Them Be Me Mods
Blue Sea 12V Power Port to the Aux Battery in the engine bay mostly to be used for the awning lights. Other than the refrigerator power this is the only always hot port on the truck.
PowerPortEngine_zps372a88fd.jpg~original
let me know when you want to drill those front fenders!
I've never used synthetic winch line so could you share what caused it to break and why it was knotted up? I've certainly inadvertently kinked wire rope winding it back in and am guessing that the more flexible synthetic could more easily kink, but just have no experience with it.
Long story short: You will be fine if its used correctly. Slow steady winching and when respooling always have the rope under tension. Out of frustration and laziness I did neither. There are also better ways to take down hung up trees which I ignored as well :censored:
Maybe about 10K and so far no issues at all.
BTW, welcome! Let me know if you need any help at all or want to get your new pretty truck dirty ;) Nice rides!
Probably not the question to ask about the Duratracs, but I am curious - how was the fuel economy on your trip out to Colorado?
We just traded our 2003 for 2015, and we make trips from San Antonio to Colorado every 3 months (we are from there). The 2003 4R had Firestone Destination ATs, and they handled everything with ease. I am just wondering how much of a hit I am going to take for getting the tires that litterally everyone and their cousin on this forum seem to be running in the snow and ice.
We off-road on trails every once in a while, but we seem to always get caught in West Texas, New Mexico, or Colorado with a need for 4WD and maximum traction. I am trying to determine if I want to go to the Duratracs or not.
Cheers! (and awesome thread)
Sorry but I'm the worst possible person to ask since I don't track mileage, nor do I really care too much about it. My truck has a nifty gauge that tells me when I need fuel and when it does I add more.
I know some of my mods have hurt my mpg but i honestly can't say how much.
I completely understand. That was me in my 2007 Tacoma. Now-a-days, I don't have that luxury. We typically put anywhere from 2,000-3,800 miles on our truck in 1 month. I just got the 2015 TEP 6 days ago, and I have already logged 800 miles.
Thanks for the response though.
Cheers!
As anybody with a dog can testify, getting the hair out of the back carpeting is a real PIA. Having a yellow lab and black interior does not help. I just installed a set of Canvasback Canvas Custom Cargo Liners. Price was $ 159 and so far so good. The Velcro is very strong but time will tell how well it holds up.
CanvasbackCanvas2.jpg~original
She seems to approve!
CanvasbackCanvas1.jpg~original
Hey, how are these holding up?
As good as the day they were installed. Dog holding up well too :D
It might just be the shine showing in pictures, but how slippery are those for your dog? Have you taken her off-roading in there? My dog was a little all over the place when I took her out last weekend with a heavy blanket laid down, that definitely was not the best solution and I'm wondering if these would be better. I don't drive fast, more crawling but the up and down angles with her 85 pound weight made the blanket slide under her.
It does seem a bit slippery because every now and then if I make too sharp of a turn I hear a thump from the back. :shrug: However she is learning to anticipate and the thumps have greatly reduced as her experience increases. But it’s not there for the dog; it’s there to make cleaning up after her easier on ME. And that it does very well. As much as I love the mutt the day she stops shedding is the day I'll put something back there more comfy for her.
Yes, she is a veteran off roader as well as boater, camper, etc. and even knows not to get in front of the muzzle when we are shooting....most of the time.
That's good to know, thank you for the feedback!
5th Gen 4Runner On Board Hot Water Shower System (Heat Exchanger)
Met Ben from OutbackProven.com at Overland Expo and fell in love with the Piranha Power Hot Shower Kit from Australia. Its basically a heat exchanger which uses engine coolant to heat the water and a pump / filter to supply from a water source.
Trouble was that I'm basically out of real estate in the engine bay so why not just cut into and use the fender space?
ShowerInstall5_zps7bda43e6.jpg~original
ShowerInstall3_zps00412b6d.jpg~original
ShowerInstall4_zpsd20a4b11.jpg~original
ShowerInstallLocation_zps8221a122.jpg~original
ShowerInstall1_zpsb49805ca.jpg~original
ShowerInstall2_zpscc4efe56.jpg~original
Hello,
Your Hot Water On Board system is so nice and professionally built. You are the only 5th Gen 4Runner owner, who I found , installed such a clean solution. I am (a non-tech guy) planning to follow the same path to build the similar system in my 4Runner. May I seek your valuable experience about this project?? :
1. Is there any potential risks in terms of mechanical failure (e.g. coolant leaks, pressure level reduced, heat exchanger too hot & cause fire, engine overheat……..) for this modification? Please give comments about the potential to compromise the durability of the truck.
2. There is a potential risk to MODIFY (not add) the engine system and it could void the manufacturer warranty?
3. Can you get “warm water” even though the engine is in idle running (e.g. 800rpm) and water temperature “can be increased” by something? How can you control the water temperature? Do you need to increase the rpm or change the air heater level inside your 4runner?
4. Any potential issues for the heat exchanger to be cracked/damaged during winter freezing season, some water was left inside, right?? What are you going to do in winter time?
5. Connection method :
I look under the hood, there are 2 pipes (coolant flows through them) of core heater hose going through the firewall into the vehicle. Do you know :
Upper Pipe (Coolant returns from the heater) ??
Lower Pipe (Coolant flows into the heater) ??
Certainly, it can be verified by touch them to see which one is hotter (flow into the core heater). But this is not scientific, could be wrong !
Where did you connect with the Core Heater Hose? Are you connecting in series with the heater core hose? Are you using the in-path (i.e. coolant flows into the heater core) or out-path (i.e. coolant return path from the heater core)?
6. What connector types/size (in the heat exchanger) would be the easiest for non-tech person to carry out this project in the 5th gen 4runner? E.g. ½” Male NPT, ½” Hose Barb, 3/8” Copper Sweat….. I want to choose the simple connector types of the heat exchanger to match the hose dimension. I want Plug and Play method if possible.
7. I intend to connect the heat exchanger in series with the coolant return path (i.e. after coolant going out from the core heater unit). Then, I just need to disconnect one hose to minimise the change. There is no impact on existing core heater for its heating performance. I can also control the water temperature with the core heater knob (coolant flow rate) inside the vehicle as well. How would you comment this configuration?
8. What is the dimension of the core heater hose that I should buy?
9. After installation: I need to refill coolant (there may have some lost by redirect it to the heat exchanger)? How can I verify the existing core heater (hot and cold air blow out from it) still functioning as before? For those professional mechanics, do they have any tool to check the coolant pressure/level, heater performance??
Looking forward to share your valuable experience with ALL 5th Gen 4Runner owners !
Damn Johnny, most just post 'nice truck' and move on :bigok:
Pm me your email address and I'll send you more technical info. Generally, anything can and everything will fail but I've had it for a while now with zero issues whatsoever. Of couse it's not used daily because who takes showers every day?
This always has been...and continues to be...
the Gift that just keeps on giving...:cheers:
Just sat down and read 31 pages of awesomeness.... Few questions
1) how many usb/power ports have you installed
2) how many feet of wiring would you guess you have used
3) which is your favorite switch
