Exhaust manifold leak/tick
hamiltonj2w1
Ok so I just noticed this today I seem to have an exhaust manifold leak with the windows down at slow speeds you can hear a slight tick and after having my wife give it some gas while parked myself and a friend both listened to it and it doesn't sound like a valve or a rod or like the noisy V6 fuel injection anybody else have this problem and I looked for headers online and it seems nobody makes them for 03 to 07 V8's?
yes because the cats are part of the manifold on a V8 so they have to be changed as an assy. both my manifolds were cracked so i ended up getting all new manifolds, cats and exhaust right up to the muffler. fell under the emissions warranty.
what also might help is tell them you have the sulfur smell. they will change the cats under the TSB and the emissions warranty and you will automatically get the manifolds.
Mine is getting done right now. its a "all day" fix for Toyota, so expect not to have it for 10 hours
I think I've got it
Starting to think I have a cracked manifold. Passenger side I believe...
I hear an exhaust leak type ticking noise that was never there before.
Its most noticeable when cold and at low rpms when under load. I dont hear it all that much in park but in reverse with my foot on the brake its very noticeable. Also when taking off from a stop light you can hear it pretty easily...
I think stock manifolds are like $600/each and if I'm not mistaken there are no aftermarket options for 2005 V8 4runners. A competent welder may be able to repair the original as well. I've heard replacing them is a real PITA and takes many hours.
I will be pulling the manifold heat shield this weekend for a closer look...
I just noticed mine doing the same thing the other day. 03 V8 with 80K.
Started it in the garage and hear the tick. As soon as the exhaust warmed up, it went away.
Anyone found any aftermarket exhaust manifolds yet?
I have it too and the Toyota tech told me that is what it is. Mine only last for about 1-2 mins after start up then it goes away once it gets warm. Estimated repair cost at the stealership was $1500. They said it would not pass state safety inspection in VA but I live in MD and we don't have safety inspections after you title it.
Well after some talking with my dealer they looked at it and I have a cracked passenger side manifold and possibly the drivers side one as well the vehicle was warm and it goes away after the motor heats up. The cost to replace both manifolds is 1500 without labor and it is a 10hr job. My dealer won't replace them but they said they will take them off and have the cracks welded and reinstall them all at no cost.
Ticking and sulfer smell
Yep I have this issue as well on my 03' limited that I just bought about a month ago. You guys have given me the motivation to get this fixed, I wonder if it falls under the 3 month 3 thousand mile dealer warranty? Anybody? Rotten egg smell sucks.
Thanks!
03' limited w/nav, 22" Effen Hurricane rims, JL amps and subs.
Can anyone point to the actual warranty info on this?
T-SB-0342-09
September 21, 2009
Excessive Sulfur Odor
Service Category
Engine/Hybrid System
Section
Intake/Exhaust
Market
USA
Applicability
TSB SUPERSESSION NOTICE
The information contained in this TSB supersedes TSB No. EG005-06.
^ Applicability has been updated to include 2007 - 2009 model year 4Runner vehicles.
TSB No. EG005-06 is Obsolete and any printed versions should be discarded. Be sure to review the entire content of this service bulletin before proceeding.
Introduction
Some customers may complain of excessive sulfur odor on 2006 - 2009 model year 4Runner vehicles equipped with the 2UZ-FE engine under the following conditions:
^ Stop and go driving
^ Heavy acceleration
In order to reduce the sulfur odor new catalytic converter assemblies have been made available. Follow the repair procedure to replace the catalytic converter assemblies.
For more complete understanding of the root cause, refer to TSB No. EG003-03, "Sulfur Odor from Exhaust."
Warranty Information
APPLICABLE WARRANTY
^ This repair is covered under the Toyota Specified Major Emission Control Component Warranty. This warranty is in effect for 96 months or 80,000 miles, whichever occurs first, from the vehicle's in-service date.
^ Warranty application is limited to occurrence of the specified condition described in this bulletin.
Parts Information
Repair Procedure
Refer to the Technical Information System (TIS) applicable model year 4Runner Repair Manual:
ENGINE
EG020-04
June 14, 2004
Title:
EXCESSIVE SULFUR DIOXIDE ODOR
Models:
'03 - '04 4Runner (2UZ- FE)
Introduction
Some customers may complain of excessive sulfur dioxide odor on 2003-2004 model year 4Runner (2UZ- FE) vehicles under the following conditions:
^ Stop and go driving.
^ Heavy acceleration.
In order to reduce the sulfur dioxide odor, the Electronic Control Module (ECM) (SAE term: Powertrain Control Module/PCM) fuel cut control logic has been modified and a new catalyst is provided. Follow the repair procedure to reflash the ECM and replace the catalytic converter assembly.
NOTE: For more complete understanding of the root cause, refer to TSB No. EG003-03 "Sulfur Odor From Exhaust," dated February 24, 2003.
Applicable Vehicles
^ 2003 - 2004 model year 4Runner vehicles equipped with the 2UZ-FE engine produced BEFORE the Production Change Effective VINs shown below.
I'm having this tick problem too, which a mechanic told me is probably a cracked manifold. My 4R has 93k :cry: no emissions warranty fix for me apparently
