I've tamed the Magnaflow Catback
Ducman
About a month ago I installed a Magnaflow catback. It sounded great, I was very happy until.... it broke in. DRONE CITY. The resonance with the windows up at certain RPMS was extremely uncomfortable.
I'm no stranger to aftermarket exhaust on a V8... I've owned several V8 Mustangs over the years with various exhaust systems (mostly Magnaflow) and never heard anything like this before. It was not good.
I knew I didn't want to go back to stock... so I started looking at what my options were and did some reading...
I took some measurements and figured I had just enough room for a large resonator in place of the long straight pipe right infront of the muffler.
I purchased a 2.5" Vibrant Ultra Quiet Resonator, made 2 cuts in the straight pipe with a pipe cutter and slipped it over the 2 end pieces. I reinstalled the pipe and took it for a spin... still throaty but just not so abrasive sounding. I gave it a week to 'break in' and it did get a little louder but still very quiet. After I was sure I was happy with it, the local muffler shop charged me $20 to weld it on.
I did have to bend the heat shield above it just slightly in order to make room for it. I've got about 1/2" of clearance above the rear edge. A tight fit but it does fit.
I'd estimate it reduced the resonance that happens just before the 1-2 shift and again just before the 2-3 shift by about 50%. Overall volume is probably reduced by 50% or so.
At idle - 25% throttle you can hear a nice note inside the truck but outside it sounds nearly stock. At 50%-75% throttle you get a nice throaty exhaust note both inside and ouside the truck and then strangely at 100% throttle you can hear the engine more than you can hear the exhaust inside the truck and outside its actually slightly more quiet than 50% throttle.
For me its damn near perfect.
Smaller resonator
Another option is the 2.5" Vibrant bottle resonator, shown with the Ultra Quiet version.
The bottle resonator is much easier to fit but only cut overall exhaust volume by around 10% or so, it did take the edge off the resonance reducing it by maybe 25% or so but was not enough for me so I stepped up to the larger one.
