB0289-08 09/09/2008 Body - Moon Roof Stuck/Improper Operation SB0258-08 09/02/2008 Restraints - Seat Belt Tongue Plate Stopper Replacement SB0144-08 07/31/2008 Vehicle - Certification Label Information SB0142-08 07/29/2008 Body - Upper/Lower Windshield Tick Noise SB0138-08 07/21/2008 Body/Frame - Protective Wax Coating Information SB0053-08 05/08/2008 A/T, M/T - Alignment Pin Service Precaution SB0020-08 03/25/2008 ABS/TCS - Zero Point Calibration Information EG049-07 12/05/2007 Engine - Oil Leak From The Timing Cover PG007-07 11/20/2007 Vehicle - Replacement VIN Plate Information EL010R-07 11/10/2007 Keyless Entry - Remote Transmitter Programming Guide DL003-07 11/08/2007 Drivetrain - Front/Rear Differential Oil Spec. Change PG005R-03 10/04/2007 Wheels/Tires - Spare Tire Carrier Operation Information SS006-07 08/11/2007 Battery - Absorbed Glass Mat Battery (AGM) Information Page 2 SS004-07 08/06/2007 Restraints - SRS Component Disposal EG034-07 06/28/2007 Engine Controls - Bank 1/Bank 2 O2 Sensor identification AC002-07 05/18/2007 A/C - Blower Motor Ice Build-Up SS002-07 04/26/2007 Engine Controls - ECU Flash Reprogramming Procedure NV003R-04 04/11/2007 Interior - 2nd Row R/H Seat Back Noise ST005R-01 03/21/2007 Steering/Suspension - Vehicle Pull Manual Supplement TC003-07 03/06/2007 Drivetrain - Driveshaft Replacement Precautions AU001R-06 02/26/2007 Audio System - Quick Reference Diagnostic Guide EL006R-05 12/21/2006 Charging System - 'Charge' Warning Lamp ON EL014-06 12/12/2006 Daytime Running Lights - Deactivating PG001R-06 11/28/2006 Electrical - Battery Maintenance and Testing NV011-06 10/20/2006 Interior - Driver's Seat Noise/Shifting Sensation CRIB146 09/01/2006 Body - Paintless Dent Repair Information NV005-06 06/16/2006 Interior - Front Seat Track Squeaking Noise PG011R-05 06/09/2006 Fuel System - Fuel Injector Cleaning Procedure EL006-06 05/23/2006 Body Electrical - Erratic Back Door Functions EG029-05 05/01/2006 Fuel System - MIL ON/DTC's Set/No Start in Extreme Cold EG043R-05 05/01/2006 Fuel System - MIL ON/DTC's/No Start in Extreme Cold BO017R-03 04/24/2006 Body - Interior Trim Panels/Garnish Loose BR004-06 03/17/2006 Brakes - Inconsistent/Unusual Brake Pedal Feel Page 3 EL006R-05 01/31/2006 Charging System - 'Charge' Warning Lamp ON BO022R-04 12/09/2005 Restraints - Seat Belt Extender Availability/Application BO001R-05 11/30/2005 Body - Sunroof Components and Service Procedures SS003-05 11/28/2005 Audio System - CD Player Skip Verification EG012R-03 11/18/2005 Engine - Accessory Drive Belt Squealing/Chirping Noise BO014-05 11/10/2005 SRS/Interior - Seat Cover Replacement Caution PA002R-02 10/17/2005 Paint - Paint Stains Under Rapgard AC004R-05 09/12/2005 A/C - Erratic Blower Motor Operation ST001R-05 09/08/2005 Steering - Highway Speed Steering 'Flutter' Page 4 SS003R-02 08/26/2005 Antitheft - Diagnostic Tester Immobilizer Function PG018R-02 08/19/2005 Body - Power Window/Moonroof Initialization EL011-05 06/03/2005 A/C - Inoperative/A/C Light Flashing EG014-05 03/28/2005 Cooling System - Radiator Cap Inspection Procedure PA003R-02 02/14/2005 Paint - Refinishing Bumper Cover EG005-05 02/11/2005 Engine Controls - MIL ON/DTC'S P0136/P0156 Set EG020R-03 01/06/2005 Emissions - MIL ON/DTC P0441, P0442/P0446 EG048R-04 01/06/2005 Emissions - LEVII EVAP System Check for Multiple DTC's TC002R-03 12/21/2004 Engine/Transmission Controls - Resetting ECM Memory PA005R-04 12/16/2004 Paint - Iron Rust Contamination Repair AC009-04 12/16/2004 A/C - Sensor Inspection Procedures TC009-04 12/15/2004 A/T - A340 Solenoid Identification BO010R-04 10/12/2004 Interior - Rear Seat Arm Rest Cup Holder Replacement NV013R-03 09/07/2004 Body - Moonroof (Sliding Roof) Rattles Page 5 EL009-04 08/10/2004 Electrical - Power Window/Roof Initialization Procedure BO013-04 06/15/2004 Interior - Accidental Seat Adjustment Handle Contact EG015-04 05/27/2004 Exhaust System - Excessive Sulfur Dioxide Odors DL001R-04 05/12/2004 4WD System - ECU Service Precautions BO005R-04 04/28/2004 Body - Windshield Molding Deformed/Warped BO007-04 04/28/2004 Interior - Front Seat Track Cover Removal NV002-04 03/17/2004 Body - Body Mount Noise EL003-04 03/03/2004 Electrical - 'Crank Hold System' Jump Starting BO001-04 01/14/2004 Body - Rear Door Support Improvement SS002-03 12/17/2003 Engine Controls - O2 Sensor Monitor Threshold Values BR005-03 12/04/2003 Brakes - VSC Lamp ON/DTC P1203 Set NV013R-03 11/20/2003 Body - Moonroof Rattling Noise EL016-03 10/24/2003 Immobilizer System - Service Procedures Clarification BO019-03 10/17/2003 Wipers/Washers - Poor Rear Wiper Performance NV006R-03 