Originally Posted by Overland Warehouse
I tried fitting a Trail Gear crossmember to mount a skid plate, and the 4th gen 4Runner frame width was wider than the FJ. I assume this is because they shortened the frame.
All suspension parts are interchangeable.
The tank on the FJ is shorter if I recall correctly.
Wider really? Still haven't looked over the data on TIS, its on my list of stuff to look up for other threads. This week's been pretty busy so I haven't had much free time.
I was looking at an FJ Cruiser earlier today and had my 4Runner in a stall nearby. You should be able to fit the spare tank in there, but you will have to modify or remove the sparetire brace, and possibly make your own brackets. But physically it should be fine, the spare tire well is far larger than the rear section of the FJ Cruiser in terms of sq.ft.
