Front Turn Signal Housing removal?
JIMXEOD
Noob here. Just picked up a nice 2005 Limited. On the left (drivers) side the turnsignal/DRL housing is cloudy, and after polishing, it is hazed on the inside? :mad:
How does this unit come out? I looked behind it and can't find out how it is attached. Does it just "pop" out? I did a search and all I found was bulb replacement, which is very obvious.
Also any leads on a reasonable replacement besides my local dealer?
I will eventually kill my DRL's as I hate them!
Thanks for the help guys!
just look under bumper closer, whole assembly held with 3 screws I believe. Easy to pull out
You can access the fog, and the front turn signal lamp assembly from the fender lines infront of the wheels.
also, here is a PDF attached on how to replace the turn signal...
i think you need to remove a screw and release a claw fitting.
  • x040001.pdf
    x040001.pdf
Correct. Note: To remove the turn signal you only need to remove the screw closest to the bumper i.e. for the driver's side signal all that needs to be removed is the screw located farthest to the left. Then tug on the housing from the front of the vehicle while pushing from behind and it will pop out.
That sounds right. I will try and remove that one screw/bolt and see if it pushes out. Sometimes they realease from the front by releasing a clip or something.
Anyway, thanks for the help. Any ideas on a cheap source for an OEM part like that?
Sorry to bump such an old thread, but replacing my Turn signals now.
How in the world do you release the claw fitting? I don't see any way to get to it.
There is 1 Screw in the turn signal and 2 or 3 on the Fog. Remove them. Push fog light out and Turn signal housing will come out with it because they are connected to each other then you can seperate them. Easier than trying to push Fog out by itself
with pictures, since I had to do this today..
Sorry for bumping an old thread.
I’m trying to replace both, but one side seems be stuck while I had no issues getting the other one off. I removed all 3 screws as shown in the earlier pic and tried to push out from back and pull from front.
Did you ever get this taken care of? How did it go? I want to try this today or tomorrow... :)
Oh. I had actually cut the original and when I put the new one on I realized you can tilt it (up/down with it facing you) and pull them apart, the fitting/tab keeping them together is like a hook.
How did you release the tabs?
Just had to remove the housing for a water filled turned signal. So hope you figured it out but if not there are 2 tabs on top of the housing frame that are black. Push those in and then using a flathead pry apart the grey housing that contains the lights from the black frame and it should pop forward right out.
Good luck!
Good luck!
I have not, I have an 05 sport and the only 2 tabs I see are on the side and are light grey. The previous link shows a thread that has pics on what to do, but I have tried to push in the tabs and they barely move. I’m tempted to just tear out the turn signal that I’m replacing so that there’s enough room to get the fog light out.
Front turn signal lens body replacement
the link shows a good explanation. make sure youve removed the three screws (green arrows) and then the blue tabs should be able to be popped with a flathead while pushing the entire housing from under bumper and delivering it outside. The fog and the turn light housing are tethered together and should pop out as one unit. you can seperate them by twisting them apart. hope that helps good luck.
Any decent upgraded after market turn signal assy.???.
Mine are cracked and looking poorly. Wish to upgrade them
I saw a blacked out version of the foglights.
Also any idea of the part number for the TS housing
US $49.91 30%OFF | Case for Toyota 4 Runner fog light 2003 2004 2005 halogen fog lamp Bulb HB4 12V 51W shipping free
Page Not Found - Aliexpress.com
