DIY ceiling MOLLE/PALS mount
beeftube
Recently I've been really annoyed with the 4th gen 4Runner's lack of "cubby" storage. Sure, there's the glove box and the center console, but that just doesn't cut it for a lot of stuff.
A friend of mine has an FJ, and ended up purchasing the Springtail MPAC MOLLE bracket that mounts over the driver's side wheel well in the cargo area. This is a great design; unfortunately they don't make it for the 4Runner. First, I set out to see if I could easily make a bracket to fit the FJ MOLLE mount -- but turned out to be more difficult than I was anticipating.
I could have used their bracket that mounts on the back of a seat, but the problem there is that I regularly have my seats folded down, and the 4Runner packed to the gills with dive gear (you cave dive and 2 people and all their gear will fill the entire truck completely by the time you have 2 sets of steel doubles, deco bottles, O2 bottles, gear tubs, tool boxes, gym bags, drysuits, etc.)
So, clearly I needed all the cargo space i could get. I kept searching around for ideas.
Next, I stumbled upon an old thread from a guy with a 1st gen 4Runner who used a piece of wire shelving to effectively make a MOLLE mount over the rear window (cheap MOLLE / PALS gear mount)
...this gave me some ideas. It obviously wouldn't work for the 4th gen, so I decided to see if I could do the same thing, just across the ceiling in the cargo area, using the "coat hook" mounts to mount a bracket that would hold a piece of wire shelving cut and bent to length.
Turns out, it works okay. I found a 4' piece of wire shelving at home depot that I used. I had to trim it about 5" (don't remember exact measurements), and then bend each end down to contour with the ceiling.
The brackets are fashioned out of an aluminum 3"x1/2"x3' threshold that I also found at Home Depot. I used the existing drilled holes, and took the factory plastic "coat hook" and used it as a template to mark where to drill the next hole. I then cut it to length. (Did this twice to make two brackets).
I test fitted and it seemed to bolt up and was pretty sturdy. I took it all down and sprayed it satin black so it wouldnt just look like I tried to install a shelf in the back of my SUV. :)
I wouldn't put more than a couple pounds of gear on it, but it's good for mounting a lightweight first aid kit, a few lights tools, and a get-home bag. best part is, it doesn't interfere with the rear view hardly at all! I wouldn't call it "pretty", but it works okay.
Pics below (sorry for crappy quality -- it was dark, and I was using my cell phone. Click for big!):
One thing I would recommend would be to get MOLLE bags that have the velcro backing that can be removed quickly -- that way you only have to string up the velcro backing once. There's not a lot of space between the wire and the ceiling, and it makes stringing the bags up a pain in the arse.
A good example would be some bags made by Condor (http://www.condoroutdoor.com/ma41rip-awayemtpouch.aspx). I think SpringTail makes some rip-away bags as well.