09/30/2003 Interior - Rear Seat Arm Rest Cup Holder Rattles Page 6 SS004R-01 09/23/2003 Engine Controls - Error When Reprogramming ECU SS002R-01 09/22/2003 Engine Controls - ECU Reprogramming Procedure CRIB136 09/01/2003 Body - Full Frame Components & Precautions SU005-03 08/28/2003 Suspension - Squeak Noise From Front on Sharp Bumps EL002R-03 07/29/2003 Instruments - Maintenance Reminder Light Resetting EL010-03 06/20/2003 Instruments - Difficult to Read AU003-03 06/13/2003 Audio System - JBL System Static Noise NV003R-03 06/11/2003 Body - Moonroof/Headliner Rattles EL009-03 06/04/2003 Navigation System - Map Screen Is Blank CRIB130 05/01/2003 Body - High Strength Steel (HSS) Locations CRIB127 05/01/2003 Glass - Windshield and Fixed Glass Bonding CRIB129 05/01/2003 Paint - Paint Codes - All NV004-03 04/26/2003 Interior - Front Seats Squeak/Creak NHTSA03V146000 04/01/2003 Recall 03V146000: Fuel Pulsation Damper Replacement EL008R-02 02/28/2003 Keyless Entry - Transmitter Programming & Identification EG003-03 02/24/2003 Exhaust System - Sulfur Smell Page 7 CRIB122 02/01/2003 Body - Body Sectioning BO021-02 12/18/2002 Interior - Upper Console Box Removal Precautions PA007-02 12/13/2002 Paint - Paint Colors PG027-02 12/04/2002 Steering/Suspension - Ball Joint Inspection NV010-02 11/28/2002 Interior - Front Seat Squeak/Creak Noise NV009R-02 11/14/2002 Interior - Headliner Rattles PA004-02 10/21/2002 Paint - Paint Colors - All BO017-02 09/30/2002 Interior - Seat Belt Extender Availability CRIB128 07/01/2002 Paint - Paint Codes EG007-02 03/22/2002 Valve Cover Oil Baffle - Damage Prevention BO010-01 9-12-07 Rust on tailgate I will add the bulletins in the same order as above. Last edited by CJ3Flyr; 02-16-2010 at 11:34 PM. |
| Sponsored Ad | # |
Advertisement
#2 (permalink) |
Registered User
-SB-0301-08
September 19, 2008 Engine Serial Number Location Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability Introduction The purpose of this TSB is to assist in the identification and location of engine serial numbers on 2000 - 2009 model year Toyota vehicles. NOTE When writing a Field Technical and/or Product Report the serial number of the engine MUST be provided. Warranty Information |
#3 (permalink) |
Registered User
T-SB-0289-08
September 9, 2008 Moon Roof Stuck/Improper Operation Service Category Vehicle Exterior Section Sliding Roof/Convertible Market USA Applicability TSB SUPERSESSION NOTICE The information contained in this TSB supersedes TSB No. BO016-06. ^ Applicability has been updated to include 2008 model year 4Runner vehicles. TSB No. BO016-06 is Obsolete and any printed versions should be discarded. Be sure to review the entire content of this service bulletin before proceeding. Introduction Some customers may experience a moon roof that exhibits improper operation such as: ^ The moon roof does not close from its fully open position (an improper jam protection operation occurs). ^ The moon roof is stuck due to a difference of alignment between the right and left parts of the moon roof. ^ Sliding parts are stuck due to hardened grease. Perform the following repair procedure to correct these conditions. Warranty Information APPLICABLE WARRANTY ^ This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date. ^ Warranty application is limited to correction of a problem based upon a customer's specific complaint. Parts Information Kit Contents The plastic tubes are NOT required for this TSB. Repair Procedure NOTE Perform the same procedure for both the RH and LH sides. 1. Remove the gear assembly. A. Open the moon roof approximately 75% and then remove the ignition key. B. Release the two (2) metal clips (behind the sunglass holder) by gently pulling down the front of the map light assembly. C. Disconnect the connector and remove the map light assembly. D. Remove the two (2) bolts disconnect the motor connector and then remove the gear assembly. 2. Remove the roof wind deflector. A. Using a flathead screwdriver hold down the guide block release lever and push the plastic clip forward. B. Slide the guide block backwards and out. Repeat for the other side and remove the wind deflector. NOTE To prevent breakage of the guide block release lever when the outside temperature is below 40°F (4°C), use a heat gun to raise the temperature of the guide block and surrounding aluminum housing to at least 65°F (18°C). Be careful NOT to damage components or paint with the heat gun. 3. Disconnect the wind deflector rod. A. Place a screwdriver against the rail in the notch area shown in the illustration and pry the rod to disconnect. B. Secure the rod with a piece