Kicker Sub installed under Driver Seat - thanks ANTMAN
jnance50
So I didn't take alot of photos of the install as they are basically the same as this post:
http://www.toyota-4runner.org/5th-gen-t4rs/92013-antmans-thread-24.html#post989173
I did however use a different Sub, situated it differently, and mounted the remote bass unit in a different location. It sounds awesome. I mean, as noted before, this is no 12" sub with 600 watts. They are 8" subs, and with a built in 150watt amp so set expectations accordingly - but I will say this exceeded my expectations - it really bumps. In fact, if you turn it up, it's a 2 in 1 mod - bass and massage chair. One thing I really like about this unit is it has a bass boost, so you can turn that all the way up and it lets you turn the bass on the head unit down, saving your factory speakers from blowing or distortion if you're really jamming. Whole thing picked up at BestBuy for $299, same as on Crutchfield and Amazon.
You can see the orientation and how it fits here:
One problem was the vent for the back seat that it sits on top of, I was worried about blowing hot air onto it all the time:
So, I found these little rubber door stops at home depot (adhesive already on them), trimmed them a little, and stuck the to the bottom of the unit to raise it just slightly to allow air flow:
And finally, I just drilled a hole in the back of this uselessly small cubby and the unit fit perfectly, even with the lid closed. You actually cannot see it at all from the driver or passenger seat. The edge of the unit sits flush with the edge of the cubby, the knob protrudes from there but still does not contact the lid when closed - pretty sweet:
that is quite interesting, never seen that before. looks like a cheap solution for the average person that doesnt want big sound.
Agreed, as long as you keep it turned down. Having just done some extended time in the T4R with it, it is deceptively loud. As it turns out, there's a difference between 600watts and a 12" sub in the cargo area ... and sitting on top of an 8" sub with 150watts - the effect is almost comparable truthfully - mine rarely ever sees above a 3 or a 4 absolute max on the dial ... which in Kicker fashion goes to 11.
its tempting for me to get something like this. i dont want to spend big bucks or lose cargo space in my 4Runner. my other 2 vehicles has stock subs that suffice for me. i am no audiophile so im easy to impress, the BOSE in my 2500HD and the B&O in my Audi are both 8" subs and they are plenty to keep me happy when cruising.
So it's been a few weeks, any thoughts, impressions on your new sub?
I'm thinking of adding this sub along with the Kappa's in the dash and know that Antman didn't like his set up and swapped out his sub so I'm thinking this Kicker would be the way to go. Also are you happy with the location being under your seat or would you recommend it being else were? While I'm looking for more bass I don't want to be overwhelmed with it because it's right under my a$$.
Thanks
Thanks
No thoughts?
Sorry, missed the update. Initially I wished it had gone in the back somewhere - admittedly having it under your drivers seat takes some getting used to.
That being said, a week later I started really liking the placement and now I'm sure it really is the best option. Reasons for this being without loosing cargo space there really is no other place to put a sub - and this sub - while it has really impressive output for it's size would not be enough when put in the rear of the vehicle. And what's more, you would not want any more bass under your seat - it really does double for a massage chair when turned up. Really impressive if you ask me - and it fits perfectly.
The only other thing I've been thinking about is perhaps running a second one under my passenger seat - the controllers wire is just a headphone cable ... so I'm thinking I might even be able to run a splitter and be able to have them on the same control - and wiring it would be super easy, I could just tap the other speakers harness in the dash ... but we'll see.
No thoughts?
Awesome, thanks! I'm definitely there. Also, if you decide to do this / need any help with your lift I'm more than happy to help.
Thanks for the offer, much appreciated :hatsoff: Having it installed at my bro in laws shop so I'm all set...I hope :lmao:
i am really thinking this would be a great mod. I really miss the fosgate system in my Xterra (which had a factory sub under the driver seat!).
do you guys notice the stock stereo booms a bit too much? I have to turn down the bass some times, especailly when use my iphone through the USB port.
