Door lock/unlock programming
steve73
This is for key entry system....
Can you configure the locks so hey lock automatically at 12mph and then open automatically when the vehicle is put in park
I can only seem to get either : LOCKING WHEN over 12MPH(stay locked in park)
OR
AUTOMATIC Open in drive and AUTOMATIC
locked When in park
Page 54-55 in owners manual. You can do the locks yourself. Ignition to on position, within 20 seconds shift into park or neutral, hold lock or unlock for 5 seconds. Refer to the manual, there is a chart for options.
P/L (Shift position/Door lock switch position) = locked based on shift function
P/UL= unlock based on shift position
N/L = Speed linked lock
N/UL = Driver door linked unlock. when opens, unlocks all
When programmed, doors will lock and unlock once to tell you its done. Repeating the same procedure cancels the individual function.
I currently have shift out of park locking, speed locking (in case i manually unlock, step out etc), and driver door unlocking. Cancelled the unlock in park for safety.