of cloth. Place the cloth between the rod and track to keep it out of the way. 4. Remove the moon roof wind deflector guide rail holder. A. Place a flathead screwdriver against the stepped portion of the holder and lightly tap the screwdriver using a hammer to release the holder. B. Move the holder toward the front of the vehicle by pushing it with the screwdriver and remove it from the rail. 5. Replace the grease. A. Using a piece of cloth or scraper remove the old grease from the holder-sliding surface on the rail and the deflector arm. NOTE Remove the grease on both the RH and LH sides. B. Install the NEW holder (P/N 63257-35040/50 included in repair kit P/N 63207-35040) to the rail by performing the removal procedure in reverse order. C. Push the rod into the holder. NOTE Make sure the wind deflector rod is installed in the guide block's towards the most forward position. D. Apply grease (P/N 09170-35010 included in the repair kit) to the contact surface between the holder and the rail and the groove (deflector arm installation portion). 6. Install the roof wind deflector by performing the removal procedure in the reverse order. NOTE Install the front tab first, then slide back, and snap into position. 7. Align the drive cable holders. A. Place a flathead screwdriver against the stepped portion of the holder and push the holder toward the front of the vehicle to move the deflector to the half-up position. Align the RH and LH holder positions. B. Install the gear assembly and connect the map light assembly. Operate the moon roof switch to move the slide panel to its fully closed position. C. Remove the two (2) moon roof side garnish pieces by releasing the locking clips (pull gently). D. Remove the moon roof panel and gear assembly. Set the moon roof system to the fully closed position. NOTE Be careful when removing the Torx screws for the moon roof panel to prevent damage to the screws. (1) Using a flathead screwdriver push the bracket of the cable assembly forward. (2) Align the protrusion of the link to the center marking of the bracket. 8. Install the moon roof drive gear assembly the moon roof panel and the side garnish. Moon Roof Glass Assembly Mounting Screw. Torque: 4.0 N*m (41 kg*cm, 35 in*lbf) Moon Roof Drive Gear Assembly Mounting Bolt. Torque: 5.4 N*m (55 kg*cm, 48 in*lbf) 9. Initialize the moon roof. A. Press the moon roof switch on the "TILT-UP" side and hold the button (the button may have to be held for up to 10 seconds). ^ The moon roof will lock in the fully tilted up position. ^ Then, the moon roof will move down a few millimeters. B. Release the switch - initialization is complete. C. Cycle the moon roof through all the operating modes (including auto-open and auto-close modes) to make sure the moon roof functions properly. 10. Install the connected map lamp assembly. |
#4 (permalink) |
Registered User
T-SB-0258-08
September 2, 2008 Seat Belt Tongue Plate Stopper Replacement Service Category Vehicle Interior Section Seat Belt Market USA Applicability TSB SUPERSESSION NOTICE The information contained in this TSB supersedes TSB No. BO017-07. ^ Applicability has been updated to include 2008 model year vehicles. TSB No. BO017-07 is Obsolete and any printed versions should be discarded. Be sure to review the entire content of this service bulletin before proceeding. Introduction For situations where only the seat belt stopper is broken a new service part has been developed to eliminate the need to replace the entire seat belt assembly. Follow the installation procedure below to utilize this new part. Warranty Information APPLICABLE WARRANTY ^ This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date. ^ Warranty application is limited to correction of a problem based upon a customer's specific complaint. Parts Information Repair Procedure 1. Shift the tongue plate to the upper portion of the tongue plate stopper and temporarily hold it with a clip or tape. 2. Remove any pieces of the original tongue plate stopper in the webbing with a pair of diagonal pliers. NOTE Be careful not to damage the webbing, since this may compromise the safety of this seatbelt. CAUTION Damaged or weakened seat belts may break in an accident and injure the occupant. The seat belt assembly MUST be replaced if: ^ The webbing is cut, frayed, worn, or damaged. ^ It has been used during a severe impact (inspect the label to ensure no impact damage has occurred) Inspect the entire length of webbing for damage and replace the assembly if needed. Be careful NOT to damage the webbing during repair. 