NFAB Steps INSTALL 2011 SR5
irnmanfan
My fiance got me the NFAB steps for Christmas for my 2011 SR5 4Runner so here is the install. I had to order 4"x4" tube 1/4" steel to fabricate the spacers for them to fit below the body kit. The NFAB step ups are ONLY available for the trail version...they should really think about working on getting a set for the SR5 and LIMITED. I called but "no such luck".
It's a pretty simple install if you have the tools but here's a quick recap of what I did.
  • 1 foot piece of the 4"x4"x1/4" tube steel MetalsDepot® - A500 Steel Square Tube
  • Cut them into 2" sections (I used a chop saw, pic 1)
  • Trace out the hole on the steps onto the 2" tube steel
  • Measure the center of the steel and draw a line down it (the center is 2" since the length of the steel is 4")
  • Drill the holes within the traced holes you used form the steps and down the center line you measured
  • IMPORTANT (the space of the steps and holes in the frame of the 4Runner are exactly the same hole pattern.(no need to crawl under to measure)
  • Notice the front bracket under the 4runner has only one hole, used the nut/hole closest to the running board.
  • I used a drill press to drill the holes with a few drips of oil as to not burn up my bit (this may take some time without a drill press, it is 1/4 steel)
  • You will need to buy 2 EXTRA 8mm bolts, 2 EXTRA washers and 2 EXTRA locking washers and since you are NOT bolting the steps direct into the frame you will need 12 nuts; I got locking nuts rather than using locktite and I never trust a lock washer(10 bolts, washers and lock washers come with the steps)
  • I mocked everything up for a trial run to make sure everything lined up
  • BE SURE TO SPRAY PAINT THE SPACERS OR THEY WILL RUST IN LESS THAN A WEEK
  • When bilting the spacers to the frame they will slide UNDER the brackets holding the running board on (sorry no good pic of that)
  • Use painters tape tape your running boards as to not scratch or dents them paint.
  • Be sure to use locktite when bolting the spacers to the frame (you have nuts for the steps bolting to the spacer, no need for locktite there)
IMG00810-20120114-1041.jpg~original
IMG00812-20120114-1045.jpg~original
IMG00813-20120114-1051.jpg~original
IMG00818-20120114-1336.jpg~original
IMG00816-20120114-1202.jpg~original
IMG00815-20120114-1201.jpg~original
IMG00821-20120114-1405.jpg~original
IMG00825-20120114-1547.jpg~original
IMG00824-20120114-1547.jpg~original
This is the meat of the install, I didnt want to go on forever with details so I hope this helps....they look badass!
ONTO the lift!
nice write up...they look great! Sooooooo...when are you going to fab me some of those spacers since I do not have a drill press? ;)
I might be able do that, when I ordered the tube steel I got a few feet just in case. The steel is a bit pricey along with shipping and I'd have to buy a new blade to cut it. What were you thinking regarding price?
BTW the front fog lights look great, I might think about doing that!
Thanks...I like the setup! As for price...you tell me something fair. I didnt look at the tube steel prices...so I have no idea. Parts, some $ for labor...and shipping. Let me know! No rush either...
+1. I'll buy a set of spacers to. Already PM'd you. Awesome write up btw.
edit: Really NEED these spacers. :) Just ordered some NFAB steps for $300 shipped from streetsideauto.
Spacers to install NFAB's on SR5 and Limited
I never received a response from the OP so I decided to make some spacers on my own using the directions from irnmanfan. Thanks to him for doing all the legwork.:guitar3: :thanks:
My NFABs arrive tomorrow so i'm hoping to have them installed by tomorrow night using these spacers. If anyone is interested in getting some of these spacers, please PM me. I bought some extra tubing so I'll be able to provide the spacers along with all the necessary extra hardware to install NFAB's on your SR5 or Limited. All you will have to get are the NFAB's. I may powder coat all the spacers to.
Nice write up! Steps look great!! Wish I saw this before I bought my boards.
Thinking of some RR supersliders now tho so boards may be for sale soon.
So yesterday I called up a local metal shop and order some metal.
12' 4"x4"x 3/16" tubing.
The nice part is I had them cut it into 6 2" piece for $22.
When I got home I punched some holes into it using my drill press.
Then I sprayed the pieces with some spray on bed liner $9.95.
It was super fast and easy.
Thanks for the write up and I'll post some pictures as soon as I can.
Here's the link METAL SUPERMARKETS - Buy Metal Online - Small Quantity Orders for Aluminum, Stainless Steel, Hot Rolled Steel, Cold Rolled Steel for Delivery or Local Pickup
How did you mount the front bracket? Did you make a different style hanger so you could use both bolts to mount it to the body?
I made completely different brackets. you can find pictures in my build thread.
Had to give a ride to a friend last night.. 290lbs power lifter - they held up just fine.. surprisingly..
Spacer price
Did you decide to get into the "spacer" business? If so, PM me and let me know how much. I'm tired of hopping into my 4runner and want the Nfab set.
Thanks!! :bigok:
ONTO the lift!
Does the front of your step side hang down a little? I followed your measurements and steps and didn't know if you had this as well
