6 Inch lift on an 06 sport 4WD??
4Runner8
I got a friend with an 06 sport 4wd and he was wondering if he could get the toytec ultimate or icon lift kit then add 3 inch spacers on top of those ront and rear coils for a total of 6 inches. is this possible with those kits???
buy the toytec ultimate lift kit then put 3 inch spacers on top of the front and rear coils to get a 6 inch lift. whats not to get???
LOL tell him to buy some extenz. A 6" lift with spacers.... making up for something?? Lots of extra cost in diff drop, brake lines and more! do it lol post picturesSo Gay
that'll kill your truck dude. thats too high. you'd have to do some major work on it, and get the cv's to not crumble on the spot.
anythings possible..........all it takes is money!
the angle on the cv's would be ridiculous. it wouldnt work out.
it would take some engineering and fabricating to make it work correctly.
Yes it can and in my opinion SHOULD be done if your buddy has the money to do it. Since it is a 4WD the front diff would need to be dropped by means of a custom fabricated bracket. This is not as costly as some may believe it to be, just do your research or make friends with someone with a welder and some experience. This bracket would need to be made to where the CV joints were at an angle comparable to stock or just a little bit higher. The other task would be to extend all the lines that come from the truck down to the wheels/axles so that when you flex the suspension, there will be enough slack to no rip them apart. This includes brake lines and ABS lines. I'm sure there are probably more like your parking brake but you would have to get under it and look.
The other problem I see with it is the arms and stabilizers that connect to the rear axle as well as the components up front for the IFS that would be pushed way to far down. The rear can be taken care of pretty easily if you know what to extend, the front would be quite a bit harder, but I think you can work out some kind of long travel kit to work on it.
On another note, this would be pretty pricey, and as someone stated before, you could go with a 3" suspension lift and then a body lift as well. My buddy down the street did a 3" suspension and he fab'd up a 4" BL on his 03. He said it wasn't too hard and he has had no problems with the steering links at all.
Just make sure you do your research and work out everything that needs to be done before you start. Pull it apart and work out what you need. Then put it back together, go out and build what you need, and build it all in at once.
Hope this helps and good luck if you guys actually try to do it!! Don't let anyone tell you it can't be done or its gay. These people say it's because you may be making up for something... i say they don't do it because they don't have the balls to :satan:
Probably not, but with deep pockets anything is possible.
Honestly, are you posting just for the hell of it, because you're bored and have nothing better to do, or you're trying to get a rise out of the members? Please stop.
In the event you are serious, here is a 7" custom lift by member AlexJet. His entire build thread and the start of the custom lift on page 4.
Also, a 6" bracket lift will bring with it almost zero benefits if you actually off road, as it does not increase your clearance any more than a 3" lift
2" body and 3" ultimate lift would work. Unless you go custom or cut a lot of body then that's about as tall as I'd go.
why in the hell would post i this for the hell of it. my buddy asked if it could be done and i wasnt sure so i asked u guys. and he probably wont be able to just cause the money factor but thanks for the info anyways. learn new stuff everyday
3 inch toytec lift.
1.5 inch 4crawler body lift.
34" tires.
__________________________
total 6.5" taller then stock.
looks like this...
The body lift isn't very expensive. 4crawler.com. The OME lift is supposed to be 3" front and rear, but its more like 2" rear. This is why I added the cornfed 1.25" rear spacer in addition (not pictured).
Looks good
How high are your fenders from the ground? (Middle base of each fender)
_DSC1421-2.jpg~original