3. Install the NEW tongue plate stopper A. Install a NEW tongue plate stopper in the hole of the webbing. NOTE Be sure to install the stopper in the correct direction as shown in the illustration. B. Pinch the tongue plate stopper into the webbing using the tool shown in Figure 3 or use a small "C" clamp. NOTE To prevent damage to the plastic tongue plate stopper when using a "C" clamp device, use light to moderate clamping force when crimping the two halves of the tongue plate stopper together. HINT Press the adjustment screw locating the male and female parts of the tongue plate stopper parallel to each other. CAUTION For this procedure, do not use pliers. They may damage the webbing. C. Tighten the c-clamp until the space between its jaws are 4.5 - 5.0 mm (0.18 in. -0.20 in.) Figures 5 & 6 D. Verify the male pin of the tongue plate stopper has deformed evenly in the hole of the female part and is firmly held to the belt webbing. |
#5 (permalink) |
Registered User
T-SB-0144-08
July 31, 2008 Replacement Certification Labels Service Category General Section Identification Market USA Applicability TSB SUPERSESSION NOTICE The information contained in this TSB supersedes TSB No. PG008-07. ^ The Notes in the Certification Label Criteria section and in the "Application for Replacement Certification Label" form have been updated. ^ The Note in the Procurement Procedure section has been removed. TSB No. PG008-07 is Obsolete and any printed versions should be discarded. Be sure to review the entire content of this service bulletin before proceeding. Introduction Replacement Certification Labels (vinyl label installed on driver's door or door post) may be available from Toyota providing the request meets one of the criteria listed in this TSB. Warranty Information Certification Label Criteria (please see important note below) A replacement certification label may be requested if: ^ The vehicle is in an accident and the label is damaged or is attached to a part that will be replaced during the repair. ^ The label is stolen. IMPORTANT NOTE ^ To expedite your request, please provide a clear, legible photograph of the certification regulation label along with the original label. This will allow TMS Technical Compliance to obtain information from the original label which is not easily available elsewhere. We may be unable to create a replacement label if this material is NOT submitted. ^ All replacement certification regulation labels for damaged and/or stolen vehicles are subject to approval by TMS Technical Compliance. If you have specific questions, please. Procurement Procedure To request a replacement label complete a copy of the form at the end of this bulletin. Your dealer parts account will be billed for each replacement of a damaged or stolen label. |
#6 (permalink) |
Registered User
T-SB-0142-08
July 29, 2008 Upper/Lower Windshield Tick Noise Service Category Vehicle Exterior Section Window/Glass Market USA Applicability TSB SUPERSESSION NOTICE The information contained in this TSB supersedes TSB No. NV009-06. ^ Applicability has been updated to include 2008 model year applicable vehicles. TSB No. NV009-06 is Obsolete and any printed versions should be discarded. Be sure to review the entire content of this service bulletin before proceeding. Introduction If a creak tick or rattle noise is heard at the top or bottom of the windshield the source of the noise may be the two windshield stoppers bonded to the top of the windshield or the windshield retainers bonded to the lower edge of the windshield. This bulletin provides the recommended repair procedure to eliminate these types of noises from the windshield area. NOTE Some vehicles have both stoppers and retainers while others may only have stoppers at the top of the windshield. Use the chart in this bulletin to determine the location of the windshield locating pins. Warranty Information ^ This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date. ^ Warranty application is limited to correction of a problem based upon a customer's specific complaint. Required Tools & Equipment Additional SSTs may be ordered by calling SPX/OTC at 1-800-933-8335. Pin Locations Repair Procedure Upper Windshield Glass Stoppers: 1. Remove both sun visors and both A-pillar garnishes and then carefully lower the front of the headliner to gain access to the windshield stoppers (refer to the appropriate model year Repair Manual for the proper procedure). NOTE It is very important that the front of the headliner be lowered carefully and slowly. Applying too much downward force on the headliner will cause it to develop a permanent crease in the surface material. The stoppers are located on the inside of the passenger compartment behind the windshield glass blackout section (near the top front edge of the metal roof opening). The stoppers are typically located 20 - 25 cm (7.9 - 9.8 in.) inboard of the top corners of the windshield glass. 