Auto Down Function for Driver's Window
bokmeipai
My auto down function just stopped working, I have to hold button down for it to go down completely. Does something have to be reset? Anyone experience this problem?
i just did mine about 10 min ago, HAHAHA!
All you have to to is with the key in the ON position.....press and hold the window button until the window goes all the way down.....Then pull button up until the window goes all the way up and hold the button for a sec or 2. The light is suppose to blink but I never saw it. Then press the button and check to see if that worked. It did for me.
Yep, just hold the button down for 5-10 seconds after it rolls all the way down, and do the same for it going up. This should reset it and get it working again.
I am going to guess you recently had the battery die on you, replaced, or had something done that required the battery to be disconnected. Your vehicle has lost is memory and it needs to be reset.
Simply cycle the window up and down 3 times to relearn the auto function, same goes with the rear window and other automatic functions. Toyota loves 3! :beer:
Yep it worked, Thank you all for the info !
