OW 2.0 Setup Soon/Opinion
cbielat
After much research, I am extremely close to pulling the trigger on the Overland Warehouse 2.0 system. My main reason for the 2.0 is because I do not really take the vehicle off road or planning on adding any additional weight to require the 2.5 system. I understand the 2.0 system is completely capable of handling moderate off road use. I am on the road many miles per day for my job so, I do not need the characters of the 2.5 system. I am choosing to go with the 2.0 system for more of an aesthetically pleasing appearance and the quality of the products from what I have researched (mainly on this forum).
I would really like to hear what some of you have to think about this decision and from anyone who has the 2.0 system.
Thanks!
The OW 2.0 kit is capable of much more than just moderate off road use. If you're looking for pure aesthetics then why not just go with Bilsteins or a spacer lift? From the sounds of it they'll be better suited to your needs at a much lower price.
Intruder- I have researched and thought about going with the Bilstein 5100's, but I do like the option of the more adjustable OW coil over. I have also considered the spacer but after reading and seeing the negative effects of what a spacer could potentially do to the shock bottom quickly turned me away from that option. I do know however, that the OW 2.0 can handle more than moderate off roading as well. I should have worded it differently the first time. I guess any off road driving I would do would be considered moderate.
I'm very happy with my 2.0 kit. It handles much,much better on and off road and has greatly reduced the nose dive and sway. The dust does make mine a little creaky from time to time though.
I too love my setup, the handling is soo much better. Just be sure to do the zero point calibration if you feel that your vsc is kicking in too much post lift.
Same experience as everyone else.
Head and shoulders above the stock suspension XREAS.
Its a great set up for what you are describing you're goals are.