2. Cut OFF the tip of the plastic stopper as shown in Figure 3. HINT It is sometimes necessary to bend the metal body tab down to gain access to the shaft of the stopper. 3. Once the tip of the stopper has been removed use a screwdriver to open a gap between the roof panel and the remainder of the plastic windshield stopper. 4. Test drive vehicle prior to reassembly to confirm that the noise has been eliminated. 5. Reassemble the vehicle. Lower Windshield Retainers: 1. Carefully remove the plastic cowl cover at the base of the windshield and store it in a safe location for reinstallation later (refer to the appropriate model year Repair Manual for the proper procedure). 2. Locate the lower windshield retainers. The retainers are typically located 140 - 200 mm (5.5 - 7.9 in.) inboard of the lower corners of the windshield. The flat portion of the retainer is adhered to the backside of the windshield with double-sided foam-backed tape. 3. Use a "Mini" Hacksaw with a fine tooth 10-inch blade to cut OFF the pin portion of the glass retainer flush with the flat portion of the windshield retainer as shown in Figure 6. 4. Test drive the vehicle to confirm the elimination of the noise. 5. Reassemble the vehicle. |
#7 (permalink) |
Registered User
T-SB-0138-08
July 21, 2008 Permanent-Type Protective Wax Coatings Service Category Vehicle Exterior Section Paint/Coatings Market USA Applicability Introduction Toyota uses two types of permanent protective wax coatings; one is yellow-brown and the other is black. The yellow-brown (cavity wax) is used for interior body panels (i.e. hoods trunk lids doors engine compartment components etc.). The black (underbody wax) is used on the underside of the body floor separate frame (if equipped) as well as inside the fenderwell areas. Both types of waxes provide substantial corrosion protection to the aforementioned areas and components. These permanent-type protective wax coatings should not be removed from the vehicle unless body work is to be done in an area coated with the protective wax. It is essential that these wax coatings be restored to areas where the wax was removed during body repairs. Replacement wax coatings are available from local automotive chemical suppliers. NOTE :^ Any underbody wax that has been inadvertently sprayed on the exhaust system by the factory will normally dissipate in a few miles. Warranty Information Parts Information Cleaning Procedure If necessary removal of any wax coating overspray on the exterior paint finish may be removed easily with Toyota bug and Tar Remover. Be sure to wash the paint surface with Toyota Liquid Car Wash before using the Bug and Tar Remover (this will prevent scratching of the paint surface from dirt trapped in the wax coating.) |
#8 (permalink) |
Registered User
T-SB-0053-08
May 8, 2008 Alignment Pin Installation during Transmission/Transaxle Assembly Installation Service Category Drivetrain Section Automatic Transmission/Transaxle Market USA Applicability Introduction The purpose of this TSB is to provide information regarding the installation of alignment pins during transmission/transaxle assembly installation. Missing alignment pins may result in incorrect alignment and failure of the transmission/transaxle assembly. Use the information below when installing a transmission/transaxle assembly. Parts Information Warranty Information Repair Procedure 1. Inspect the rear side of the engine block assembly for 2 alignment pins. ^ If there are less than 2 alignment pins present one may have been removed with the transmission/transaxle assembly. Check the removed assembly for the missing alignment pins. Go to step 2. ^ If there are 2 alignment pins present the transmissionltransaxle assembly may be installed following the applicable Repair Manual procedure. NOTE :A missing alignment pin may result in failure of the transmissionltransaxle assembly. 2. Install the missing alignment pin(s). ^ Refer to the applicable Repair Manual procedure for location of the cylinder block rear side alignment pins. NOTE In the Repair Manual, the alignment pin is referred to as a "straight pin." |
#9 (permalink) |
Registered User
T-SB-0020-08
