Aiming The Headlights Down
lookingatlife
I purchased a 2010 4runner that had a 3 inch lift kit installed and it seems like the lights are aiming a bit high. Every time I drive I night I get the the high beam signal from at least 5 cars.
I know on my FJ that once I lifted it I needed to point the lights down a bit to offset the life.
Anyone got any ideas?
Sorry, couldn't resist.
Yes, it's simple, just adjusted mine a few days ago, same reason. But I have no idea if you can compensate for a 3" lift.
There's a ~3/4" toothed, aluminum-colored disk on the back of the headlight. On the driver's side, it's ~1.5" from the battery. You can turn it with a thin flat-bladed screwdriver, or a ratcheting box wrench I suppose.
Easy-peasey.
Easy-peasey.
The easiest way is to use a long Phillips screwdriver. There is a black plastic "guide" that goes towards that bolt. The Phillips head turns "gears" of that bolt head.
SHUT UP .... seriously? That's too funny ... here I've been fumbling around with a flat blade, flipping one tooth at a time. Doh!
