How to change bulbs of T4R Limited running boards
You just access them from underneath, rotate the light socket counter-clockwise and pull out. Replace bulb and re-install.
The bulbs go in at a slight angle rather than straight. I find it easier to get the bulb socket back into the running board laying down.
anyone know if there is a specific fuse that lights these running boards? all four of mine do not come on, and there I tried replacing a bulb with a new one today, and still nothing.
I don't recall the name/label for that fuse. It's a 10A fuse in the fuse block behind the battery under the hood. That fuse supplies power to the dome lights and tripometer, maybe some other additional circuits.
update: after crawling a little under the runner, i noticed that one side had the wiring cut (passenger side) and the driver side looks pretty dirty. This is getting weird.
Bought the runner a few months ago, and it needed a little TLC as far as I know. Everything else works in the truck, dome light/trip/interior lights