March 25, 2008 Disconnect Battery & Perform Zero Point Calibration After Wheel Alignment Adjustment Service Category Brake Section Brake Control/Dynamic Control System Market USA Applicability Introduction The purpose of this TSB is to provide information on when and how to perform the zero point calibration on vehicles equipped with Vehicle Stability Control (VSC). Momentarily disconnecting the battery is a necessary step for performing the zero point calibration. Warranty Information Required Tools & Equipment ^ Additional TIS techstream units may be ordered by calling Approved Dealer Equipment (ADE). ^ The Toyota Diagnostic Tester and CAN Interface Module may also be used to perform the service procedures listed in this bulletin. Preliminary Information Perform this procedure if any of these repairs have been performed on the vehicle: ^ Wheel alignment has been adjusted. ^ Any chassis components have been removed/installed or replaced. Repair Procedure 1. Disconnect the cable from the negative (-) battery terminal for MORE THAN two (2) seconds. 2. Reconnect the cable to the negative (-) battery terminal. 3. Perform the applicable zero point calibration of the yaw rate sensor and/or the steering angle sensor. HINT Refer to the applicable TSB or Repair Manual for the zero point calibration procedure. 4. Re-initialize all applicable systems available on the vehicle (power window sunroof power lift door etc.). |
#10 (permalink) |
Registered User
ENGINE
EG049-07 Title: OIL LEAK FROM FRONT TIMING COVER Models: '03 - '07 4Runner (1GR-FE) December 5, 2007 Introduction Some 2003 - 2007 model year 4Runner vehicles with 1GR-FE engines may display evidence of a small oil leak located where the Bank 1 cylinder head, engine block, and timing cover meet. Use the following repair procedure to address this condition. Applicable Vehicles ^ 2003 - 2007 model year 4Runner vehicles equipped with the 1GR-FE engine and produced BEFORE the Production Change Effective VINs shown below. Production Change Information Warranty Information Applicable Warranty*: This repair is covered under the Toyota Powertrain Warranty. This warranty is in effect for 60 months or 60,000 miles, whichever occurs first, from the vehicle's in-service date. * Warranty application is limited to correction of a problem based upon a customer's specific complaint. Required Tools & Equipment Repair Procedure 1. Inspect the location where the Bank 1 cylinder head, engine block, and timing cover meet for signs of an oil leak. 2. Use an oil dye to confirm the source of the oil leak. 3. Remove and reseal the timing cover if confirmed leaking. Refer to the Technical Information System (TIS): 2003, 2004, or 2005 model year 4Runner Repair Manual, Engine/Hybrid System - Engine Mechanical - "Timing Chain or Belt Cover Sub-Assy (1GR-FE): Replacement" ^ 2006 or 2007 model year 4Runner Repair Manual: ^ Engine/Hybrid System - Lubrication - "1GR-FE Lubrication: Oil Pump: Removal" ^ Engine/Hybrid System - Lubrication - "1GR-FE Lubrication: Oil Pump: Installation" 4. Confirm that the repair corrected the condition. |
#11 (permalink) |
Registered User
PRODUCT GENERAL INFORMATION
PG007-07 Title: REPLACEMENT VIN PLATES Models: All Toyota Models November 20, 2007 TSB UPDATE NOTICE :The information contained in this TSB supersedes TSB No. PG009-02. TSB No. PG009-02 is now obsolete and should be discarded. The changes will take place January 1, 2008. Introduction Replacement VIN plates (metal plates riveted to dashboard) may be available from Toyota providing the request meets the criteria listed in this TSB. Applicable Vehicles ^ All Toyota vehicles. Warranty Information Replacement VIN Plate Criteria A replacement VIN plate may be requested ONLY if: ^ The vehicle is in an accident and the VIN plate is damaged. ^ The vehicle was stolen and the VIN plate is damaged but still available. NOTE : ^ The original VIN plate being replaced MUST accompany the request. ^ If the VIN plate is stolen, be sure to contact the State Police or your State's Department of Motor Vehicles (DMV). In most cases, the State DMV will issue a unique number so that the original number can be included on stolen vehicle listings. If this is the case, a replacement VIN plate is NOT available from Toyota. However, the original VIN, NOT the state issued VIN, must be used on all warranty claims. Procurement Procedure To request a replacement VIN plate, complete a copy of the form at the end of this bulletin. Note that the damaged VIN plate MUST accompany the request form. Your dealer parts account will be billed $40.00 for each replacement of a damaged VIN plate. All replacement VIN plates are subject to approval by the Technical Compliance Department. If you have any specific questions, contact them. |
#12 (permalink) |
Registered User
ELECTRICAL
