Highway driving
bbumbles
Hi I have a 08 limited with Xreas which probably does not matter but figure I would say it. Does anyone get blown all over the place on the highway when windy? If not any reason why?
thanks
Yes, it does wander in the wind - I've got 85k miles on my 2003 and it has done that from the very start. Probably a combination of a high vehicle, large side area, and suspension/alignment. Changing to Michelin CrossTerrains seemed to reduce it a bit over the OEM Dunflops, but it wasn't a huge change.
Considering the high profile of the body,I am quite surprised at how stable it is in windy conditions. And believe me we have wind here in Hurricane. Had Subaru station wagon that got pushed around more than this 4Runner.
Ok good to know it is not just me. My wifes 03 with 17" is better than the limited with 18"s seems to move allot more on the highway. Once my bridgestones wear out I think the michelins will help.
Interesting that I've noticed just the opposite. For a high profile vehicle with a considerable amount of side area, the 4R is pretty good about stability in my opinion. In the past I've owned Tahoe's, a double cab Tundra, full sized and smaller model Blazer, Aviator, etc. In fact I drove across west Texas in very heavy winds just a few weeks ago, had no problem.
Maybe you're coming from a lower profile small sided vehicle?
Try driving thru Colorado Rockies (mountains) with high heavy winds.
it has more to do with suspension than anything else cu zhonestly the 4R doesn't sit that high.
i've driven plenty of SUVs and the 4R wanders more noticeably.
I agree wanders more than any vehicle I have ever owned. I also owned an 04 limited without xreas and 17" tires and it wandered less but still wandered. I also had a tacoma which was ok a rav4 which was fine so i know it is not me it is the vehicle.
Suspension will have minimal effects on the AERODYNAMICS of a car, if any. Grwing up in the South, I've had my fair share of harsh winds. 4Runner did about as well as any other SUV or truck with aerodynamics of a shoe box. No matter how stiff or sloppy your suspension, the WIND will push you side to side.
Agreed. But it has a great deal to do with how it reacts to side forces and how well it tracks.
I also agree with you. However, IF the cross winds are strong enough to blow you across the lanes, I really doubt stiffer springs will be the remedy. Think about how much the stock springs deform in a moderate wind storm. 1" at best? Is that really enough to throw you off track? Doesn't jive with me, but I could be wrong.
I felt this from day 1 on the 4runner.. i just learned to deal with it.. other than that the ride is solid :thumb3:
It's not about spring stiffness. It is more about suspension geometry. There are plenty of large SUVs that don't wander as much on the highway as the 4Runner does.
And the wind doesn't have to "blow you across lanes" to cause the truck to wander.
My 4Runner does tend to wander more than my Daily Driver VW Golf. Then again, the 4Runner is considerably larger then the VW.
The 4Runner does wander a bit less when I am towing my enclosed trailer.
Probably has something to do with the additional weight along with the weight distributing hitch & dual cam sway control. :)
I don't think I'm getting my point across clearly. Ok, say you pull off on the side of the road during a wind storm. As the wind pushes against your car, how much does that affect the suspension? Very minimal amount. This is true whether you're standing still or going 70mph. It's aerodynamics that affects this wandering, not suspension. Anyway, this is how it made sense in my head.
This is my first Large vehicle and hardly take it to the highway, but last summer went on a roadtrip to Texas and the truck wandered just a little and maybe because we had to pass through a very bad thunderstorm almost all the way . But on the way back it felt normal...maybe bcause we had tons of things on the cargo area.
It was a smooth ride...
x2!
I would check alignment.
