Fender Liner Part Number(s)
I just ordered a new set of these before I found this thread. Not sure if I'll keep the new ones or just make my own. If I get the new ones, I will make templates (I have a 2004 BTW).
[MENTION=115707]4WDFTW[/MENTION] That'd be awesome man...I wouldn't mind PayPaling you some $$ for your troubles if you can make some templates and upload them. Keep us posted
Can't be long before every owner comes across needing to replace these! There wasn't even enough parts of the liner left for me to template and what was left crumbled once I put hands on it! I tow a lot now and thought it was the result of my underhood temps being higher for longer than the average 4Runner but it looks like it's par for the course.
Good opportunity for a T4R'er to serve others and profit in the process who wants to take up the task of making a suitable replacement and selling it here on the forum.
Going to need these very soon so I spent the time pulling up the part numbers from the site that was referenced earlier in the thread. Anyone have any other recommendations on where to pick up the parts?
5373635150 Left front shield $20.34
5388635020 Left rear shield $18.05
5373535150 Right front shield $16.74
5388635020 Right rear shield $18.05
9046710186 Clip $1.42 (looks like 18 total are used?)
-David
What this guy said ^^^^
I'll let everyone know when they come in. I will draw up templates and should be able to scan them at work as a PDF. If not, i can draw them up and mail them.
And I'm in the same boat as everyone else.... mine are missing so I have nothing to build a template from.
ty
thats awesome
that is how i was going to try to do it to
scan it in a pdf
great minds
Check out what came in today. These things are freakin expensive! I should be able to just put them right on the scanner with a ruler and scan em in.
Great idea! I was lucky enough to still have enough of mine to trace onto new rubber, but for those that are missing completely that would be great! +1!
Okay, the liners are scanned. I have them as a PDF. You will need to be able to print 11x17 to get them. If you cant get access to 11x17, I can mail you a set. PM me with your email address for the file. Thanks
Thanks for doing this. I just haven't had time to take mine off to make templates. You are going to save the other huys a ton of money. That is what T4R.ORG is all about!
No problem, glad to help!
When you guys PM me, include your email address. It looks like I'm not able to include attachments in PMs so I will need to email you.
By the way, found the rear liners on Amazon for just under $15 each with prime delivery. Went that route for simplicity and time's sake as I've got more projects that need my attention that I can possibly tackle so time is at a premium.
Hey thanks for the templates
I Have not been on much but i am sending a few bucks your way
Thanks
I traced them right off of the computer screen and test fitted them and they were pretty dam close
Inly needed to move one hole over a little but that might be because i had to add and remove a little material as my remote resi brackets are kinda un the way
Wooot
Thanks again
Now i still have to cut them and install them tomorrow
Woot thanks again