EL010-07 REVISED Title: WIRELESS TRANSMITTER & PROGRAMMING GUIDE Models: '90 - '08 Applicable Toyota November 9, 2007 TSB REVISION NOTICE : ^ November 10, 2007: A TSB reference has been updated in the Programming column of the Application Chart. Previous versions of this TSB should be discarded. TSB UPDATE NOTICE :The information contained in this TSB supersedes TSB No. EL008-02. TSB No. EL008-02 is now obsolete and should be discarded. Introduction Difficulties during Remote Keyless Entry (RKE) Transmitter Programming can arise due to confusion between Toyota Factory Wireless systems and Toyota Port/Dealer installed systems. This bulletin will assist in identifying the system/correct remote transmitters for each vehicle, and provide the location of the most accurate programming procedure for each system. Applicable Vehicles ^ 1990 - 2008 model year applicable Toyota vehicles. Warranty Information System Identification The Application Chart contains all of the necessary information to correctly identify the type of system installed, and where to go to get programming procedures for each vehicle. Should a vehicle having both VIP and Factory systems available (as identified in the Application Chart) be brought in without any remotes (or one non-working remote), use the following tips to help determine which type of wireless system (O.E. or PIO/DIO) the vehicle has. ^ Look at the Trim Level of the vehicle. Higher-grade vehicles will tend to have O.E. systems, while entry-grade vehicles will tend to have VIR For example, the 2001 Camry XLE has Factory WRKE, but the LE and CE grades have VIR ^ Look for a "Status Monitor" with a glass breakage sensor and an LED externally installed into the dashboard or on the center console. Most VIP systems will have this. ^ Locate the ECU (refer to the applicable vehicle VIP Manual installation instructions for location). Once located, refer to the part label. ^ Attempt to perform the factory wireless programming procedure to get a response from the vehicle. Select the "confirmation mode" and see if any "Lock/Unlock" response is received, if so, the vehicle has a factory system. Application Chart Wireless Transmitter Identification |
#13 (permalink) |
Registered User
DRIVELINE & DIFFERENTIAL
DL003-07 Title: FRONT AND REAR DIFFERENTIAL GEAR OIL SPECIFICATION CHANGE Models: '03 - '08 4Runner & '07 - '08 FJ Cruiser November 8, 2007 Introduction The differential gear oil used in 4Runner and FJ Cruiser vehicles has been changed to a 75W-85 GL5 synthetic gear oil beginning with the 2008 model year. This new synthetic gear oil is compatible with 2003 - 2007 model year 4Runner and 2007 model year FJ Cruiser differentials. Please refer to the Parts Information section below for information about this gear oil and use this gear oil (or equivalent) when filling front or rear differentials with oil. Applicable Vehicles ^ 2003 - 2008 model year 4Runner vehicles. ^ 2007 - 2008 model year FJ Cruiser vehicles. Parts Information Refer to the diagram below to identify if LSD or non-LSD gear oil is used on the vehicle. For applicable vehicles, there is a caution label above the filler plug, as shown below. Warranty Information |
#14 (permalink) |
Registered User
PG005-03 REVISED Title: SPARE TIRE CARRIER OPERATION Models: '91 - '08 Land Cruiser, '96 - '08 4Runner & Tacoma, '98 - '08 Sienna, '00 - '08 Tundra, '01 - '08 Sequoia August 19, 2003 TSB REVISION NOTICE : ^ October 4, 2007: 2007 - 2008 model years have been added to Applicable Vehicles. ^ September 27, 2005: 2005 - 2006 model years have been added to Applicable Vehicles. The previous TSB should be discarded. Introduction The spare tire carrier may become damaged if an impact wrench or any other type of power tool is used to raise or lower the spare tire. The Owner's Manual, as well as a label near the drive nut, warns against the usage of an impact wrench or other power tools. Applicable Vehicles ^ 1991 - 2008 model year Land Cruiser vehicles. ^ 1996 - 2008 model year 4Runner and Tacoma vehicles. ^ 1998 - 2008 model year Sienna vehicles. ^ 2000 - 2008 model year Tundra vehicles. ^ 2001 - 2008 model year Sequoia vehicles. Operation Procedure Refer to the vehicle's Owner's Manual for vehicle specific instructions. 1. Locate the drive nut for the spare tire carrier. Refer to the vehicle's Owner's Manual for specific location. 2. Using the hub nut box wrench from the vehicle's tire tools kit, lower the spare tire to the ground. 3. Remove the tire from the carrier. 4. Installation of the spare tire is the reverse of removal. Warranty Information |
#15 (permalink) |
Registered User
SPECIAL SERVICE TOOLS
SS006-07 Title: ABSORBED GLASS MAT (AGM) BATTERY INFORMATION Models '01 - '08 Toyota August 11, 2007 Introduction This TSB provides background on the differences and similarities between AGM (Absorbed-electrolyte Glass Mat) batteries and flooded lead acid batteries. It also explains charging procedures performed by the GR8 Battery Diagnostic Station (SST P/N 00002-MCGR8) and its ability to charge AGM batteries at higher current levels then a standard battery charger. Applicable Vehicles ^ 2001 - 2008 model year Toyota vehicles equipped with an AGM battery. Required Tools & Equipment Warranty Information Battery Comparison Differences between AGM and flooded lead acid batteries: ^ AGM batteries have thin, sponge-like, glass mat separators that absorb all liquid electrolytes. ^ Flooded lead acid batteries have free, liquid electrolyte all around the plates and separators. ^ Flooded lead acid batteries can easily release gas that is formed during a charge, while AGM battery life is diminished if gas is formed during charging. Similarities between AGM and flooded lead acid batteries: ^ Both share the exact same lead acid chemistry. ^ Both share the same charge and discharge principles. ^ Both are safely charged by vehicle charging systems. ^ When discharged, both can be recharged at high current levels. Battery Charging Information Damage to AGM batteries becomes an issue when the charge rate is NOT monitored and controlled by the charger (i.e., quick chargers). The performance of an AGM battery can be irreversibly reduced if the charge rate remains too high, allowing the battery to overheat and vent. Once an AGM battery loses water (venting), the glass mats will become dry, causing the battery to lose conductance, power, and performance. In most vehicle charging systems, the alternator limits the charging rate by limiting the output voltage (about 14.4V). For example, an AGM battery may be observed charging at 60A and 13.5V. As the battery recharges, the charging voltage will increase from 13.5V to approximately 14.4V (voltage will vary based on temperature, control sophistication, etc.), and the current will decrease from 60A to about OA. The charging system voltage regulators prevent both AGM and flooded lead acid batteries from being overcharged and venting. By controlling the voltage, the charging rate (current) can be controlled. The discontinued Special Service Tool (SST) Automatic Trickle Charger (SST P/N 00002-YA122-01) maintained a manual charging limit of 10A to accomplish a safe recharge rate for AGM batteries. This low amp charge was low enough to prevent the AGM battery from overheating and venting since the charger had no way of monitoring battery temperature/condition. The GR8 Battery Diagnostic Station (SST P/N 00002-MCGR8) is a customized diagnostic fast charger that monitors battery temperature/conditions and contains custom charging rates for ALL model batteries used for Toyota and Scion vehicles. As such, it safely charges good batteries as fast as possible to a point where they can be returned to service and eliminates wasted charging time by quickly diagnosing bad batteries. Based on the characteristics and performance measures of each individual battery (i.e., custom charging rate), the GR8 Battery Diagnostic Station will apply the fastest charging rate that is safe for that particular battery. ^ When the GR8 Battery Diagnostic Station pe~ormance measurements indicate that an AGM battery qualifies for fast-charging, it will be charged at whatever current level it will accept, but the charging voltage will be controlled so that it does NOT exceed 14.4V, and the battery temperature will NOT exceed 135°F (57°C). ^ When the GR8 Battery Diagnostic Station performance measurements indicate that an AGM battery does NOT qualify for fast-charging, the charge session will only continue if the battery qualifies for "Recovery" mode (part of which means, NO defects or other serious performance issues were found). It is recommended that ALL Toyota and Scion vehicle batteries be charged using the GR8 Battery Diagnostic Station. NOTE :^ NEVER connect the GR8 Battery Diagnostic Station to remote battery terminals. ^ ALWAYS connect the GR8 Battery Diagnostic Station DIRECTLY to the vehicle battery. For assistance on charging procedures, refer to the GR8 Instruction Manual or TSB No. PG001-06, "Battery Maintenance for In-Stock Vehicles & Pre-Delivery". The GR8 Instruction Manual can be found on the Technical Information System (TIS), Diagnostics - Battery - "GR8 Instruction Manual". |
| Thread Tools | |
| Display Modes | Rate This Thread |
